2000 lbs In Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Mar 15, 2013.
  1. Mar 16, 2013 at 12:28 AM
    #61
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya... Pinal is the poster boy for the LEO section.
  2. Mar 16, 2013 at 12:52 AM
    #62
    Rich91710
    Rich
    Los Angeles
    08 Base
  3. Mar 16, 2013 at 12:55 AM
    #63
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Haha
  4. Mar 16, 2013 at 5:49 AM
    #64
    acdronin
    acdronin Well-Known Member
    LOL
  5. Mar 16, 2013 at 5:50 AM
    #65
    acdronin
    :p no such thing as bad press right?
  6. Mar 16, 2013 at 7:11 AM
    #66
    fireroad
    fireroad Well-Known Member
    McCall, ID
    Just making sure you were paying attention...
  7. Mar 16, 2013 at 11:04 AM
    #67
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    I have the 3 leaf springs.
    But you're making an apples to llamas comparison.
    The worst choice for hauling with these trucks is a double cab. Best choice is a regular cab.
    Reason is that as you add cab between the front axle and the back axle, you push the bed (load area) further away from the front axle. As you do this, you reduce the percentage of the load that the front axle handles. Thus, you are actually increasing the amount of load the back axle handles.
    Ergo, with equal loads and equal spring packs in a double cab and a regular cab, the double cab will always sag more.
  8. Mar 16, 2013 at 11:22 AM
    #68
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Watching Goldfinger and they just crushed a 5,500 pound Lincoln Continental and dropped it into a '64 Ranchero. I think 2000 lbs in a Tacoma should be no problem then.
  9. Mar 16, 2013 at 12:18 PM
    #69
    Rich91710
    Rich
    Los Angeles
    08 Base
    And in this case, like fuel economy and unlike snow, the Prerunner is better than the 4x4 because of it's higher cargo carrying capacity.
  10. Mar 16, 2013 at 12:22 PM
    #70
    Rich91710
    Rich
    Los Angeles
    08 Base
    Dukes of Hazzard used to jump the General Lee too.
    There was a movement persuading owners to refuse to sell their '68 and '69 Chargers to the studio. Somewhere between 250 and 350 of these now-valuable cars were destroyed making that series.
  11. Mar 16, 2013 at 12:40 PM
    #71
    Yoshio
    Yoshio Well-Known Member
    Scott
    Central Coast, CA
    2007 SW 2.7L 4x4 SR5
    Double Cab Step Tubes, 35% Tint Front Windows, Husky Mud Flaps, Illuminated 4x4 Switch, Debadged, DEPO LED tailights, Undercover SE Tonneau Cover, Panavise In-Dash Mount, Plasti-Dipped Front Bumper Lip, OEM Front Fogs, Rear Fog Lamp, LEDs throughout, Door Sill Protectors, Color Matched Satoshi, Rear Window Security Bar, ImMrYo Rear Mirror Bracket, Added factory DTRLs & DTRL kill switch, Rear Diff Breather Mod, 17" FJ Alloy Rims, Sport shocks coils leafs, DEPO black headlights, off-road recovery hook, skid plate, BT-35 TOY Bluetooth kit
    Aww, you just ruined goldfinger for me... other than a 300 lbs man getting sucked through a broken airplane window and coming out on the other side unharmed...
  12. Mar 16, 2013 at 12:43 PM
    #72
    worthywads
    Unfortunately a 318 '69 Charger could be had in usable but rusty shape for less than $1000 back then. While a terrible waste, they did make over 90,000 69 Chargers.
  13. Mar 16, 2013 at 12:49 PM
    #73
    Rich91710
    Rich
    Los Angeles
    08 Base
    The studio paid the family doing the mods $2k per when they were deemed no longer usable (plus $250/wk rental).
    I'm sure the most desirable cars were spared and not sold to the studio, likely in part as you said, the 318 "Base models" would be cheaper than the nicer models or those with the 383 and 440.
  14. Mar 16, 2013 at 9:36 PM
    #74
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    The captions for the below pics:
    "In Afghanistan, overloading trucks is encouraged by the safety people.."
    "Access Cab Tacomas have no upper weight limit.."
    "You are a wuss for not overloading your truck.. Fine, I'll do it with my Jetta!"
    "My Ute has a WAY stronger axle than your Tacoma!"
    :burnrubber:
    Alexely999 likes this.
  15. May 24, 2021 at 5:03 AM
    #75
    Zjoz78
    Zjoz78 New Member
    Zach
    2016 v6 Tacoma access cab
    None
    So I am going and picking up 2b limestone and a yard weighs about 2000 pounds this is most likely a one time thing but I did have 1500 pounds or rubber mats in the back and my rear barely moved down should I go for it?
  16. May 24, 2021 at 6:47 AM
    #76
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Here’s about 2,200lbs :anonymous:
    anyone asking “can I do it?” “Should I do it?”
    DONT DO IT. I’ve learned since then. I was also in my 20s at the time, and was pressured by my boss.
    Either make 2 trips, or use a trailer.
  17. May 24, 2021 at 7:04 AM
    #77
    ColoradoTJ
    ColoradoTJ I drink, and I know things… Moderator
    Looks like Alaska
    POS Jeep
    No. Make a few trips.
