2001 Tacoma no start no click
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levi_jordan14, Nov 22, 2020.
  1. Dec 9, 2020 at 10:39 PM
    pokerstarinya
    pokerstarinya Member
    96 Tacoma 4x4 DLX 2016 TRD Tacoma4x4 OffRoad
    Gen 1 = Icon Stage 4 lift with Icon A-Arms, BFG 33's Gen 3 = King 3.0 lift matching rear reservoirs and rear leveling kit. 305-70-17 Toyo RT on Pro Comp rims
    I just put a post in today about the same exact thing!! My 96 Tacoma V6 4x4 Manual trans. To a post above I have clutch cancel and it still wont start. I was going to ignition switch too! Was not sure what else to do!!
  2. Dec 9, 2020 at 11:02 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    Do you hear the starter solenoid click when you crank the ignition? If not, I had a bad ground (wire was corroded) from my starter relay that caused a really annoying intermittent no-crank in my '90 with a 22re. Don't know if the V6s are wired the same.
  3. Dec 9, 2020 at 11:11 PM
    pokerstarinya
    I just replayed the video I took and no I don't think so. I will have to check out. Thanks for your feedback!
  4. Dec 10, 2020 at 8:40 AM
    Mojave4x
    Mojave4x Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    You may want to remove the cables and take a wire brush to the ends, and clean the battery posts if you haven’t done that. Reassemble them tightly. Check both ends, battery and starter
  5. Dec 11, 2020 at 8:06 PM
    pokerstarinya
    Copy that. I'm on checking the ends. Did a new battery and cables. Thanks
  6. Dec 26, 2020 at 12:35 PM
    pokerstarinya
    So I have checked. I see the reminisce of an aftermarket alarm. It doesn't seem to be connected. I have a new battery. I was driving yesterday and my battery light came on for about 15 minutes all the way home. When I got home I looked for the same thing and nothing. I did diagnostic on alternator and it checks out however there is no light currently. Maybe this is going now? battery is not draining currently. Tightened every connection I could think of and seems ok here too!
  7. Dec 26, 2020 at 12:50 PM
    CoastieTX
    CoastieTX Well-Known Member
    PNW
    Original owner 1998 Tacoma TRD; 3.4 V6 with 5 MT
    Another thing that can be done if the culprit is the clutch switch....twist the key all the way to the start position, hold it there, and pump the clutch. If, after doing this several times it starts, you know the clutch switch is intermittently failing.
    JudoJohn likes this.
