2000 4runner. BUILT!
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by AddictedOffroad, Sep 18, 2011.
  1. Sep 18, 2011 at 7:51 AM
    AddictedOffroad
    AddictedOffroad [OP] Well-Known Member
    Windsor, CO
    2000 4runner. Linked and locked
    Would consider a trade for a buggy, or partial for tow rig/trailer setup. Or, a 4th gen 4runner with V8 and 3rd row seat.
    So, here we go. Here is the build thread. Its not the silver one at the beginning, but you can see where the black one comes into play a few pages in. http://www.pirate4x4.com/forum/showthread.php?t=803827
    Specs:
    2000 Toyota 4runner. 3.4L, Auto, 158k. 108.5" Wheel base. 23" frame height.
    It started life as a 2wd. Currently has 157,940mi on it.
    2nd gen TRD Supercharger on 3.4L with URD 7th injector kit on it. 2.2 pulley. Rig is FAST.
    Supercharger nose cone oil was just changed about 3K ago.
    Timing Belt and water pump done at 144K.
    A340 Automatic with Inchworm prerunner adapter mates to dual 2.28 gear driven Tcases. Crawl ratio is perfect with the automatic. Cases have 23 spline cromoly inputs on both cases.
    Tranny temp gauge, Boost gauge. Huge transmission cooler. Never runs warmer than 210*. Runs at 165* all day long on the trail.
    I will throw in a wide band air flow meter, that is already plumbed into the exhaust, and Autometer gas gauge for the Ford F150 tank.
    Front axle:
    66" WMS-WMS Diamond axle. 9.5" Land Cruiser center section. 5.29s, ARB Air locker. 30 Spline Longfields with Cromoly hub gears. Big 3rd gen 4runner rotors and brakes.
    Rear axle:
    64.5" Diamond Axle. Full floater. Cromoly shafts, 9.5" center section. 5.29s, ARB Air locker, Disc brake conversion
    Heavy Duty, high output, ARB Compressor and "pump it up kit" for airing up tires. It will air up the 37s from 8psi to 30psi in about 3.5 mins/tire.
    Front suspension:
    Custom 3-link with panhard. I spent no less than three months designing the suspension and getting it perfect for a dual purpose rig. The geometry is perfect IMO.
    14" 2.5" Fox Reservoir coilovers
    Ballistic 2.625" joints at the axle end
    Ballistic Poly bushings at the frame end
    Ballistic brackets used.
    Rear suspension:
    Dual triangulated 4-link. Gas tank was relocated to the rear behind the axle using an F-150 tank and sits almost flush to the frame rails. OME coils, 13" BBCS shocks from Poly Performance.
    Tires: Five 37x12.5x17 Goodyear MTRs with around 65% left mounted on Raceline Renegade Six wheels.
    Armor:
    Addicted Offroad front winch bumper with a Smittybuilt XRC8 Comp winch with synthetic rope. The winch has only been used one time to date and that was two days ago at the Jamboree to pull another rig back a few feet.
    Sliders are Addicted Offroad heavy duty sliders.
    Rear bumper is an Addicted Offroad rear. I tow my pop-up with this bumper all over Colorado. Its NOT a light pop-up. It will pull passes with ease with the supercharger even towing.
    Driveshafts are balanced and true. Pinion angles are perfect. You can run 75mph in 4wd with no vibes. None!
    This rig is the ultimate dual purpose rig. I daily drive it to and from work just about everyday. Its smooth, predictable, and the steering is tight. Its not darty at all. In fact, it drives better than my bone stock suburban does. I finished it in July of 2010 and its seen 14K put on it since then. It drives straight as an arrow down the road with one finger on the wheel at any speed. Its FAST with the supercharger and the URD 7th injector kit. The link setup also work FANTASTIC offroad. Its 100% dialed in.
    IT NEEDS NOTHING!
    Its run numerous hard trails in and around Colorado and Utah.
    Holy Cross
    Wheeler Lake
    Chinaman's Gulch
    Green Day
    Hells Revenge
    Pritchett Canyon
    and more
    There are a couple very small dings here and there and some Rocky Mountain pin striping, but the body is straight, clean, and free of rock rash. There is also no rust on this rig.
    Stereo is a Pioneer Double-Din touch screen that is Nav capable. It has an Ipod hookup and software as well. MP3, SD Card, DVD etc. Its a Pioneer AVH-3200DVD.
    Price is $22,500. Serious inquiries only. 970-420-4198
    I would not hesitate to drive it anywhere in the country.
    Its located in Windsor, CO. (about an hour north of Denver). 100% of this rig was built in my shop by me personally. The fabrication and workmanship is spot on. This is NOT a hack job build. I spared no expensive to building this rig exactly how I wanted it.
    I will include a full set of front Ballistic Joints with rebuild kits. I also have one new spare of both a LH thread and RH thread Creeper joint as spares. I also have some spare TREs and a spare steering box.
    Pics:
    Some pics on Green Day in Area BFE:
    More from other places:
    MORE PICS HERE
    Just detailed it and took a ton of pics:
    https://picasaweb.google.com/115639...authkey=Gv1sRgCNaS_oOcldC6pAE&feat=directlink
  2. Sep 18, 2011 at 2:03 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    nice rig you got there sir. just wondering how come sell such a nice rig?
  3. Sep 18, 2011 at 2:08 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    :jerkoff:
    :jerkoff:
    :drool:
    I've seen this runner around the internet, GLWT/S!
  4. Sep 18, 2011 at 2:20 PM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    that thing is sickk!!!!!
  5. Sep 18, 2011 at 2:25 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    ive watched the threads on ttora, this thing is built to perfection without sparing anything.
  6. Sep 18, 2011 at 2:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I saw this thing up in Denver a while back. By far the nicest rig I've seen in person.
  7. Sep 18, 2011 at 3:35 PM
    AddictedOffroad
    Windsor, CO
    I am only selling it because I want a plasma table for the shop, and want to build a buggy at this point.
  8. Sep 18, 2011 at 3:38 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    That runner has some SERIOUS FLEX
  9. Sep 18, 2011 at 6:12 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    VERY NICE! GLWS.
  10. Sep 20, 2011 at 8:28 PM
    AddictedOffroad
    Windsor, CO
  11. Sep 20, 2011 at 8:30 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    I WANT!!! :D
  12. Sep 23, 2011 at 9:54 AM
    AddictedOffroad
    Windsor, CO
  13. Oct 2, 2011 at 2:47 PM
    AddictedOffroad
    Windsor, CO
    Just added a tire carrier.
  14. Oct 2, 2011 at 2:50 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    BEAUTIFUL!!! GLWS
  15. Oct 2, 2011 at 8:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Holy Shit this a gorgeous 4runner...
  16. Oct 2, 2011 at 8:47 PM
    Drew5387
    Drew5387 You can't fix stupid
    Drew
    Kansas
    03 PreRunner SR5 DC Black
    Raptor Style Grill, KC Highlight Spot Beams, 2.5% Window Tint, Kenwood Touchscreen Head Unit, Train Horn, Tinted Tail Lights, Retrofit Source Projectors with Halos, BHLM, LED Fog Lights, 40" LED Light Bar, 33" Cooper STT Tires, Herculined Rocker Panels, 175+ hp in stickers
    I'm jelly...
  17. Oct 2, 2011 at 8:48 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
  18. Oct 2, 2011 at 11:31 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    this has got to be one of the meanest 4runners ive seen around.. glws!
