2001 Leaf Spring question
Discussion in 'Suspension' started by dustinclm, Jan 28, 2011.
  1. Jan 28, 2011 at 1:32 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    i have a 2001 tacoma with a 3" suspension lift with has blocks in the back (yes i know its a crappy way to lift the truck) which has been on the truck for almost 4 years now. I have never noticed before but the leaf springs do not have a curve to them any more, they are pretty much staight with the front side a little further down than the rear, as if the were slightlty tilted forward. is this normal? or expected with adding blocks?
  2. Jan 28, 2011 at 1:45 PM
    BSPDX
    BSPDX Well-Known Member
  3. Jan 28, 2011 at 1:57 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Our leafs sit pretty much flat but seeing how you have a 01 I would swap them out for some new ones or a temp fix you can put in a AAL but depending on how bad your leaf packs are you will just need to replace them.
  4. Jan 28, 2011 at 2:18 PM
    dustinclm
    Thibodaux, La
    without going to the dealership does anyone know how much they usually cost? i am finishing college in May and will hopefully be getting a new truck sometime after that so i do not want to dump all kind of money into the truck if i dont need to...
  5. Jan 28, 2011 at 2:22 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Probably close to $1000.00 if you do the work yourself, double it if you have a shop do it. If your getting a new truck in the next year, save your time and money for the new truck.
  6. Jan 28, 2011 at 2:24 PM
    JLee
    Jerry
    Bay Area NorCal
    Don't go to the dealer there is lots of other places to buy leafs. If you really just want a temp fix buy an AAL. I'll have one for sale next month 60 bucks shipped when I switch out to my Expos.
  7. Jan 28, 2011 at 2:27 PM
    JLee
    Jerry
    Bay Area NorCal
    :eek: for a leaf replacement! :der: I payed under 300 for my AllPro Expos when they were on sale so they are a little over 300 bucks.
  8. Jan 28, 2011 at 2:29 PM
    dustinclm
    Thibodaux, La
    I might have to take you up on the offer. how many miles do you think yo have on yours? Why would the AAL be a temp. fix and wouldnt that stiffen the ride? i dont mind doing the work myself, i'll enjoy it, i put my lift on so i think i could handle this.
  9. Jan 28, 2011 at 2:36 PM
    JLee
    Jerry
    Bay Area NorCal
    I have about 3500 miles on my AAL's The only reason I say a temp fix is if your leaf pack is shot it will only do so much before the AAL starts to flatten out with your leafs. I bought the 2" lift AAL from Toytec and it only gave me 1 1/2 and they have sagged a little so I'm replacing the whole leaf pack. I'm sure the AAL is still good it's only been 3500 miles it's just settled and it's to low for me.
  10. Jan 28, 2011 at 2:49 PM
    dustinclm
    Thibodaux, La
    i thnik my lift only gave mt 2.5" or 2.75" in the front if im not mistaken which make the front just a hair lower than the back and actually i would prefer the truck to sit level or have the front a hair higher, but i dont know how low the 1.5" would make the stance of the truck change. Im not familiar with the AAL, if im correct then i wouldnt need the lift blocks in the rear anymore...?
  11. Jan 28, 2011 at 2:51 PM
    JLee
    Jerry
    Bay Area NorCal
    How big is the block?
  12. Jan 28, 2011 at 3:09 PM
    dustinclm
    Thibodaux, La
    just at 2 7/8" or 2 15/16"
  13. Jan 28, 2011 at 3:15 PM
    JLee
    Jerry
    Bay Area NorCal
    Well the AAL is going to lower your rear end just a little.
  14. Jan 28, 2011 at 3:31 PM
    dustinclm
    Thibodaux, La
    yeah i figured it would and im ok with that, i like how trucks look when they are level or the front it a shade higher but im not sure how 1 to 1.5" would look, not not too bad...good enough to have a better ride probably and i would be ok with that bc its pretty rough right now haha i also pull my boat which levels out the truck so as long as it wont mess with anything with that i may get the AAl from you if they will last me about a year
  15. Jan 28, 2011 at 3:40 PM
    JLee
    Jerry
    Bay Area NorCal
    Pm'ed
