2000 Turbo Taco - Race Truck Edition, to include wannabe fabricator and machinist stuff(PIC HEAVY!!)
Discussion in 'Street Trucks' started by Murd3rd, Mar 24, 2023.
  1. Mar 29, 2023 at 6:26 PM
    Icecoast
    Icecoast Active Member
    IMO since your playing around with delrin I would get a boring bar and play around with it. It's a good opportunity to learn what you and your machine are capable of.
    Murd3rd[OP] likes this.
  2. Mar 29, 2023 at 6:29 PM
    Murd3rd
    Murd3rd [OP] I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    I think that'll be the plan, boring bars are really expensive from what I've been able to find so far. :eek:
  3. Mar 29, 2023 at 6:38 PM
    Icecoast
    don't buy a "true" boring bar until you know you're going to use it.
    https://www.mcmaster.com/3301A91/
    something like this will get you turning but might not last long in harder materials.
  4. Mar 29, 2023 at 6:42 PM
    Murd3rd
    Oh I'm sticking with cheap eBay stuff for now. Lol. I'm not trying to invest thousands into that hobby since I currently have a small hobbyist grade lathe that was less than 500 bucks on eBay just to learn some basics.
  5. Mar 30, 2023 at 10:29 PM
    Murd3rd
    I tacked up some rockers for the cantilever system today. Not quite sure I like how they turned out. I'd like them a bit shorter, and maybe a wider angle. Gunna cut the rod ends off tomorrow and shorten them and see how I like that before scrapping them for a new design.
    PXL_20230330_164645440.jpg PXL_20230330_173709933.jpg PXL_20230330_174427003.jpg
    Update: I chopped em by around 2 inches.
    Steves104x4, EdgemanVA and BananaMan like this.
  6. Mar 31, 2023 at 10:12 AM
    Murd3rd
    I've gotta make some mount tabs for the bottom of the shocks because I screwed up and didn't order enough. But here is the vision so far. The push rods on the axle will be a short piece of dom tube with threaded rod ends on either end(1 left hand and 1 right hand threads), just like the 4-link links. That way you can adjust ride height with either the coilovers or the push rod from the axle to rocker arm.
  7. Mar 31, 2023 at 10:37 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    I'd almost think you might want more of 1.5:1 or 2:1 ratio out of the cantilever to take advantage of more of the shock travel since you're probably don't need much suspension travel. I could be wrong since I don't actually know how much suspension travel you use, the spring rates or event he shock length. So basically spit balling here.
    Absolutely great work on everything though.
    Steves104x4 and Murd3rd[OP] like this.
  8. Mar 31, 2023 at 10:48 AM
    Murd3rd
    The rocker ratio was a factor in determining the right shock length. I tried to keep it simple since I'm still learning this. But, I'm now wishing I would have gotten the longest ones they made in this type. Then a different ratio would have been beneficial. This particular shock length is 14 inches fully extended and 10 inches compressed and a recommended ride height of 12 inches +/-. I highly doubt I'll ever see 2 inches of suspension droop unless it's being jacked up or something. Even with the leaf springs I don't think the suspension dropped more than an inch and a half or so, but I never really measured it.
    I am thinking about making the rockers with adjustable holes in them, so you can move either the push rod and\or the shock to a different hole which would change the ratio. But who knows, this may dial in and work well for my needs. The good news is I have plenty of 3\16 steel sheet and can whip these up in basically any shape I want as long as I want to do the labor. This may evolve and change as time goes, much like any other project I guess. Lol
    One thing I'm trying very hard stay conscious of is the max shock travel in either direction. I believe that my front shocks failed prematurely (even though they are 11+ years old) because anytime I jacked the truck up they would be the limiting factor when the front tires were hanging by their own weight. This was a recently learned thing with the QA1 conversion in the front. So I intend on steeling an idea out of the off-road\pre-runner book and putting a limit strap of sorts on the rear axle, or maybe some sort of bump stop on the rocker that would rest on the frame in order to keep the shock from ever fully extending when the truck is lifted by the frame. And of course do some measuring and coming up with a better limiter in the front as well. The previous owner put slim bumps on the front control arms and while that's good for up travel (I don't think I ever bottom them out on compression) it isn't good for down travel, mainly when the truck is suspended in the air, especially with the wheels and tires installed.
    BananaMan likes this.
