2001 tacoma timing issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by plumislandstriper, Nov 7, 2011.
  1. Nov 7, 2011 at 6:47 PM
    plumislandstriper
    plumislandstriper [OP] Member
    jesse
    ellis
    So got myself into a pickle. changing timing belt on truck and everything line up perfectly and new belt looked great but after turning engine over several time by hand i realized that though my cam marks and crank marks lined up great at tdc the belt marks moved one tooth evry time i brought crank back around to tdc. am i correct in assuming there is an issue and if so whats the fix.
  2. Nov 7, 2011 at 6:53 PM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    04 Tacoma DC PreRunner 2WD
    Magnaflow Catback System, King Coilovers, Total Chaos UCAs, Rear 5100, Deaver J59, Greasable shackles, rear steel braided brake hose, Timbren Rear Suspension Enhancement Kit, Kenwood DDX318 HU, JL Audio XD700/5 Amp, Infinity 6830Cs Front, Polk Audio DXi 570 Rear,Pioneer TS-SW2501S4 10" Sub/ Custom enclosure behind the rear seat.
    as long as the cams and crank shaft lines up with the marks you are fine, the marks on the belt are just for start point. I just did mine and ran into the same problem but the truck is running perfect.
  3. Nov 7, 2011 at 6:59 PM
    plumislandstriper
    jesse
    ellis
    it started an ran fine for 20 minutes, i burped the system and topped off all fluids and went on test drive and it seems now to be knocking a little like a diesel truck. oh and it started to over heat
  4. Nov 7, 2011 at 7:02 PM
    fidencio74
    Fidencio
    Escondido, CA.
    it was already there. I had the same issue about the knocking sound but it has been fine. I even took the truck to a mechanic and he told me that the sound is normal for the trucks and I wasn't going to be able to get rid of it. You won't notice it in a couple of days. I don't know about the over heat issue, That sounds like a problem but I don't think that is timing belt related. Did you replace the thermostat and water pump?
    any water leaks?
  5. Nov 7, 2011 at 7:07 PM
    plumislandstriper
    jesse
    ellis
    yeah i replaced water pump, tensioner, both idler pulleys and thermostat. the truck never knocked before i did the belt so im assuming that it has to be something i did, check engine light came on too so i figured maybe knock sensor unplugged but it didnt. Im now confused as to what to do next.
  6. Nov 7, 2011 at 7:09 PM
    fidencio74
    Fidencio
    Escondido, CA.
    Did the cams move when you were installing the belt?
  7. Nov 7, 2011 at 7:12 PM
    plumislandstriper
    jesse
    ellis
    no i was very careful about the camshaft marks and quadruple checked my work
  8. Nov 7, 2011 at 7:15 PM
    fidencio74
    Fidencio
    Escondido, CA.
    Are you sure that you don't have any water leaks? Did you install the thermostat gasket around it? Did you buy everything from the dealer?
  9. Nov 7, 2011 at 7:22 PM
    plumislandstriper
    jesse
    ellis
    the overheating issue is most likely an easy fix, my main concern is the dieseling sound and the check engine light. I work in a garage so guess ill attempt driving it to work and putting it on the scanner
