2000Taco 2.7 fuel filter replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigrooster, Mar 26, 2011.
  1. Mar 26, 2011 at 8:42 PM
    bigrooster
    bigrooster [OP] Member
    frank
    FC
    00 taco ext sr5 Blue
    where is the fuel filter located and how hard is it to replace?
  2. Mar 27, 2011 at 11:20 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    under the manifold...its a bitch ti get to it WILL be an all day project.
  3. Mar 27, 2011 at 12:07 PM
    02tacoma2.7
    02tacoma2.7 Well-Known Member
    Barrett
    Albany, Ky
    02 tacoma 2.7 4x4
    K&N cold air Eagle 102 15x10 wheels 31x10.50x15 Cooper STT Line-X rocker planels Window Tint
    ^what he said.
  4. Mar 27, 2011 at 3:34 PM
    JohnnYp
    JohnnYp Member
    Arizona
    98 SR5
    throttle body spacer k&N cold air intake stage 2 clutch kit Gibson cat back exhaust kit bed liner and rocker panel lined
    you can try jackin up the driver side and takin the driver side front wheel off take off the lil rubber flapper in the wheel well and go in through there thats how i did mine beats taken the intake out lol
  5. Mar 27, 2011 at 5:25 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Looks like somebody needs to make a HOW TO video!!!!
    Hey........ I have a 2.7 and no idea when my fuel filter was changed. I also have a video camera.
    Now if I could just get some nice weather I might be on to something.:D
  6. Mar 27, 2011 at 8:09 PM
    bigrooster
    frank
    FC
    any pictures would be good.
  7. Mar 28, 2011 at 5:02 AM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    From all that I have read it looks like the 2.7 fuel filter is in a really hard to get to location.
    They say the best way to get to it is to jack up the drivers side and go through the fender well.
    Here is a link to a good write up on the 3.4 fuel filter. Doesn't help in this situation but has some good general fuel filter removal tips that might apply.
    http://www.customtacos.com/tech/index.php?article=175
    Here is a schematic of where the fuel filter is supposed to be located on the 2.7.
  8. Mar 30, 2011 at 10:05 AM
    motoedde
    motoedde Member
    Edde
    Philly, PA
    '96 Tacoma 4x4 2.7L shortie
    I did mine with some ratchet extensions...was a PITA to put back on. I sincerely have thoughts about relocating the filter to a different location for the next change.
    Anybody have thoughts on that? The genuine Toyota filter comes with mounting bracket anyways!?!?
  9. Apr 3, 2011 at 6:36 PM
    Tennessee01Tacoma
    Tennessee01Tacoma Member
    Jerry
    Joyner/Windrock, TN
    01 Taco 2.7 4x4 5100's
    Bilstein 5100 and top gun customz shackles
    I have replaced the fuel filter on my truck its a 2001 xtra-cab 4x4 with the 2.7. You have to remove in a certain order.
    Step 1. Loosen the lines its like a 12mm I used a line wrench but you can use a boxed end wrench or socket.
    Step 2. Remove the 2 bracket bolts the top one is fairly easy the bottom one you will probably have to go through the fender and unless you have a lift on you will have to remove the tire. After you remove the bracket bolts you can pull the filter and bracket out together and then you have to remove the bracket which is only one bolt and then reassemble
    It took me about 3 hours now I could probably do it in half the time.
  10. May 3, 2011 at 10:29 PM
    flynhighaf23
    flynhighaf23 Active Member
    Albuquerque, NM
    95.5 SR5 V6 TACO
    05 Rims K&N Intake
    okay, i just wanna bitch about what a PITA it is to change this fuel filter compared to the v6 model. what effing retard decided to mount the fuel filter to the engine block on the 4 banger?! i had a 96 v6 and it took me literally 5 minutes to change the fuel filter on that truck....okay, i've vented and now i'm cool. :)
  11. May 4, 2011 at 10:51 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    im having second thought about changing the fuel filter now.
  12. May 26, 2011 at 2:02 AM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    i have to do mine, already bought the filter just need to find the desire to do it! i luckily have a sweet body lift that makes working on anything virtually effortless lol i can sit Indian style under the bed comfterbly...but well see about this fuel filter....
  13. Oct 12, 2012 at 10:05 AM
    beedoola
    beedoola Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    is it recommended to go the route of pulling the fuel relay and starting the truck and letting it die?
    Or can one just relieve the pressure from the gas tank and then start dismantling the fuel filter? - Guessing fuel will come out, but how much?
    Should I put some towels over any electronics?
  14. Aug 1, 2013 at 7:24 PM
    azn toyo
    azn toyo Active Member
    Durham NC
    4x4
    Hi there
    I'm looking to replace my fuel filter and had the same question bedoola had. Does the fuel go everywhere when you loosen the lines? Also, do you need two 12mm line wrenches to loosen the lines (one to hold, one to loosen)? Sorry for the dumb question. Trying to plan out everything I will need.
  15. Aug 1, 2013 at 7:48 PM
    ludeaddict
    ludeaddict Member
    NorCal
    1996 Tacoma 4X4
    N/A
    00 tacoma likes this.
  16. Dec 11, 2013 at 6:24 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Im getting ready to do mine in the next couple of weeks. I will try to take pictures and do a detailed write-up as everyone seems to be deftly afraid of this procedure.
  17. Dec 11, 2013 at 6:25 AM
    Moco
    Eric
    NoVA
    I think you should be OK without pulling the relay. I undid my fuel line up top to make sure it wasnt seized and only a trickle of fuel came out.
  18. Dec 11, 2013 at 6:37 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Wow, the 4cyl is a PITA! It makes me want to go change my fuel filter just because. :p
  19. Dec 11, 2013 at 6:59 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    It sucks. I tried. Jacked up truck, took off wheel. Got everything off but one bolt would just not budge. The space is tiny and hard to get to, and I just couldn't get the leverage I needed. After 4+ hours, multiple cuss words, and some banged up knuckles, I excepted defeat and put everything back together.
    Eff that stupid filter placement, and eff Toyota for letting that roll out like that. Every other vehicle I've owned, I could change out the filter in 5 minutes.
  20. Dec 12, 2013 at 6:59 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You could always cut and replace the hoses and relocate a new one somewhere else. Just leave the old in it's same spot.