  9. Mar 31, 2023 at 11:12 AM
    gstodd
    2005 2wd base 5-lug
    Sounds like how you have it set up will work quite well. And like you said it's just a matter of fabricating new brackets if you do feel it needs changing.
    BananaMan and Murd3rd[OP] like this.
  10. Mar 31, 2023 at 1:45 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I'm not sure how much droop you would achieve, but I know with my truck I experience a good amount of droop in the turns. I know it's hard to really tell for certain, but sitting static, these tires are flush/barely tucking inside the fenders.
    Murd3rd[QUOTED][OP] likes this.
  11. Mar 31, 2023 at 1:48 PM
    Murd3rd
    I've got some GoPro footage somewhere that shows my rear wheel-wells during an autocross event. The amount of body roll I have is very little. It seemed that my suspension would compress a decent amount, but would not extend all that much. I'll have to watch the vids again and see just how much it's moving. It's been a while. Lol
    But I also have a rear sway bar, I don't think you do yet do you @BananaMan ?
  12. Mar 31, 2023 at 1:50 PM
    BananaMan
    I'll have to try and do that same shot this year. I just got offered an entire 350z rear subframe assembly for a couple hundred bucks, the struts, diff, axles, everything. I'm now toying with the idea of 350z swapping my rear suspension to go IRS.
  13. Mar 31, 2023 at 1:51 PM
    Murd3rd
    Hell yeah! That'd be pretty dope.
    BananaMan[QUOTED] likes this.
  14. Mar 31, 2023 at 1:53 PM
    BananaMan
    It would, but I'm really digging your cantilever setup. Lots of fab work either way.
  15. Mar 31, 2023 at 2:44 PM
    #35
    Murd3rd
    Tell me you've seen the Aussie Hilux drift ute? He's running pretty much all Nissan suspension\drivetrain from a 240 I think? Or maybe there's an Aussie version that's different, idk. Sad that it's not at least *mostly* Toyota, but it's not even a truck in any way other than basic shape anymore. Lol
  16. Mar 31, 2023 at 4:02 PM
    #36
    BananaMan
    Yeah I've seen it, it's rowdy! I like that mine is mostly Toyota, but anyone trying to be competitive in track/autocross knows that a watts link for mustangs, or IRS swap is the way to go for most rwd vehicles.
  17. Mar 31, 2023 at 5:29 PM
    #37
    Murd3rd
    Yeah, I can agree with that. Just wish he could've found some Toyota running gear, and the engine that was in the Hilux is perfectly capable of creating great power, just like the SR20
  18. Apr 1, 2023 at 10:03 PM
    #38
    Murd3rd
    Did some late night fab work today. Got all of the cantilever stuff tacked in to see how it would all work together...aaaaaaaaaaaand I have to redesign the rockers. They're too short. When the suspension is compressed it's on the teetering edge of knuckling over on itself. I think I'm also going to play around with an offset ratio, not real sure yet. There is definitely more learning to do, but I ain't even mad, I'm lovin' it!
    PXL_20230402_021528827.jpg PXL_20230402_021537255.jpg PXL_20230402_021607365.jpg PXL_20230402_040219194.jpg PXL_20230402_040505305.jpg PXL_20230402_040516740.jpg PXL_20230402_040529671.jpg PXL_20230402_040555105.jpg
    Tatts521, EdgemanVA, hemitruk and 2 others like this.
  19. Apr 7, 2023 at 10:33 AM
    #39
    2Runner
    2Runner Well-Known Member
    Scott
    So Cal
    2002 Regular Cab 2.4L MT 2WD
    This is really coming along, great work!! :thumbsup:
  20. May 3, 2023 at 11:34 AM
    #40
    Murd3rd
    Wow, it's been over a month since I've worked on this thing.
    Had another project pop up that the wife really wanted to get started on. We have 11 chickens, with 4 of them being chicks that we just got about 2 weeks ago. Our old chicken coop was basically falling apart, but it was part of the deal when I got the original set of chickens from a friend, so we used it until we finally committed to building a better one for them. I wont go too in depth on this thing, but just so you can see what my time has been going toward recently. Lol
    Now, back to what we're really all here for!:D
    I did some boxing of the open ends in the crossmember today. I've been thinking a lot about the rockers for the cantilevers and I've really gotta calculate some stuff to make a better attempt. Gotta remember that I'm learning this as I go, so it's A LOT of trial and error. ;)
