200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. May 31, 2024 at 9:51 AM
    #1481
    Švejk
    Švejk Member
    Švejk
    2004 Burgundy Access Cab Tacoma SR5 2.7l V4 Manual
    Nice truck man. Is it an automatic or manual? Merely curious.
  2. May 31, 2024 at 9:57 AM
    #1482
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    little quirks?
  3. May 31, 2024 at 12:06 PM
    #1483
    nwdetectorist
    nwdetectorist Member
    Oh, it is a wonderful 5-speed manual with the 3.4L V6.
    I would have like a bit better mileage but its a great engine.
    Švejk[QUOTED] likes this.
  4. May 31, 2024 at 12:08 PM
    #1484
    nwdetectorist
    Quirks like cloudy old plastic headlamp lens, some very small dents, etc.
    Nothing too overwhelming, but...
    I sure do miss the older Toyotas where you could actually see where the plug wires came from and where they went to.
    A time when a simple set of automotive wrenches and a cheap 'Equus' brand timing light kit was all you needed. :)
    Švejk and Black97v6MT[QUOTED] like this.
  5. Jun 9, 2024 at 4:49 PM
    #1485
    conor138
    conor138 New Member
    Skipzero
    Oakland, California
    Blue 99 Taco 2wd xtra bed
    Hello folks. This is my first post, but I've been lurking for years figuring out how to keep my '99 taco on the road. I've had it for the last 15 years and when I saw the 200k thread, had to at least say something about the last ~150k I put on it myself... I've got a 2wd xtra cab with the little 2.4L engine, but she'll carry two vintage motorcycles while pulling a trailer with one more on it over the grapevine (I5), or did when I first got her about 2009. it might take her a full minute to get up to highway speed if there's a little incline, but she's got legs once going!
    I'm back on here again cause the clutch is starting to slip and gotta do all the research I can before I put her up on jack stands and attempt to drop the tranny. watching videos on youtube and already miss having to drop the transmission in my pop's old '65 chevy 1/2 tons. a whole lot less keeping that thing in the truck back then!
    anyhow, I've got over 220k on her now and save for blowing a spark plug that I had to install a helicoil to repair, she's been pretty maintenance free!
    Soonr1 and Dalandser like this.
  6. Jul 1, 2024 at 4:32 PM
    #1486
    tacocopter
    tacocopter Enguhhhhhhhneer
    Nick
    St. Mary's, MD
    22 Tacoma SR
    I hit 200k at the beginning of June! Some of you may remember though that I never got lucky with the frame recall and repaired the frame myself. Well, it started to rust through again and I didn’t feel that it was worth the money to repair a second time. Traded my 1st gen for $500 on a ‘22 SR. Was surprised to get that much!
    Soonr1, Texas-Gorilla and Dalandser like this.
  7. Aug 5, 2024 at 1:08 PM
    #1487
    leebob#9
    leebob#9 New Member
    1997 Tacoma 2wd
    I've got 308,000 miles on my 97. The original radiator crapped out causing the motor to overheat so now it's got a new head gasket and of course new radiator. Plus new master and slave clutch cylinders, several new sensors, interior door handles oh and lower ball joints crapped out causing the front wheel to fall off. if you have that problem get replacements with grease nipples. But that's about it. Runs great, had it about 12 yrs. Love it! But I wanted to ask about the timing bet. I read it doesn't have one but instead a timing CHAIN. How long does the chain last?
    Black97v6MT likes this.
  8. Aug 6, 2024 at 6:00 PM
    #1488
    TacoBaco2002
    TacoBaco2002 Member
    Craig
    Michigan
    2003 sr5 extracab 4x4
    03 SR5 with 275k and runs like a champ :)
    Soonr1 likes this.
  9. Aug 7, 2024 at 8:58 AM
    #1489
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    The Wet Okale: Are those the 17tan with 100taupe full piping?
  10. Aug 11, 2024 at 5:38 PM
    #1490
    astroroush
    astroroush Member
    Benjamin
    2001 Yellow 2.7 5pd 4x4 XtraCab
    Bought with 223k in 2022, at 236k now.
    Summer 2022:
    replaced the rear shocks, ublots, ubolt plates, brake balancer, rear bushings
    refurbished the rear frame with rust protecting paint and welded a rust busters repair kit to the front leaf spring
    Summer 2023:
    replaced oil pan, steering knuckles, ball joints, tie rod ends, wheel bearings, stereo
    This past week:
    replaced rear axle/diffIMG_8392.jpg
  11. Aug 16, 2024 at 11:12 PM
    #1491
    nbscooters
    nbscooters Member
    Socal
    1996 Tacoma 3.4l 4x4 EXT cab
    16" Method NV-305 Falken 275/65/16 SPC Light Racing UCAs Complete OME Lift w/ 883s, Nitrochargers, and Dakars. Tundra 13WL Caliper Upgrade Akebono Brake Pads LED Headlights AGM Battery Trailer Hitch Install Camper Shell
    Bolted a TVS1320 at 200k
    Laxtoy, Jase, Soonr1 and 1 other person like this.
