2000 lbs In Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Mar 15, 2013.
  1. Mar 15, 2013 at 12:47 PM
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    In case anyone wanted to know what 2k lbs looks like, here you go.
    I had to pick up some blast media (slag) and ordered 40 bags on a skid. But miscalculated the weight - assumed they were 25 lbs bags. Got there, found out they were 50 lbs bags after I saw the truck sag when they got loaded. Ooops. Well I had already bought them and I needed them so I figured here goes nothing. Drove back 18 miles on the turnpike.
    Can't say the truck took it "like a champ" because road handling was seriously compromised, but I didn't actually have any problems either. So...everything went better than expected? :cool:
    ALMOST touching bump stops. You could feel it hitting the bump stops on turns, acceleration, and big potholes.
    Don't try this at home.
  2. Mar 15, 2013 at 12:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Poor axle seals
  3. Mar 15, 2013 at 12:52 PM
    mrbadwrench
    Cleveland Ohio area
    Yes, I'm sure their life has been shortened.
  4. Mar 15, 2013 at 2:55 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    So you knew it was unsafe as soon as it was loaded and still decide to drive on public highway?? Not cool man!
  5. Mar 15, 2013 at 3:03 PM
    mrbadwrench
    Cleveland Ohio area
    Never said it was unsafe. Just bad for the truck.
  6. Mar 15, 2013 at 3:03 PM
    mrbadwrench
    Cleveland Ohio area
    No kidding!
  7. Mar 15, 2013 at 3:07 PM
    cjimenRR
    North Hollywood, Ca
    I'm no expert in car handling characteristics but there's no way you can sit there and type that it wasn't unsafe. In case of emergency braking/maneuvering the handling of truck was compromised which could have been fatal
  8. Mar 15, 2013 at 3:09 PM
    mrbadwrench
    Cleveland Ohio area
    Braking wouldnt have been compromised since the brakes are rated to handle an unbraked 3500 lbs trailer.
    Of course maneuvering is less agile but no worse than driving a motorhome or towing a large load. You lower your speed and drive more defensively to compensate.
  9. Mar 15, 2013 at 3:12 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge.
    The front tires look like they're off the ground- LOL
  10. Mar 15, 2013 at 3:14 PM
    cjimenRR
    North Hollywood, Ca
    WOW, so many things wrong with your statement! In any case kiss your lucky charm for not letting anything go wrong and I'm glad I'll never share the road with you since I'm not near your area
  11. Mar 15, 2013 at 3:18 PM
    mrbadwrench
    Cleveland Ohio area
    It's cool. You can't post rotten fruit and not expect flies.
  12. Mar 15, 2013 at 3:59 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    05 prerunner trd off road DC
    Red hot glass pack muffler dumped preaxle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front and modified zuk mod coil spring lift for about 2" in rear paired with 5100 also. C channel front bumper. Maxxis bighorn 255/85/16
    U should have went and picked up a huge load of balloons right away to offset the weight and then sell the balloons for premium and make Ur money back on everything, but hine sight is 20/20
  13. Mar 15, 2013 at 4:00 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    Firestone Ride Rite and you'd have looked like your truck thought 2000lbs was 2lbs.
  14. Mar 15, 2013 at 4:02 PM
    OZ-T
    Peter North
    British Columbia
    Poor axle seals
  15. Mar 15, 2013 at 4:09 PM
    mrbadwrench
    Cleveland Ohio area
    I knew there was a reason I should've paid attention in school.
  16. Mar 15, 2013 at 4:12 PM
    RPD STARS
    RPD STARS Turn up the good, turn down the suck!
    BC
    2010 Raptor
    Go Faster Retrozzz... Drop in Dry Flow, Blowfaster Delta 50, 315/70/17 BFG Stock Action
    I thought I was the only one that thought this...
  17. Mar 15, 2013 at 4:13 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Seriously...
  18. Mar 15, 2013 at 4:13 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I don't think its a morality police thing, just a truthful caution from people giving good advice, but you likely voided warranty in a public forum, ok with me,I wont say. But they can read.
    (remember that guy in the white truck offroad crash thing). I don't the seals are damaged, based on the axle rating on the sticker.
    Simple fact in a crash involving that weight, police and insurance ... lawyers too I bet , they find out real fast you exceeded weight. Suddenly you start assuming blame, just best not to place yourself there.
  19. Mar 15, 2013 at 4:18 PM
    mrbadwrench
    Cleveland Ohio area
    Out of curiosity, what IS the axle's rating?
  20. Mar 15, 2013 at 4:19 PM
    mrbadwrench
    Cleveland Ohio area
    truck is already out of warranty anyways.
