2001-2004 Tacoma Factory Service Manual
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Feb 4, 2008.
  1. Jan 30, 2019 at 12:54 AM
    #141
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    No problem. Happy to help.
    BTW, attached is a PDF of the torque specifications for the transmission pan (and others).
  2. Jan 30, 2019 at 1:01 AM
    #142
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Thanks! I was just looking at that. They use different terms. I'm assuming "oil strainer x valve body" is the bolts that attach the filter and "oil pan x transmission" are the pan bolts?
  3. Jan 30, 2019 at 1:02 AM
    #143
    BartMaster1234
    Tyler
    Flux Capacitor
    Correct. Strainer is the filter, and oil pan is the pan itself.
  4. Mar 16, 2019 at 9:44 AM
    #144
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    Anyone have or know where I can find the ECU connector pin diagrams, I can't find them in the FSM
    For a 2001 5vzfe Tacoma 2wd Auto
    Please please please
    E5 , E6 , E7, E8,
  5. Mar 16, 2019 at 8:13 PM
    #145
    Happysmiley
    Fabien
    Northern NV
    Jimmyrace likes this.
  6. Jun 5, 2019 at 4:08 PM
    #146
    taCOMA54
    taCOMA54 Active Member
    Jacksonville, FL
    2021 Cement TRD Off-Road DCLB
    Ceramic Pro Silver
    I'm having a slight problem when I use the index to access the different sections of the service manual. If I'm on a page and it references a different page for something, the hyperlink is there for the other page but when I click on it I just get brought to the top of the section that I was already in. Is there a way to get this to bring you to the section that it is actually referencing?
  7. Jun 5, 2019 at 6:33 PM
    #147
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Not that i know of.
  8. Jul 14, 2019 at 7:29 AM
    #148
    Taco_Nooga
    Taco_Nooga Member
    Chattanooga, Tennessee
    2004 PreRunner
    Working on it!
    Anyone know if there are differences between the '03 and '04 wiring, in general as well as specifically for the taillights and power door locks? I'm installing a Pop N Lock and a backup camera, trying to figure out where I want to tap into the harness.
    Huge thanks to those who post these FSM links.
  9. Jul 14, 2019 at 7:31 AM
    #149
    mechanicjon
    Jon
    Scottsdale Arizona
    Should be the same
    Taco_Nooga likes this.
  10. Oct 29, 2020 at 5:48 PM
    #150
    coldaccord
    coldaccord Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    Read about the manuals being NLA due to restrictions.
    Is there consensus on the best service manual? I don't mind buying a paperback one.
    For a 2000 Tacoma. Thanks
  11. Oct 29, 2020 at 6:02 PM
    #151
    BartMaster1234
    Tyler
    Flux Capacitor
    Dealers haven’t used the paper manuals in years, everything is digital now through TIS, or Toyota Information System. You can actually pay a small fee and access it, then download whatever diagrams or instructions you need.
  12. Oct 29, 2020 at 6:09 PM
    #152
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    From what I've read, paper was last used in 2011. I may have posted the following further up. Will post again.
    Here's a site where you can download from. There are 2 versions:
    - Online Version
    - Full FSM File Download
    The Online Version no longer seems to work; the Download does. Once you get it down to your machine you can unzip it. Scroll thru the list and select what's most applicable to you:
    http://web.archive.org/web/20110102225436/http://www.ncttora.com/FSM/
    vtroot and coldaccord like this.
  13. Oct 29, 2020 at 6:40 PM
    #153
    coldaccord
    André
    Buffalo, NY
    Thank you
  14. Oct 29, 2020 at 8:55 PM
    #154
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    The link in my sig line works. Download and print what you need.
    sean.hwy and Taco2021LB like this.
  15. Nov 28, 2020 at 10:54 PM
    #155
    BatteredTaco
    BatteredTaco Well-Known Member
    J Lo
    SoCal
    02 3rz stick 4wd ext
    JDM 3rz@300k Yota1 cylhead@400k ARB-OME 880/5100s
    :ohsnap: Thank you
    VeeSix likes this.
  16. Feb 25, 2021 at 8:01 PM
    #156
    Kristi with a K
    Kristi with a K Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    For any other frustrated '01 5vz owners, I was actually able to find what I needed through the link in post #155 & using the '95-'97 manual. It just opened (well, took a minute being 1623 pages.), no zip download prompt. So I'm not too sure whether downloading is an option for some it since it's not a zip, but it's there. Also I recall whenever Tim works on his 4Runner in a vid, it seems similar to the 5vz. It's referenced on the linked site as a 5fe though. Worth taking a look at just in case....
    Also this one has some hit or miss files http://www.markofshame.com/fsm/01_Tacoma/Seperates/Service manual/
    & there's this http://markofshame.com/fsm/01_Tacoma/01 Tacoma Service Manual.pdf, however unfortunately it's missing half-ish of it. States it's 523 pages, yet there are 271.
    nagorb likes this.
  17. Feb 28, 2021 at 7:48 PM
    #157
    halfbid
    halfbid Well-Known Member
    Central Oregon
    1996 Tacoma DLX 2.7L, 5 speed, 4wd
    Tdog2.7L and Kristi with a K like this.
  18. May 8, 2021 at 1:08 PM
    #158
    Kristi with a K
    Western MA
    Did you figure it out? I checked mine not long ago.
  19. Jan 7, 2022 at 8:40 PM
    #159
    Omnidaddy
    Omnidaddy Member
    zach
    redding ca
    1996 toyota tacoma 2.7 4wd
    Cool air intake, rollbar with kc lights
    Thank you for posting. i lost mine when i got a new phone. p.s. do you know where i could find an ecm for a 96 2.7 4x4
  20. Jan 7, 2022 at 8:44 PM
    #160
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Best place is a local scrap yard or flebay.
    Check car-part.com for local places.
    car-part.com
