2000 to 2001 Box/door swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by ghs57, Jul 27, 2010.
  1. Jul 27, 2010 at 10:25 AM
    ghs57
    ghs57 [OP] Well-Known Member
    Chops
    Catskill Mts. NY
    '03 Black SR5 xtracab 2.7L 4WD
    Pretty much stock with a small lift and Timbrens
    Hi,
    Anyone know if the pick-up box from a 2000 4wd xtra cab can be swapped with a 2001 same model? How about doors?
    My 2000 is going bye-bye due to frame rust, but the body parts are better than the ones on the 2001 I just bought. The hood looks different due to the grille change, or I'd swap that too.
    Thanks!
  2. Jul 27, 2010 at 3:57 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Yeah shouldn't be a problem. The door might be hard if you have power anything.
  3. Jul 27, 2010 at 6:59 PM
    ghs57
    Chops
    Catskill Mts. NY
    '00 has power everything, '01 power nothing. Plus the '00 door has corrosion across the bottom inside I did not see before. The '01 doesn't, but it has a kink in the window frame from a accident (which was straitened out, sort of) which hangs up the window. I'm thinking not worth all the work for damaged goods.
    As for the box, I thought the frame might be slightly different due to Toyota not rebuilding pre '01s. The told me they can get frames for '01s but not earlier. Still, I would have to paint to match.
  4. Jul 27, 2010 at 7:05 PM
    RAT PRODUCTS
    Farmington, MN
    Yeah, you might be better off just getting the truck fixed and repainted at a body shop. Or turn it into a trail rig and not give a shit what it looks like.
