200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Sep 10, 2022 at 1:41 PM
    #1341
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Got any pics? Did you change the color?
  2. Sep 29, 2022 at 6:23 AM
    #1342
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    On my way to work this morning, 02 Daily driver
    Things that i have had to change, numerous brake pads, rotors, spark plugs. One coil pack at about 250K, radiator at about 450k, rear wheel bearings at about 480K
    Everything else is still original including the clutch, she still runs better and is still a better truck then my 20 proIMG_7577.jpg
    RobA, JoeT4R, ToynbyuTicotex and 10 others like this.
  3. Sep 29, 2022 at 8:08 AM
    #1343
    mbeers6
    mbeers6 Well-Known Member
    East bay, ca
    03 tacoma double cab 4wd
    Air filter
    That is awesome! Did you ever replace upper or lower control arm bushings / front wheel bearings? I have 226,000 on my '03 (no lift) and while it rides little stiff I don't think the bushings are shot. Just curious..thanks!
  4. Sep 29, 2022 at 8:34 AM
    #1344
    smithlaketaco
    Houston, Al
    no, i did forget i changed the shocks at about 490,000
    mbeers6 likes this.
  5. Oct 14, 2022 at 8:04 PM
    #1345
    cone of shame
    cone of shame Member
    Denver
    02 TRD NY -> AK -> CO
    Salt spray and rock chips.
    Hit 222,222 miles as I pulled into the driveway two weeks ago. 2002 TRD Ext Cab V6.
    Bought it as an immobile rust bucket / pandemic project at 209k. The previous owner had used it to launch boats in salt water in Alaska and apparently didn't know about car washes or underbody treatments, or apparently any routine maintenance beyond oil changes. The clutch was shot, the coolant was a color that no living person has seen before or since, the rear axle had blown seals and was contaminated with salt water, every fastener was rusted solid, and the A/C lines were open to god and everyone. But it was cheap, the motor was strong, and I was bored to death.
    Immediate new clutch, ball joints, CVs, rear axle bearings, seals everywhere, timing belt & water pump, brake job, U-joints, steering rack and tie rods, and flushed every fluid. Got it back together just in time for 2020 muzzleloader season and used it to bring home a moose (!!!) on opening day.
    Rebuilt the air conditioner, new bumpers, full suspension replacement at 213k. Found a decent junkyard bed at 215k to replace my swisscheesed one. New rear driveshaft at 218k -- but in retrospect I should have just had them weld a new serviceable double cardan onto the original shaft. Drilled the roof for NMO mounts and ran 20A to the back seat for ham somewhere around here, too.
    Intake cleanup, lash check, and valve cover gaskets at 221k, no more burning oil smell! New oil cooler gasket and hoses. Fuel filter and plugs, and boy was it time. Sent the rear diff to ECGS while everything else was apart, pinion growl is now a thing of the past. The locker actuator was full of hardened saltwater mud and had corroded to the third member, I had to beat it off/apart with a cold chisel.
    Next up is door checks, a custom overhead console, and tracking down this new knock sensor code (it's probably a loose connector).
    After all this, she still purrs like a kitten. Passes emissions every time, does everything I need, MPG unchanged from the dealer sticker. I live in the desert and it's the rustiest truck in town, nobody messes with it. I love this piece of shit so much.
    Many thanks to @Timmah! and @pistonsandpixiedust for their excellent and timely videos.
    TWJLee and Timmah! like this.
  6. Oct 14, 2022 at 9:14 PM
    #1346
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
  7. Oct 19, 2022 at 6:20 PM
    #1347
    Lost in GA
    Lost in GA Member
    GA USA
    2003 Tacoma DLX SR5 V6 TRD Ext Cab 4x4, stock
    My 2003 has 315,000 and still runs good...except for that vibration in the drive line.
    Smithlaketaco - I'm impressed with the half-a-million mark. Kudos!
    smithlaketaco likes this.
