2001-2004 Tacoma Factory Service Manual
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Feb 4, 2008.
  1. Apr 8, 2017 at 12:00 PM
    #101
    747
    747 [OP] function > form
    1st Gen.
    No, but thanks for asking
  2. Apr 8, 2017 at 12:05 PM
    #102
    747
    1st Gen.
    My Tacoma recently turned over 200k, and I was reminiscing about it in its earlier days when I was active here
    Re: link, no prob!
    surforegon likes this.
  3. Jun 19, 2017 at 8:33 AM
    #103
    JackCrank
    JackCrank Well-Known Member
    Jack
    Brooklyn
    2006 4x4/2.7L/5MT/Access Cab/Desert Sand Mica
    Bone stock for now...
    So this place is awesome and the FSMs are a huge help but what I'm dying for is a full parts fiche. Does anyone have a parts catalog for a 2002 4x4 2.7L 5speed Tacoma DLX Xcab?
    Jimmyrace likes this.
  4. Jun 19, 2017 at 8:43 AM
    #104
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  5. Jun 19, 2017 at 8:46 AM
    #105
    JackCrank
    Jack
    Brooklyn
    @mechanicjon
    That is amazingly helpful! Thanks a ton! For giggles, I took my taco to the dealership for a 125k mi tuneup and to ask about replacing the exhaust which has a giant hole in it. They quoted me something along the lines of $6k...
    I am in waaaaay over my head here.
  6. Jun 19, 2017 at 8:47 AM
    #106
    mechanicjon
    Jon
    Scottsdale Arizona
    :eek:
    :eek::eek::eek::eek: did that come with a kiss to? Dam $6K!
  7. Jun 19, 2017 at 8:51 AM
    #107
    JackCrank
    Jack
    Brooklyn
    Ha... Apparently, Toyota of Manhattan only stocks special edition OEM dragonbone spark plugs and unicorn horn catalytic converters
    ¯\_(ツ)_/¯
    1stTacoma!, Jimmyrace, x2468 and 2 others like this.
  8. Sep 11, 2017 at 7:24 PM
    #108
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Does anyone have the FSM for an 04 3rz I need one and all the links are broken we can pm to exchange emails? Or something... I need a sticker this month :annoyed:
  9. Oct 17, 2017 at 6:14 AM
    #109
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
  10. Nov 5, 2017 at 5:11 PM
    #110
    Taconut83
    Taconut83 Member
    2003 toyota tacoma sr5 trd 3.4 v6 4x4
    None
    Ok i know this is a long shot but im hoping you guys are watching this thread... i have a 2003 tacoma SR5 TRD 3.4 v6. My 4 wheel drive stopped working. When i attempt to depress the 4x4 button in the cab on the transfer case selector which is a manual 2hi-4hi and 4low transfer case shifter with a push button 4 wheel drive button on the side of the knob... nothing happens... the transfer case nor the front diff move... So here is what ive attempted to fix thus far... first off it is not a vacuume system it is fully electric there are vent lines that come out of the actuators but are not controlled by vacuume. So its not a vacuume issue. I first attempted to replace the transfer case "switch"/position sensor... that did nothing same issue... i purchased a front diff actuator installed it and the old diff actuator was stuck in 4wd so i slid the gear back and set the new actuator to 2wd... same issue.. nothing happens. I disconnected the plug off of the front actuator and pushed the 4x4 button and the transfer case actuator placed the transfer case in to 4wd! By using pin 1 and 5 on the front actuator i placed the differential into 4wd so the actuator works... i reversed polarity and placed it back into 2wd and depressed the switch the transfer case went bavk.into 2hi... i know its electrical but is there a relay in my 4wd system of is it all in the 4wd computer can i purchase a new pigtail dor the 6 pin connector? I cannot find one similar to mine anywhere.in a junkyard near me i was hoping somebody has had this same issue...
  11. Nov 7, 2017 at 1:48 PM
    #111
    mechanicjon
    Jon
    Scottsdale Arizona
    Posted in the wrong section. Yes you can buy the pladtic part of the pigtail from Toyota. You need the leters and numbers off the connector it self. Then go to this thread.
    https://www.tacomaworld.com/threads...-for-tw-members.207298/page-148#post-16417113
    and ask gunny1005
  12. Nov 19, 2017 at 7:14 AM
    #112
    harness4x4
    harness4x4 Member
    Jesse
    16 DCLB TRD Sport
    Icon suspension, Lights, Shell
    I've taken my transmission off to replace the clutch and flywheel and I can't seem to find the torque specs for the flywheel. Any ideas?
  13. Jan 10, 2018 at 6:47 PM
    #113
    Coma Rookie
    Coma Rookie Well-Known Member
    Mr.
    Alaska
    02 DC TRD *SOLD for $18k*
    More than I can shake a stick at...
    Is there a simple PDF version available? Does anyone know if I pay for a subscription on Toyota’s TIS website will I be able to download the manual or just have access to their database for the length of the subscription? I have a Haynes, but it is barebones. I just want to be able to put it on the tablet and scroll and use a search function.
  14. Jan 10, 2018 at 8:40 PM
    #114
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Look four posts above yours. It's an 03 fsm. And it'll be close. Its not a PDF, but web based. It has ects-i & non-ects. Which are the main differing points between trucks. And I also wouldn't put much faith in the 03 EWD for your 02. But there's an 03 FSM PDF around.... But atm that's probably the best you'll get.
    Toyota's TIS is $$ for a 24 hour jaunt with whatever you can find & download within that 24 hours. Good luck. I have the paper FSM it's about 7" thick. And a few hundred sections.
  15. Jan 20, 2018 at 5:19 AM
    #115
    Flaps
    Flaps Well-Known Member
    Ted
    2004 tacoma 4x4 v6 TRD DCSB
    Your right Good luck
  16. Jan 22, 2018 at 11:02 AM
    #116
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I've got a hard copy of the FSM for an 01 if that will help anyone
  17. Jan 29, 2018 at 9:32 PM
    #117
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    Not sure if it’s been posted but there’s a seller on eBay selling the manual for 10 dollars as an Efile, i purchased it and it’s complete as far as I can tell ,only down fall is that each section is labeled kinda confusing, you will understand it after spending a couple hours on it , it’s marked as an 2003 tacoma service manual 2wd 4wd 2.4 2.7 and 3.4 im satisfied, i printed each section and bought a 4inch binder gonna need another 4 inch binder lol
  18. Jan 29, 2018 at 11:24 PM
    #118
    nagorb
    Alabama
    2001 dbl cab 4x4
  19. Jan 29, 2018 at 11:26 PM
    #119
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have the paper Toyota FSM version for my '98 and I always find myself using the online indexed version more, it's so much easier to navigate.
  20. Jan 29, 2018 at 11:28 PM
    #120
    nagorb
    Alabama
    2001 dbl cab 4x4
    Which version? Only ones I've seen are like the one above.