  12. Aug 17, 2024 at 12:55 AM
    #1492
    PreRun01
    PreRun01 New Member
    Jeff
    2001 Prerunner
    2001 Pre Runner with 265k. I bought it new and it still has the original starter and alternator. I've replaced the valve cover gaskets, lower ball joints, driver side door handle and the vent window latches. I replaced the water pump with the last new timing belt just because it was convenient. Last year I replaced downstream O2 sensor. After a few hundred miles it started surging under slow acceleration. It turned out to be the new O2 sensor. It doesn't like anything but Denso O2 sensors. Over the past month the transmission has started acting a little funny when cold. It seems to have a small inconsistent vibration and it shifts rough occasionally. I've never touched the fluid or anything so I just drained the old fluid (about 3 quarts which was pitch black and smelled like an old Farmall tractor) and added some new stuff. It seemed to help a little. Next on the list are new UCAs, UBJs, and strut/coil assemblies.
    Black97v6MT and Soonr1 like this.
  13. Aug 17, 2024 at 12:57 AM
    #1493
    PreRun01
    PreRun01 New Member
    Jeff
    2001 Prerunner
    And I have the classic issue with the rheostat for the blend door switching from hot to cold whenever it wants
  14. Aug 17, 2024 at 4:50 PM
    #1494
    Black97v6MT
    iMA0
    tacoLand USA
    Just got one of these,
    better late than never...
    DarkWoods04, Jase and Dalandser like this.
  15. Aug 26, 2024 at 4:38 AM
    #1495
    _-IV-_
    _-IV-_ New Member
    Louis
    1998 white tacoma sr5
    -k&n cold air intake -flowmaster cat back eqaust system -LCE headers - trail gear rock defence front bumper -trail gear rear bumper -trail gear rock sliders
    Just realised i hit 275k. All still runs like new
  16. Aug 28, 2024 at 1:44 PM
    #1496
    4sfire
    4sfire Active Member
    southern South Dakota
    Current: 2015 TRD Sport 4x. Past: 1998, 1991, 1985 Toyota 4x4 trucks.
    Leer camper shell Westin Brush Guard Springer Spaniels
    Toyotas:
    Got a 1985 Truck in 1987, put 250,000 miles on it and traded it in for a...
    1991 in 1993, put 250,000 miles on it and traded it in for a...
    1998 in 2000 with 60,000 miles on it, put 435,000 miles on it and traded it in (along with my Yaris) for a...
    2015 Tacoma in 2017 with 30,000 mi on it. Has 293,000 mi on it.
    Also inherited a 1984 Camry in 1994 with 12,000 miles, and put over 100,000 mi on it before I got rid of it.
    Bought a 2012 Yaris used in December 2012, put about 250,000 miles on it and traded it in w/ my 98 for my current truck.
    Worst vehicle decision ever, trading in my Yaris.
    That is a lot of miles on Toyotas and I don't plan on trading in my current truck, ever. I like Toyotas. Use them for commuting to work,
    hiking, camping, hunting, fishing, etc.
    unstpible likes this.
  17. Aug 31, 2024 at 11:49 AM
    #1497
    seefnords
    seefnords New Member
    I'm on my 3rd 200k Toyota now - had a 98 T100 that made it to ~205k around ten years ago, sold it when I moved and had 50 mile each way parkway commute. Drove an impreza for a couple years until I moved within a mile of the job and went back to a truck. My '99 xcab gold Taco was around 210k when a tree fell on it while I was driving home a couple years back. Weirdest thing that ever happened to me... it was a clear, calm night and out of nowhere a ~6" diameter maple landed on the hood at 40 MPH, rolled right over the roof and off the back. Drove the truck home but the insurance company totaled it for all the body damage. Bought my '02 double cab right after that, was at 208k 3 years ago, about to hit 240.
  18. Sep 6, 2024 at 3:26 PM
    #1498
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    How do you like it so far?
  19. Sep 6, 2024 at 5:06 PM
    #1499
    nbscooters
    nbscooters Member
    Socal
    @AW11 Best upgrade ever
  20. Sep 9, 2024 at 8:48 AM
    #1500
    KevinK121
    KevinK121 Member
    Kevin
    97 tacoma. 2.4 rwd drift truck in progress.
    455278496_10233206524124240_414652459372_f140296fa129187ac1a7e0ea4e9b7c119b897c85.jpg
    250k last year :cool:
    just now saw the thread
    Dan_Does_Nothing likes this.
