2000 Tacoma Driveshaft
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000GTacoma, Dec 22, 2011.
  1. Dec 22, 2011 at 3:02 PM
    2000GTacoma
    2000GTacoma [OP] Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    So for a few months I had a vibration in my truck that began to get worse and worse. I didn't know exactly what was causing it until I came across a thread about greasing the double cardan joint. I had never seen the grease zurk and was not aware it could be greased. Called a reputable drivetrain shop and the guy said some can be rebuilt some cannot. I took it off my truck and took it to him. He said it cannot be rebuilt and my only options are to buy a new from toyota or find a used one or he could order one and build it to be easily serviced. He quoted 600. :eek: Toyota wants over 900 and I can not service it. Can anyone offer any help? I have a 2000 Tacoma extended cab. 4x4 non trd with the 3.4L v6
  2. Dec 22, 2011 at 5:17 PM
    2000GTacoma
    Snow Hill NC
  3. Dec 22, 2011 at 5:19 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    call Tom woods driveshafts
  4. Dec 22, 2011 at 5:21 PM
    2000GTacoma
    Snow Hill NC
    i did but im not sure i want to go that route. i have to measure and then if its not right its my problem and i just would rather have something tried and true i guess.
  5. Dec 22, 2011 at 6:10 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Try the scrap yards.
  6. Dec 22, 2011 at 6:24 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
  7. Dec 22, 2011 at 6:43 PM
    2000GTacoma
    Snow Hill NC
    can metal craft out of goldsboro rebuild the double cardan joint? heavyduty powertrain in wilson nc said it was a no go
  8. Dec 22, 2011 at 6:45 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    ask them
  9. Dec 22, 2011 at 6:46 PM
    2000GTacoma
    Snow Hill NC
    10-4
  10. Dec 22, 2011 at 10:05 PM
    2000GTacoma
    Snow Hill NC
  11. Dec 22, 2011 at 11:09 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    well...first you have to find out if the double cardigan joint is even the problem. If there is no detectable play in the Double cardigan joints, they are probably fine. But I guess because you took it to a driveline shop that it is worn out? Take it to a different shop and see, as anything can be rebuilt if you have a tech that knows what he is doing.
    It could also be the two other U-joints on the shaft, or the carrier bearing.
  12. Dec 22, 2011 at 11:48 PM
    glamis3000
    glamis3000 Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    my mechanic just replaced my center and rear u joints in my driveshaft cost me me about 380 dollars.. if you want his info i can get it for you..
  13. Dec 23, 2011 at 8:21 AM
    2000GTacoma
    Snow Hill NC
    yes that is my problem. greased it and vibs amost stopped but still somewhat there and i want to fix it
  14. Dec 23, 2011 at 8:21 AM
    2000GTacoma
    Snow Hill NC
    maybe we have a different style joint. ive had 2 shops tell me it cannot be rebuilt
  15. Dec 23, 2011 at 8:24 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    didja call them?
  16. Dec 23, 2011 at 8:26 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    also try calling down east offroad in wilson, they do good work and are pretty cheap from what ive heard
  17. Dec 23, 2011 at 10:51 AM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I wish i had a driveshaft problem.
    Tom Woods is 15 minutes away.
  18. Dec 23, 2011 at 1:07 PM
    2000GTacoma
    Snow Hill NC
    called them and took the rear half of it over to them. said the cv feels good but he wants me to bring the other half of the shaft and he spin it up on the balancing machine to see if he can detect any vibrations. so im going to start from there. he said my style can be rebuilt and he can do it. heavy duty powertrain in wilson told me yesterday that it can not be rebuilt. so im going to take the entire shaft to him let him spin it up but i still think the center bearing needs replacing.i had really bad vibrations then i learned it could be greased and the vibs almost stopped. at certain speeds it still vibs though we will see. thanks for the info though
  19. Dec 23, 2011 at 1:08 PM
    2000GTacoma
    Snow Hill NC
    they said they could build me one for less than 500 but id rather not go that route
