2001 lift options
Discussion in 'Suspension' started by Joeyd93, Jan 23, 2013.
  1. Jan 23, 2013 at 11:48 AM
    Joeyd93
    Joeyd93 [OP] Member
    Joey
    01 prerunner sr5
    6k HID headlights, custom rims, Memphis audio front and rear speakers and tweeters, 12" kicker subwoofer, deck plate mod, k&n air filter
    I have a 2wd taco v6 sr5 4door and I'm looking to do the whole "pre runner" look.
    I want to lift both the front and the back with new shocks but I also want the front to sit about 3" higher than the back. I have no knowledge about lift kits or suspension. I want to find a good one without spending over $3000.
    I don't know if they have pre made "pre runner" looking lift kits or if I should just get a 3" kit then add spacers to the front. All feedback is appreciated.
  2. Jan 23, 2013 at 2:52 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You cannot lift the front more than 3" without a drop bracket. Adding spacers to an already lifted front would be stacking lifts.
    My suggestion would just be to buy a 6" drop bracket lift for the front, and then only lift the rear 1.5-2" with an add a leaf.
    Or you could buy lift spindles for the front and leave the back stock.
  3. Jan 23, 2013 at 3:08 PM
    Joeyd93
    Joeyd93 [OP] Member
    Joey
    01 prerunner sr5
    The only thing is that I need new shocks anyways as mine are getting pretty stiff
  4. Jan 23, 2013 at 3:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    you can lift the front with new shocks/coils (OME coils w/OME shocks, 5100's w/ eibach/toytec) and leave the stock rear....
    but I gotta ask
    why?
  5. Jan 23, 2013 at 3:13 PM
    Joeyd93
    Joeyd93 [OP] Member
    Joey
    01 prerunner sr5
    Thanks a lot. Why what, why do I want it higher in the front?
  6. Jan 23, 2013 at 3:18 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
  7. Jan 23, 2013 at 3:55 PM
    Joeyd93
    Joeyd93 [OP] Member
    Joey
    01 prerunner sr5
  8. Jan 23, 2013 at 4:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    gearing only needs to be changed if there are drastic changes to tire size; it has nothing to do with lifts
    take a look around the site, there's tons of info here
