2000lbs of river rock in bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AFZ, May 30, 2013.
  1. May 30, 2013 at 7:14 PM
    #41
    SWCB
    SWCB I'd rather be fishing..
    james
    The Bayou, AL
    2012 Tacoma DCSB 4x4
    Debadged Future mods OME or FOX lift TRD CAI TRD exhaust TRD super charger Homer taco satoshi!!
    Fixed.
    Got to do what ya got to do. Didn't go fast, didn't horse the truck. no leaks, no squeaks.
  2. May 30, 2013 at 7:15 PM
    #42
    SWCB
    james
    The Bayou, AL
    Had 1/2 inch of tire clearance in the back
  3. May 30, 2013 at 7:42 PM
    #43
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    NO! LOL
    OP, rent a trailer or get it delivered
  4. May 30, 2013 at 7:48 PM
    #44
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    1650 lb.seems like you estimated your base payload high, an AC is more like 1400 iirc. Even so you still need to subtract your weight n fuel, so its likely more like 1250lb +/-.
    So I guess the answer is the obvious "you shouldn't" , but I bet you will.:D
    I might not break anything, just don't be surprised if it does.
  5. May 30, 2013 at 8:07 PM
    #45
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    FUFY
    Make 2 trips or pay for delivery
  6. May 30, 2013 at 8:48 PM
    #46
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    is overloading your truck a dot violation? I would pay an extra fee and have it delivered.
    $30k truck vs $50 (possibly) delivery fee.
  7. May 30, 2013 at 8:55 PM
    #47
    TanaTaco
    TanaTaco Well-Known Member
    James
    Montana
    05 TRD Offroad 4x4
    OME complete kit with dakars, LR UCAs, Seat covers, weathertechs, anytime foglight mod, ABS kill switch, locker anytime mod, powered sub, halos, leer topper, aux/ipod hookup.
    :eek: Now thats ballsy!
  8. May 30, 2013 at 8:56 PM
    #48
    OZ-T
    Peter North
    British Columbia
    I already said that
  9. May 30, 2013 at 9:00 PM
    #49
    TanaTaco
    James
    Montana
    05 TRD Offroad 4x4
    Nice...
  10. May 30, 2013 at 9:05 PM
    #50
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
  11. May 30, 2013 at 9:07 PM
    #51
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    do not know how much weight I was carrying. had 8 antelope quartered up in big coolers on ice, camping gear and 3 guys on board and blew out my shocks. I have the toytec aal's, payload includes persons on board and gas so it is not what advertised. I wouldn't do it, seen axle tubes bend from too much weight.
  12. May 30, 2013 at 9:21 PM
    #52
    Tacoyota
    08 4wd
    I don't think they mean to be deceptive in advertising , they all do it .. say "1300 lb payload" they mean any weight added whatsoever, we often think " oh , cargo".
    I scaled mine with a full tank that way I know what's left.
    Too bad feds didn't make them all go by a standard, perhaps one of full tank, a 180 lb and a 120lb passengers, so they all compared the same. Suddenly 1350 would be 900lb on a level compare.
  13. May 30, 2013 at 10:16 PM
    #53
    ChiveOn
    A BC Boy in Calgary
    FUFY? I just Googled this and all the results were about puppies, kittens, and this....
    Anyways, when it comes to Toyota they knows what they are doing when they say the limit is this.... Also if your over loaded in the rear wouldn't/couldn't you lose some turning ability as your front would start to lift? I swear I've seen some old trucks over loaded with this happen
  14. May 30, 2013 at 10:22 PM
    #54
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Haha, nice transition.
  15. May 30, 2013 at 10:27 PM
    #55
    joes06tacoma
    Joe
    Central Coast, CA
    Yep, get a rental trailer and abuse that. No sense in abusing your truck and risking possible damage, possibly causing a wreck, getting sued, etc.
  16. May 31, 2013 at 4:14 AM
    #56
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Only because the truck was sitting on the frame and could not go any further.
  17. May 31, 2013 at 4:24 AM
    #57
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    Tow trailer or delivery, don't take a chance. $100 max for either, much more damage can be done if you throw it in the bed. Scratches, spring, shock, seals, etc., can be expensive.
  18. May 31, 2013 at 4:27 AM
    #58
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I am sure it would do it. But why would you want to. Make two trips and eliminate any questions
  19. May 31, 2013 at 4:44 AM
    #59
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    thinking to myself, front loader full of river rocks, ain't no way I am dumping said load in bed, especially 2000#'s +....
    even with the plywood, there will be distortions to the bed itself.....check the vertical side clearance tailgate edge to bed edge, probably will be a bit off when you get done....
    I personally would abuse a rented trailer....
    good luck....
  20. May 31, 2013 at 5:01 AM
    #60
    acdronin
    acdronin Well-Known Member
    40 bags of 60 pound concrete plus rack, shell, two passengers and fuel, probably 3200-3350
    one yard of gravel plus ten bags of rock, with everything, probably 4000 pounds
    With the right mods it can, but i don not recommend trying this at all, if you don't upgrade the brakes you are a danger to others on the road, just do two loads or better yet, like the other posters said, just get it delivered.
