2001 Mustang won't start
Discussion in 'General Automotive' started by fatty ac1d, Dec 6, 2010.
  1. Dec 6, 2010 at 3:14 PM
    fatty ac1d
    fatty ac1d [OP] Well-Known Member
    Liberal, Kansas
    15 MGM DCSB SR5
    The ol lady has a 2001 Mustang v6 that won't start. It all started a month and a half ago when it was starting to get cold. The car was having troubles starting and it sounded like a typical battery issue. I replaced the battery and that seemed to fix it. I also put about 1/3 can of Seafoam in the gas tank.
    Then a couple weeks ago the car was having troubles starting again. It would crank fine but it just wouldn't start. I ended up getting it started by turning the ignition from OFF to ON, pausing for a few seconds then repeating the process 5 or 6 times to cycle the fuel pump. That worked for a few days. Now, it won't start at all.
    What I've done so far:
    Replaced battery
    Added 1/3 can of seafoam
    Checked fuel shutoff
    Changed spark plugs 6 months ago
    Seems to be related to the cold
    What else can I do, short of driving it into a lake? I understand it could be the fuel pump but we don't have the money to get it replaced.
  2. Dec 6, 2010 at 3:21 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    maybe its the alternator, try jump starting it, and if it starts up easy then its the alternator or the replacement battery was bad but if it doesnt then you know you have a real problem.
  3. Dec 6, 2010 at 3:56 PM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    By cycling the ignition, you are giving the fuel pump extra time to build pressure. This makes me suspect a fuel delivery problem. Have you checked voltage at the fuel pump and at the fuel pump relay?
    Of course, low voltage could mean:
    - bad battery
    - bad alternator
    - bad wiring / ground
    - bad fuel pump
    - bad relay
  4. Dec 6, 2010 at 4:00 PM
    db2
    db2 Well-Known Member
    2016 TRD Sport DC
    Sounds like a fuel issue. Pull out one of the sparkplugs, connect the plug wire to it and ground the plug by setting it on the intake manifold so that the page of the plug is making contact with the metal of the intake manifold, then have a buddy crank the ignition. While doing that check to see if you see a spark between the electrode and the plug. If nothing, it's an ignition problem, if it sparks, then it's a fuel problem...
  5. Dec 6, 2010 at 4:01 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
  6. Dec 6, 2010 at 4:07 PM
    tacomadude18
    tacomadude18 Well-Known Member
    carlitos
    Glenwood Springs, CO
    SR5 TRD Sport DCLB
    AFE cold air intake,tinted windows, Snug top, Brand New XD Addicts 17x9 with a -12 offset. (hopefully get a 6 inch lift kit, also wanna get an exuast system..) new! Exelon Kenwood with 12" rockford punch
    Ford =
    Fix
    or
    Repair
    Daily
  7. Dec 6, 2010 at 4:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    start with the fuel filter first if you suspect it to be a fuel issue. its right up behind the spare tire/trunk area if i remember correctly from the 02 mustang that my wife had. they are relatively easy to change......5 dollar a/c line tool does the trick.
  8. Dec 6, 2010 at 4:13 PM
    BSPDX
    BSPDX Well-Known Member
    too be honest the lake idea sounds about right...:rolleyes::D
  9. Dec 6, 2010 at 4:14 PM
    biketom555
    biketom555 Member
    Tom
    NW Indiana
    09 Barcelona Red SR5 4x4
    Nerf bars (TRAIL FX 56400 stainless), "Quality S" class III trailer hitch, WeatherTech Side Window Deflectors, Hellwig rear Sway Bar, WeatherTech Digital Mats (front), P&L 5300.
    Fuel pump no question. I have owned a few Fords and have seen this problem. I had to get a tow when mine stalled at an intersection! If you can get it started again, take it in to have the fuel pressure checked. The pump, if it needs replacing, is in the fuel tank and will cost ~$200.00-$400.00. Sorry and good luck.
  10. Dec 6, 2010 at 4:15 PM
    VTDave
    Vermont, USA
    Unfair!
    My 2005 Mustang GT at 125k has needed NOTHING but regular maintenance and, uh, lots of gas money
    My 2005 Tacoma 4x4 at 73k has needed regular maintenance plus 2 spiral cables (clock springs) and a steering rack TSB.
    That being said, I love them both, put them through hard driving, and consider them to be very reliable vehicles.
  11. Dec 6, 2010 at 4:26 PM
    biketom555
    biketom555 Member
    Tom
    NW Indiana
  12. Dec 6, 2010 at 8:06 PM
    fatty ac1d
    Liberal, Kansas
    15 MGM DCSB SR5
    Hmmm....
    Well, when it gets warmer again on Wednesday or Thursday I'll check voltages, spark, and I'll try jumping it. I might see if I can get my hands on a fuel pressure tester also. I'd like to check as much as I can without buying anything.
    It's parked on the side of the street in front of our house, so it literally is Found On Road, Dead. :rolleyes:
  13. Jan 30, 2011 at 2:15 PM
    fatty ac1d
    Liberal, Kansas
    15 MGM DCSB SR5
    Here's a helpful tip I learned when you suspect fuel pump problems....
    When you often let the gas level get below 1/4 tank, especially with older vehicles that have the fuel pump inside the tank, you run the risk of junk getting stuck in the fuel pump. When this happens, you'll end up with symptoms similar to the ones I described above.
    To fix this, you need a rubber mallet and another person. Have your buddy crank on the ignition while you beat the hell out of the fuel tank about where the fuel pump is. It might take a few tries, but this will dislodge the junk from the pump and hopefully allow the pump to work again.
    Change the fuel filter and keep the gas level above 1/4 and you should be fine.
    :cool:
