2000 Toyota Tacoma 3.4 V6 failed NOx GPM emission test
Discussion in '1st Gen. Tacomas (1995-2004)' started by 00toytaco, May 1, 2013.
  1. May 11, 2013 at 2:10 PM
    #41
    00toytaco
    00toytaco [OP] Well-Known Member
    Joshua
    Loveland, CO
    00' Tacoma SR5 w/TRD V6 4x4
    Home made intake system (need to get the right system), Rancho rear shocks, kyb front struts, 3 inch lift, brushguard, home made grille, Dual led 6.5" speakers, 12" JL Audio sub.
    I have one cat which was replaced in 08 or 09 by a shop. Fuel filter could a replacement i did replace it once few years ago. o2 sensors are stock which the one behind the cat i will have to replace soon cause of the wire. The thermostat was replaced (stupid location if you ask me) probably 2 years ago. Also thermostat degrees at autozone are all 180's. Will check it out and see what a shop says. Any info on good shops will be helpful.
  2. Jun 26, 2013 at 7:22 PM
    #42
    00toytaco
    Joshua
    Loveland, CO
    After all that work finally passing emissions. Failed 3 times and passed today. NOx is 1.4910. I had to redo the intake system, replace catalytic converter, replace spark plugs with NGK V-Power, fuel filter, run seafoam through the intake, gas, and oil, oil and filter change...I think that's all could be more. Did good all the way to my camping spot the other day so should be good.
  3. Jun 26, 2013 at 7:28 PM
    #43
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Excellent.
