2001 2.7 won't rev past 2k RPM
Discussion in '1st Gen. Tacomas (1995-2004)' started by jedicocheese, May 12, 2017.
  1. Jun 28, 2017 at 9:04 AM
    #41
    jedicocheese
    jedicocheese [OP] Active Member
    another update:
    took off front cat converter ( broke bolt to a/f sensor, had to drill and replace)
    so, cat looks good. no broken parts and i can shine a flash light and see thru it. not sure if how else to test.
    replaced a/f sensor with new Denso part.
    fired up truck and problem still happened with new sensor. i did NOT however reset ECU. but i noticed strong fuel smell and then smoke from engine bay. say smoke/exhaust coming from upper cat pipe were it meets manifold. i guess i didn't get the new gaskets on right or tighten down enough.
    but, the smell of fuel is overwhelming now.
    i have a new MAF on the way.
    what else could cause fuel to be dumped into engine? bad injectors, fuel pump/regulator to high pressure?
  2. Jun 28, 2017 at 9:06 AM
    #42
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I didn't read the whole thread but did you ever replace the crank sensor?
  3. Jun 28, 2017 at 9:15 AM
    #43
    jedicocheese
    no, i haven't replaced the crank sensor yet. it's on the list after i get the new MAF tomorrow to try it. i hate throwing parts at this but i'm a loss as to what else to try. at least with the fuel smell i should be able to have it taken to the dealership to see if they can diagnose that problem.
    the truck has 205k on it and i don't think any sensor has been replaced. So i guess some of them could be going bad but not bad enough to show a CEL
  4. Jun 28, 2017 at 9:58 AM
    #44
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    When my crank sensor went bad it would flash a CEL while it was misfiring when I held the pedal down. Fuel won't be your problem. Pig rich can still rev. You're looking for an electronic problem.
  5. Jun 29, 2017 at 1:06 PM
    #45
    jedicocheese
    update:
    replaced the MAF with one from Rockauto (hitachi brand)
    so far seems to have fixed the smell of gas. the rev limiter problem hasn't happened yet either. I won't know for a couple days if it truly fixed the problem or not. the problem for me was intermittent
    Using my IR gun the cat temps front and back are where i believe they should be. after the truck warms up the inlet is about 270, the cat itself around 290 and the outlet around 270
    i did use the FSM to test the MAF and the a/f sensor and both tested good. however i believe they were originial to the truck, 205K
    so hopefully this helps someone in the future. i'll post again in a about a week to see if problem is gone or if it comes back.
    i believe all i'm dealing with now is burning all the penetrating oil off the exhaust. hopefully that clears up soon
    thanks again for all the suggestions.
    cruiserguy likes this.
  6. Aug 29, 2017 at 10:29 PM
    #46
    Bama_Noles14
    Bama_Noles14 Member
    Jonathan
    1997 Toyota Tacoma 4x4 3.4L
    Did the problem come back ?
  7. Aug 30, 2017 at 5:04 AM
    #47
    jedicocheese
    So far so good. After replacing the MAF. Hitachi brand from Rock Auto the problem hasn't returned.
  8. Aug 30, 2017 at 8:32 AM
    #48
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    I believe that first Cat check you did wasn't really valid because the truck hadn't been running. Cat's have to warm up to work correctly.
  9. Aug 30, 2017 at 8:36 AM
    #49
    jedicocheese
    I meant to update that. I let it get to operating temp. Then noticed my IR gun was on Celsius. So I did it again later and it was around 500 degrees
  10. Aug 30, 2017 at 11:03 AM
    #50
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    I had that issue turned out to be a combination of a clogged cat and faulty wires and platinum plugs.
