2001-2004 Tacoma Factory Service Manual
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Feb 4, 2008.
  1. Jan 29, 2018 at 11:28 PM
    #121
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    A lot of the links are broken, but the '03 one downloads fine. That's the one I use the most.
    nagorb[QUOTED] likes this.
  2. Mar 3, 2018 at 7:21 PM
    #122
    VanillaGorilla78
    VanillaGorilla78 New Member
    2001 White Tacoma TRD
    Hey I'm new to this site anyway I just purchased a 2001 Tacoma 4x4 TRD Double cab 3.4L I was wondering if you could possibly help me with some info on possible causes of rear differential lock not engaging the light just blinks when I push the button to engage the locker also do you happen to know where I could get a PDF copy of a repair manual for my truck Thanks in advance for any help you can provide
  3. Mar 23, 2018 at 12:45 PM
    #123
    dakotaramos
    dakotaramos )'(
    Las Vegas, NV
    04 Taco V6 4x4 5-spd manual TRD Off Road
  4. Mar 23, 2018 at 2:59 PM
    #124
    srsupertrap
    srsupertrap Well-Known Member
    Erie, CO
    2001 Tacoma SR5 V-6 TRD 4 X 4
    Bilstein 5100s, Borla 14945 S/S Exhaust, Fram Air Hog Filter, Diff Breather Mod & NGK Wires
    Thanks . . . Love those hyperlinks
  5. Aug 14, 2018 at 6:33 PM
    #125
    Truckguy2003
    Truckguy2003 New Member
    2003 Toyota Tacoma Red
    I’m looking for the location of the body control module for a 2003 Tacoma Prerunner 3.4L
  6. Aug 14, 2018 at 6:35 PM
    #126
    BartMaster1234
    Tyler
    Flux Capacitor
    Behind the fuse panel under the steering wheel.
    Jimmyrace likes this.
  7. Aug 26, 2018 at 8:40 PM
    #127
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    How much difference do you find in the 03 fsm vs working on earlier year trucks?
  8. Aug 26, 2018 at 8:42 PM
    #128
    BartMaster1234
    Tyler
    Flux Capacitor
    I use it all the time for my two 1998's. Only major differences I know of are some of the wire colors and some minor tweaks.
    License2Ill[QUOTED] likes this.
  9. Aug 26, 2018 at 8:46 PM
    #129
    License2Ill
    Ian
    That's good to know. :cheers: I know the 03 has diagnostics for both throttle body types which is the largest difference I've found.
  10. Aug 26, 2018 at 8:51 PM
    #130
    BartMaster1234
    Tyler
    Flux Capacitor
    I even have the Paper edition of my 1998 service manual but I use the 2003 one way more simply because it's easier to navigate, plus it's indexed. Even the wiring diagrams are mostly the same, just some of the pinouts and wire colors changed over the years.
  11. Aug 26, 2018 at 9:00 PM
    #131
    License2Ill
    Ian
    Yep, have the $$$ multi-book fsm also. Having it on my phone & computer is pretty much indispensable.
    Jimmyrace and BartMaster1234 like this.
  12. Aug 26, 2018 at 9:02 PM
    #132
    BartMaster1234
    Tyler
    Flux Capacitor
    I don't even touch the paper manuals anymore. For things that mostly remain the same, like torque specs, I use my the '03 indexed PDF on my laptop.
  13. Dec 12, 2018 at 5:50 AM
    #133
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  14. Jan 30, 2019 at 12:39 AM
    #134
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    2003 FSM good for 2001 3.4 4x4 DC?
  15. Jan 30, 2019 at 12:41 AM
    #135
    BartMaster1234
    Tyler
    Flux Capacitor
    No. The 2003/2004 5VZ v6 has the ETCS-I electronic throttle system, 1995-2002 have a mechanical cable driven throttle. The valve body and the throttle body at least will be different.
  16. Jan 30, 2019 at 12:42 AM
    #136
    jeg0005
    Jon
    BHM, AL
    linkie likes this.
  17. Jan 30, 2019 at 12:46 AM
    #137
    BartMaster1234
    Tyler
    Flux Capacitor
    That website received a copyright infringement/takedown notice so you won't be able to find up-to-date FSM links. If you're doing any engine work than involves the throttle system then it will be different.
    Every year something changed, especially the pinouts on the ECU and other computer components in some cases. If you're doing something basic than never changed over the generation like a water pump, head gasket, etc. then any year FSM will be fine. It's entirely up to what you're doing to determine if you need your specific year FSM or not. Most of the time the answer is no, you don't need the year specific FSM.
    linkie likes this.
  18. Jan 30, 2019 at 12:47 AM
    #138
    jeg0005
    Jon
    BHM, AL
    For now I'm just looking for torque specs of drain/fill/transmission pan bolts so the 2003 should be fine? I'll attempt to track down a 2001 at some point I guess.
  19. Jan 30, 2019 at 12:49 AM
    #139
    BartMaster1234
    Tyler
    Flux Capacitor
    Absolutely it'll be fine. Stuff like torque specs didn't change (for the most part). When you get into wiring schematics, vacuum line routing, emissions control, and other specifics that changed over the years is where you run into trouble.
  20. Jan 30, 2019 at 12:51 AM
    #140
    jeg0005
    Jon
    BHM, AL
    Thanks! I'm new to TW and have been obsessively browsing the forum since I got my Taco and I see you everywhere being incredibly helpful. Thanks from a newbie.
    If anyone has a digital 2001 FSM pm me please
