2000 SR5 smokes terribly on start up
Discussion in '1st Gen. Tacomas (1995-2004)' started by MR Derick, Oct 14, 2020.
  1. Oct 17, 2020 at 3:27 PM
    #41
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Yeah, this is what I did since the "New" one I purchased from RockAuto was defective and causing blow by in the motor. New one came from Toyota Dealership and in my particular case it resolved the issue.
  2. Oct 17, 2020 at 6:03 PM
    #42
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    I always ask the same ‘ Basic ‘ questions
    year/ model taco
    mileage !!!!!!!
    type o driving ( commuter bump/grind .......excessive idling )
    Ur truck has age........not that many miles
    that much water in a cylinder could result in a ‘ wet ‘ cylinder or a cylinder that would ‘ hydraulic ‘
    i doubt it would actually fire with that much water
    its possible as a few have mentioned the valve ‘ seals ‘ are leaking
    unusal for the miles
    maybe for the age which leads me to to ‘ environs ‘
    why so few miles in 21 years ???????
    pull the spark plugs..................keep them in order.................Do NOT jumble them up
    take good close photos
    do a compression / leak down test
  3. Oct 17, 2020 at 6:11 PM
    #43
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Where's the water coming from? He said the coolant level doesn't budge
  4. Oct 17, 2020 at 6:18 PM
    #44
    ROAD DOG
    FEW
    everyone is lookin for the origin of the water
    mixing oil/water NO way he can tell water level the same
    to answer Ur ?
    he’s pissin in his radiator !!!
    until he does a compression + leak down
    NO 1 WILL KNOW !!
  5. Oct 17, 2020 at 6:29 PM
    #45
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If PO neglected oil changes severely, the baffles in the top of valve covers could have gotten sludged up to the point a new PCV will never do it's job and in fact could sludge the rings closed.
    This was a design flaw of the early Camry 3.0 engine in that it happened easily but really, could happen to anything. further hampering would be if they neglected plugs too.
  6. Oct 21, 2020 at 12:10 AM
    #46
    MR Derick
    MR Derick [OP] Member
    Derick
    2000 Toyota SR5 6cyl auto
    None
    Good idea, any takers?
  7. Nov 26, 2020 at 4:01 PM
    #47
    MR Derick
    Derick
    None
    I put in a Toyota PCV valve and new grommet. It appears something is working I have less smoke but it still smokes on start up for about five seconds to 10 seconds
  8. Nov 26, 2020 at 7:18 PM
    #48
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Well. Your valve stem seals are 20 yrs. old
    We can't feel bad, you used to be doing good to get 10 out of them.
    edit: Didn't read whole thread again. So did oil consumption slow? Did you check rings with compression test?
  9. Nov 27, 2020 at 4:56 AM
    #49
    Thomas670
    Thomas670 Well-Known Member
    2002 Taco Regular 5 speed
    Yes the best option to do is a compression test. Psi for each spark plug should be 127-178 psi if im not mistaken
