200,000 Mile Club (1st Gen Tacomas)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Elmo P Moose, Sep 9, 2010.
  1. Sep 14, 2024 at 12:01 AM
    #1501
    Plumcrazy440
    Plumcrazy440 New Member
    Michael
    Florida
    2016 Barcelona Red Metallic Tacoma SR5
    Tacoma extreme weather floor covers, Tonneau cover, hood deflector, vent visors on all four windows, Running Boards
    Took over my wife's 2004 Taco with 196,000 miles on it. Runs great, normal things, had to replace AC components and heater core. Steering linkage. Now looking at timing belt, have been advised to replace water pump at the same time. Also, looking at replacing shocks and struts since they have never been replaced. Someone suggested using Pre Runner struts because I have a four door and they are heavier than a regular cab?
  2. Oct 15, 2024 at 5:51 PM
    #1502
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
  3. Oct 15, 2024 at 9:41 PM
    #1503
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    IMG_20241015_135916.jpgright there with you!
    Black97v6MT and TeeYoda[QUOTED] like this.
  4. Oct 16, 2024 at 11:23 AM
    #1504
    lucasjohnson0809
    lucasjohnson0809 New Member
    1998 White Tacoma SR5 V6
    Bilstein 4600s
    My baby Fishstick runs great after 203k ish miles. Shifts are smooth, and the only problems I've had were dealing with the suspension (last owner REALLY took bad care of it.), and even then it was relatively easy to replace. I even ended up accidentally dropping the thing off the jack while working on the suspension, and it slid about 6 to 8 feet on the rear brakes - 0 issue. We replaced the clutch too, just because we didn't want to have to do it down the line, and honestly we didn't probably need to. Overall the old tacos still run well after 200k. I would go for it! Some of them need love, but it'll only connect you more with the truck.
  5. Jan 7, 2025 at 3:39 PM
    #1505
    rdnck1
    rdnck1 New Member
    Over 460k 2001 S-Runner
    DarkWoods04, billybonez and unstpible like this.
  6. Feb 25, 2025 at 12:55 PM
    #1506
    billybonez
    billybonez Member
    Sacramento, CA
    2002 3.4L 5VZFE M/T 4WD XTRACAB
    380k here. Did an engine rebuild at 330K and the engine runs great.
  7. Jun 18, 2025 at 11:59 AM
    #1507
    NatesTaco
    NatesTaco New Member
    260K on a 2003 Prerunner
  8. Jun 24, 2025 at 9:57 AM
    #1508
    1kdrye
    1kdrye Kevlar
    northflorida
    99 prerunner sr5 3rz
    Stock
    220k miles on 1999 2.7 SR5 Prerunner.
  9. Jul 5, 2025 at 7:13 PM
    #1509
    Švejk
    Švejk Member
    Švejk
    2004 Burgundy Access Cab Tacoma SR5 2.7l V4 Manual
    I heard the Timing Belt Chain does not need to be replaced. You may want to check that. But, that is what was said to me.
  10. Jul 8, 2025 at 8:36 PM
    #1510
    joelrpsu
    joelrpsu Member
    Joel
    1999 Tacoma
    I have over 300.000 on my 99. The engine is still great, but I had to replace many parts and weld the frame.
  11. Jul 27, 2025 at 5:28 PM
    #1511
    Tmar04
    Tmar04 Well-Known Member
    Terry
    2004 Tacoma prerunner
    Don’t worry about mileage, rather about condition. Interior and exterior. I live in Georgia and recently bought 00 prerunner with 2.7 and AT. 370k showing and everything works.i recently took trip to Oklahoma and back .(1800 miles) used no oil, leaked no fluids . Presently 382k miles. Normal maintenance, flushed tranny with valvoline multi veh fluid. Works like a charm. Good luck
  12. Aug 1, 2025 at 8:34 AM
    #1512
    kzr750r1
    kzr750r1 New Member
    Passed Smog again after replacing the repaired and re cracked exhaust manifold. 320K on the clock. Time for a front end parts refresh, likey get the Moog kit soon. Need to find some larger rims. Tired of compromising with tire options on 15".
  13. Aug 1, 2025 at 9:36 AM
    #1513
    Tmar04
    Terry
    I did same thing on my 00 Tacoma. Bought used 16” rims n tires. Then lbj both sides. Next is brake rotors n pads. Got 382k showing on orig 2.7. Changed head gasket at 375k using all OEM parts. Had small leak of coolant. Had head resurfaced and checked for cracks or warpage. None found. Just got back from 1800 mile trip to Oklahoma and return. No problems. Rough rider tho. Hard on 86 yr old body too. But, I heal quickly.
