200,000 miles come on in!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dogger37, Sep 25, 2011.
  1. Sep 25, 2011 at 6:48 PM
    Dogger37
    Dogger37 [OP] New Member
    Hello everyone,
    New to the board and just had a few quick questions for you experts. Just recently turned over 200,000 on my 2001 Tacoma. My radiator just started leaking and I was wondering if you guys thought that while I had it out if I should replace the AC Compressor, Water pump, alternator, and belt tensor? None of these items seem to be failing but I am just worried that there life expectancy is almost up. Also my original exhaust has just finally got a hole in it. When I am replacing it, should I replace both Cats? Do you think they will be plugged up from the miles? Thanks for all of your help !!!!
  2. Sep 25, 2011 at 7:05 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    I mean, I'm not a mechanic, but I feel like spending all that extra money while those parts are still good might just be a waste, I don't change my oil pan every oil change I do just because the trucks already set up on a life, ya know?
  3. Sep 25, 2011 at 7:50 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    If 3.4L, I'd change timing belt, waterpump, plugs, wires, air filter..etc.
    Alternator..should be fine.
    Tensioner..no point..it's fine
    Compressor is fine..I wouldn't change it till the bearings seize up in..which doubt it will.
    Cat's could be plugged, look at them when you cut old exhaust off.
    If not, then leave em if the truck still passes smog.
    Don't fix nothing that isn't broken (unless it's preventive to prevent other problems arising...I.E. broken shock, causing worn leaf springs because no dampening)
  4. Sep 25, 2011 at 8:01 PM
    Dogger37
    UndefinedTaco It has the 2.7L. Would you do everything but the belt then since it has a chain?
  5. Sep 25, 2011 at 8:03 PM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    I got this little manual saying a/c compressor should be replaced at 100k. My 2001 d/c air is getting less pressure, not less cold but just less force so i'm thinking that the compressor is messed up.
  6. Sep 25, 2011 at 8:05 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    I'd change all fluids, plugs, wires, air filter
    Clean MAF sensor, clean throttle body, replace fuel filter.
    Read FSM on how to if your unsure.
    and drive it if it's the 2.7L.
  7. Sep 25, 2011 at 8:13 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    ^^^^^this.... if its not broke don't waste your money on it. I've got 203,000 on mine and it runs like it did the day I bought it.
  8. Sep 25, 2011 at 8:19 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    +1
    especially cleaning the Throttle body. At 174K my throttle body was disgusting...And do it right and take the throttle body off the truck to clean it. You will get it much cleaner that way.
    After doing a few other things and cleaning the TB I gained 3MPG's
  9. Sep 25, 2011 at 8:28 PM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    Yeah mine was nasty as he'll at 200000. Used a toothbrush with carb cleaner to scrub it. Be careful with the gasket on the throttle body. I broke mine and had to rvt it to drive it. Lol started at 11 p.m. on a Saturday and had to make a call to chris4x4.
  10. Sep 25, 2011 at 8:43 PM
    TacoMX
    Jonathan
    Deltona, Florida
    My TB gasket flaked apart too....lol.. luckily autozone had a feltpro gasket in stock.
