2000 4 cylinder Exhaust Help!
Discussion in '4 Cylinder' started by OFFROADCARWASH, Feb 4, 2009.
  1. Feb 4, 2009 at 4:43 PM
    OFFROADCARWASH
    OFFROADCARWASH [OP] Well-Known Member
    Jacktown, Mississippi
    2000 Taco customized
    Custom badged black, 100watt LOUDSPEAKER mounted under toolbox, UWS toolbox, All terrain Tires, K&N Ram Air Intake, HUGE flood lights mounted to Tool Box, Cobra CB radio, Francis Antenna, HELLA Blue Headlights, 12 Pad LEDS in Cab lights, Husky Liners, Tinted Windows at 15%, Thrush Glass Pack (burned Out) with 4inch Tip..Remote Crank and Intry, 2 12" subs, Blacked out head lights and tail lights.
    So I went to the exhaust shop today and when I asked to get my cadalitic converter cut off he said sure man. We raise the truck up get the saw and tubing ready to reconnect to my glasspack. And :mad:....He looked and said he cannot because ther is and o2 sensor it will have nowhere to go after I cut..And if it does not read the flow coming out it will screw up my computer stuff in my truck....HELP! there has to be another way. Can I not cut an exact spot in the new tubing to put it in then weld?
    An before any of you twats start saying YOU CANT CUT YOUR CAT OFF THATS ILLEGAL BLAH BLAH BLAH THATS FEDERAL I KNOW THE LAWS!....just dont reply. there is no checks for cats here in Mississippi anywhere. so save your breath.
    Thanks, Selby:cool:
  2. Feb 4, 2009 at 4:57 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    From wat i have seen cutting off the cat and just plugging in the 02 will f**k shit up... my cousin did it to his dakota.... sounded good but he got like 6 mpg and all his sensors got all out of wack............
  3. Feb 5, 2009 at 12:05 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Like I said before, dont do it. You're not gonna get substantial gains in power and frankly, its gonna sound like shit. The only way to get around throwing a code, is adding a O2 simulator.
  4. Feb 5, 2009 at 12:28 PM
    josh3972000
    josh3972000 Well-Known Member
    kentucky
    02 dbl cab TRD
    If i was going to install exhaust on a 4 banger I would go custom from the cat back. It will save alot of headaches from throwing codes and screwed up sensors.
  5. Feb 15, 2009 at 4:26 PM
    stk
    stk New Member
    96 tacoma 4x4
    aftermarket suspension, spacers, mud dawg tires, Mud rims,
    This is Trace Mines already cut off i don't know how they did it though.
