2000 Tires and Door plate
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChesterTacoma, Sep 22, 2009.
  1. Sep 22, 2009 at 7:51 PM
    ChesterTacoma
    ChesterTacoma [OP] Member
    2000 4x4 Manual Reg Cab
    Just got a 2000 Tacoma 4x4 and the door plate shows 225/75r15 as the tire size.
    Current tires
    Front 265/75r15 Wild Country XTX
    Back 265/75r15 Goodyear Fortera
    I know the 2000 had a larger tire option, but would the door show the original tire size?
    I'm considering getting 225/75r15 Firestone Destination A/T, would they provide better wet and snow traction then the larger tires?
    Thanks.
  2. Sep 22, 2009 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    Generally, the door plate only lists the standard tire the vehicle comes with. It doesnt list the optional size. Personally, I would stick with the 265/75/15 size. :)
  3. Sep 22, 2009 at 8:20 PM
    ChesterTacoma
    There isn't as many options in 265s. I might replace the Goodyear Fortera with Wrangler SilentArmor.
  4. Sep 22, 2009 at 9:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A 31/10.50/15 is the same as a 265/75/15....You may want to check that size.
  5. Sep 22, 2009 at 10:10 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I've got a stock 2000 4x w/ 32"x11.50x15" BFG A/T's, no problems hitting innerwell unless offroading in a turn & hitting a rock or rut,etc; but haven't kissed it really hard yet....:cool:
  6. Sep 23, 2009 at 3:27 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    I have a 2000 Xtra cab, 4x4 and the stock tires are 31x10.50x15. I'll be replacing them with 32x11.50x15 in a month or two.
  7. Sep 23, 2009 at 12:26 PM
    ChesterTacoma
    Thanks. Now its time to fix the squeaky clutch...
  8. Sep 30, 2009 at 3:44 PM
    ChesterTacoma
    How would I know the recommened tire pressure if the size is different from the door plate?
    Anyone running 265/75/15, what's your PSI?
