2001 tacoma 3.4l o2 sensor - which one?
Discussion in '1st Gen. Tacomas (1995-2004)' started by banketh, Jun 9, 2017.
  1. Jun 14, 2017 at 12:42 PM
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
  2. Jun 14, 2017 at 12:46 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  3. Jun 14, 2017 at 3:43 PM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    Just checked Amazon and it looks like the A/F sensor is available, Denso 234-9001 (if you have an auto). You can replace it and it may or may not help anything. If you go to a shop that does OBD2 diagnostic/testing (more than just "here's the CEL codes") they can see how the A/F sensor is behaving in regards to fuel trim and voltage. That could tell you if it's the sensor, or if there is another issue up-stream. It's either gonna take some investigation, or just buying new parts and hoping you get lucky.
  4. Jun 14, 2017 at 4:16 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    I just replaced my AF sensor last week due to a P1135 code. It was a PITA as the nuts were completely rusted out and I had to file them down to get a wrench around them. It my understanding that the upstream and downstream sensors will throw different codes. I would also advise looking the part up on Desnso before buying on Amazon as their are different part numbers for manual and automatic. http://densoautoparts.com/find-my-part/vehicle-selection
  5. Jun 14, 2017 at 6:44 PM
    banketh
    banketh [OP] Active Member
    2001 Tacoma TRD
    Thanks again for the help guys!
    I appreciate the links to Amazon but ive already ordered the part from them (9003 - manual) and then a week later they said it wasnt in stock and cancelled the order. The same part is still showing for sale by the same vendor but according to amazon as of today the part is not available.
    Hence im wondering if i should shell out double the money to replace it soon or wait until amazon gets their shit together which could be who knows how long? Any recommendations? Am i gonna burn the cat up running too rich?
  6. Jun 15, 2017 at 10:19 AM
    Currygoat
  7. Jun 18, 2017 at 7:23 PM
    banketh
    2001 Tacoma TRD
    Ok well the o2 sensor showed up and after working through the rusted bolt issue I installed the new one and the check engine light has been off since the first turnover. I think I got a little lucky on this one! I also managed to not mangle the heat shield, one bolt broke loose pretty easily and I was able to turn the heat shield around so I could access the other bolt easier. Ended up using vice grips to get it off, the bolt was rusted to the stud but the entire stud broke lose and came out fine. I replaced both studs with bolts and lock washers instead.
    Thanks again for all the help and advice guys!
  8. Jun 18, 2017 at 7:27 PM
    McMash
    Tyler
    Gig Harbor, Wa.
    Hopefully that did the trick! It may take some time for the ODB readiness monitors to finish their test procedures; if they finish up and something doesn't pass, the CEL will come back on. Finger's crossed the new sensor helps.
  9. Jun 18, 2017 at 9:08 PM
    banketh
    2001 Tacoma TRD
    Yeah I was wondering about that. I did disconnect the battery to switch the sensor, does that reset the ecu? I've driven maybe 25-30 miles since the swap but I'd imagine it will take longer than that.
  10. Jun 18, 2017 at 9:48 PM
    McMash
    Tyler
    Gig Harbor, Wa.
    Yeah, that resets the ECU. It depends on the driving conditions, duration, fuel level, etc, but the monitors will likely complete within a few days worth of driving.
  11. Jun 19, 2017 at 6:09 AM
    banketh
    2001 Tacoma TRD
    Right on, thanks for the info!
  12. Jun 21, 2017 at 5:21 PM
    banketh
    2001 Tacoma TRD
    Ok well I've driven a few days and a couple hundred miles and the check engine light hasn't come back on so I think that fixed it.
    Is it still a good idea to do the a/f sensor since that's been almost 75000 also?
    What kind of gas mileage are you guys normally getting? Is 16 - 17 the average or is it closer to 20?
  13. Jun 22, 2017 at 2:03 PM
    Currygoat
    I asked this exact question to the parts manager at my local Toyota dealership. He told me his previous job was at a wholesale manufacturer of Toyota parts. He said to wait till the car throws another code before replacing the other O2 sensor (downstream in my case).
  14. Jun 22, 2017 at 3:23 PM
    banketh
    2001 Tacoma TRD
    Even though toyota recommends replacing these every 75000 regardless of a code or not?
    I'm usually for the mindset if it's not broke don't fix it, but with electronic sensors it seems as if this may not always be the case?
  15. Jul 3, 2017 at 5:30 PM
    #35
    banketh
    2001 Tacoma TRD
    Haha engine light came back on, same code. Figure it's the a/f sensor now that needs to be swapped out, right at about that 75000 mark...
  16. Dec 24, 2022 at 2:31 PM
    #36
    nestea123
    nestea123 New Member
    2001 tacoma
    @banketh, I know this post is 5 yrs old :D but what did you end up doing on this issue? I have the P0420 light and about to figure out my plan of attack. thinking of doing sensors first, and Cat as the last resort.
  17. Dec 24, 2022 at 4:26 PM
    #37
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    They have not been around since 4/2020
    The first step is check for any exhaust leaks between the cats .
    Allowing for exhaust to leak before the down stream sensor is able to read all the exhaust.
    For what ever reason the ecm is reading to constant of a signal not enough difference .
    Some get lucky changing the downstream sensor.
    Good Luck!!
    Good Luck
  18. Dec 25, 2022 at 8:42 AM
    #38
    nestea123
    2001 tacoma
    thank you! I will be checking for leaks first!
  19. Dec 25, 2022 at 8:46 AM
    #39
    Bivouac
    Good luck!
  20. Dec 25, 2022 at 3:07 PM
    #40
    nestea123
    2001 tacoma
    found this hole my worry is that it looks like I’ve had this for a while. Wonder why it triggered the code now.