  8. Oct 28, 2022 at 5:20 AM
    #1348
    GrandCrews
    GrandCrews New Member
    Luke
    Black '98 Tacoma SR5 Ext. 4x4 Auto with 3.4L V6
    3" Lift kit, 33" Mickey Thompson MTZs, shortened exhaust with Magnaflow Muffler, cold air intake, evap bypass, and led side marker lights.
    My 1998 has 309xxx, bought it a little over a month ago with 307xxx
  9. Oct 28, 2022 at 5:52 AM
    #1349
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My first Toyota was a white 1968 long bed Hilux sold it to my neighbor with 312,000 on it he drove it for 3 more years!
  10. Oct 29, 2022 at 5:42 PM
    #1350
    Cribb
    Cribb Once it hits your lips, it’s so good.
    South Carolina
    1996 Tacoma 2.7 XtraCab 4x4 5spd
    2” suspension lift, 2” body lift, 33” tires, K&N intake, LCE header, Alpine head unit, Kicker KS door and pillar speakers, 10” Rockville slim powered subwoofer, red/clear taillights, clear corners, clear turn signals, LED headlights, LED tag bulbs, LED reverse bulbs, LED dome lamp, Husky floor liners
    Just shy of 241K.
    tacomamom04, ztwatson and Soonr1 like this.
  11. Oct 30, 2022 at 12:29 PM
    #1351
    Comtnyota89
    Comtnyota89 HHOPWR
    Paul
    Colorado
    95’ Tacoma Ext. Cab
    {31x10.5R15}-{OME Dakar Leafs & Shocks + Belistein 5100's Front}-{LED Headlights + Bar & Pods}
    Almost 250k…
    ztwatson and Road_Warrior like this.
  12. Oct 30, 2022 at 4:59 PM
    #1352
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Very nice!
    I just picked up this 03 from the original owner with 301k miles, on the original clutch. Still grabs and shifts fantastic.
  13. Nov 11, 2022 at 9:13 AM
    #1353
    pcm
    pcm Well-Known Member
    I am at 341,862 on my 02, 2.7L 4cylinder , standard transmission! Regular maintenance and age related replacements. Did get the new frame installed by Toyota, bonus! Never selling.
    Soonr1 likes this.
  14. Nov 18, 2022 at 8:34 PM
    #1354
    Neverdiebyanother
    Neverdiebyanother "When nothing goes right, go left."
    Chuck
    WYOMING
    '96 Taco
    Rock sliders, bedliner, intake, turn signal mod, ARB front bumper, All-Pro Off-Road Pre-Runner Rear Bumper, Smittybilt X2O COMP wench (pun intended) W/Synthetic Rope, snorkel, OME 883'S, BILSTEIN 5100'S F/R, air bags, big 4,more to come.
    Get it rebuilt until you find another one, at least you'll be able to drive it.
  15. Nov 18, 2022 at 8:38 PM
    #1355
    Neverdiebyanother
    Chuck
    WYOMING
    '96 Taco
    Reminds me of Mitch Hedberg
    https://youtu.be/q2FzHZ84k14
    Black97v6MT and Comtnyota89 like this.
  16. Nov 18, 2022 at 8:41 PM
    #1356
    Neverdiebyanother
    Chuck
    WYOMING
    '96 Taco
  17. Nov 23, 2022 at 7:21 AM
    #1357
    LitRed-lll
    LitRed-lll Member
    Terry
    2014 Tacoma Regular Cab 4WD
    2004 - 250,000 mi original owner
  18. Nov 23, 2022 at 8:01 AM
    #1358
    erice
    erice Well-Known Member
    Eric
    San Diego
    Just rolled 360666k
    Black97v6MT likes this.
  19. Nov 25, 2022 at 5:21 AM
    #1359
    Soonr1
    Soonr1 Well-Known Member
    2022 Army Green TRD Off Road
    That truck is super clean man. Looks great.
  20. Nov 28, 2022 at 8:00 AM
    #1360
    LitRed-lll
    LitRed-lll Member
    Terry
    Thanks for the compliment - I bought it new on March 27, 2004. Put 120k on it and then sold it to my brother. He put 110k on it and decided he wanted to go to the dark side and get an F150. I bought it back in Sept 2017 and have had it ever since.
