2001 Tacoma Rubbing/Grinding while braking??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01GreenTacoma, Jan 9, 2017.
  1. Jan 22, 2017 at 7:01 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Usually, not always, the easiest, quickest way to test wheel bearing, at least for me, leave truck on ground and grab the tire at 12 o'clock position and push and pull aggressively. You're trying to feel a little bit of play. You may already know this, not trying to be captain obvious or anything.
  2. Jan 22, 2017 at 8:05 PM
    01GreenTacoma
    01GreenTacoma [OP] Well-Known Member
    That's how I first found the slack...
  3. Jan 22, 2017 at 10:45 PM
    cruiserguy
    Elijah
    SEKS
    Wheel bearing may have a little play, but from the sounds and symptoms you're describing that doesn't sound like typical wheel bearing symptoms. Most describe it as more of a hum, that increases as vehicle speed increases. You can also bump the steering wheel(safely) left and then right, at 35-40+ mph, to put more vehicle weight on one side. Then the hum will be more pronounced, usually, one side over the other helping you narrow down which side has the failing wheel bearing.
    To me, your symptoms don't sound like the typical symptoms of wheel bearing failure. Doesn't mean it's not that, just not symptoms I've heard.
    So it's a clunk? Coming from a front wheel? Does turning either way affect the noise you hear? How do the tie rod ends look/feel?
  4. Jan 23, 2017 at 6:45 AM
    01GreenTacoma
    I crawled under the truck yesterday again. And tried to look everything over. The tie rods felt tight. The only other thing I can think of if it's not the wheel bearing is the lower ball joint "having increased motion up/down/sideways" causing the thud/clunk and the slack in the wheel. As I push the wheel from side to side it has slack and a little thud.
    I have not had a chance to completely break down the front drivers side to inspect everything.
  5. Jan 23, 2017 at 9:37 AM
    cruiserguy
    Elijah
    SEKS
    You don't get any humming while driving?
  6. Jan 23, 2017 at 11:17 AM
    01GreenTacoma
    No humming while driving, just a clunk/thud at low speed braking.
  7. Jan 23, 2017 at 1:48 PM
    01GreenTacoma
    So I managed to get my truck at a good angle to take some pressure off of the front drivers wheel. I can feel slack in the upper ball joint when I hold my hand on it and wiggle the tire back and forth. The ball joints are only a few years old, sucks being the original set lasted about 12-13 years.
  8. Jan 31, 2017 at 7:26 PM
    01GreenTacoma
    Alright guys well guess what??????? I changed the ball joints out and my clunk is still there. The ball joints definitely had slack but that wasn't the root cause of the sound. I'm at a complete loss now....... I have shaken and pulled on everything i know to try and reproduce the sound but no luck. Maybe it's telling me its just getting old..... haha
  9. Feb 5, 2017 at 6:38 AM
    01GreenTacoma
    I wanted to give you guys an update on what I have found. I finally got time to do a complete front end disassembly and I feel my "clunk" was due to a broken lower strut bushing mount. It was allowing the strut to twist with brake pressure causing the clunking/thud. So I have my new bilstein 5100's on the way and should be good to go for the life of the truck. Anyone interested in some toytec 2.5" front aluminum spacers? I will be doing away with them since I'm moving to the 5100's.
