2001 Timing Belt Write Up Please.
Discussion in '1st Gen. Tacomas (1995-2004)' started by B-Field, May 30, 2010.
  1. May 30, 2010 at 1:40 AM
    B-Field
    B-Field [OP] Member
    Kyle
    01 PreRunner Limited
    I'm looking for a write up on how to do a timing belt change on a 2001. I have seen the links for a 1996 and read them. There are a few different things on the 01 and was wondering if anyone has seen a write up thats closer to my year. Thank you in advance.
    And if your curious my truck has 201k miles on it and this is my first timing belt and water pump change. No oil leaks or water problems. Just routine maintenance. 90k is way to early for me.
  2. May 30, 2010 at 5:52 AM
    Barnone
    Barnone Guest
    201k miles? You must have a four cylinder? If so, then you have a timing chain which doesn't require replacement.
  3. May 30, 2010 at 6:49 AM
    shift96
    shift96 Well-Known Member
    I can see the stock belt going those miles on a V6. I had 140K when I did my first belt and the belt had no signs of wear
  4. May 30, 2010 at 6:50 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    you make it 140k on one belt holy shit!!!!!
  5. May 30, 2010 at 6:55 AM
    shift96
    It's not crazy:D. My old 93 I went 200K on the belt and that belt looked great when I took it out. I won't do anohter on my until 01 around 300K:D nothing will hit on the 01 if it breaks
  6. May 30, 2010 at 10:35 AM
    B-Field
    B-Field [OP] Member
    Kyle
    Yes my truck is a V6 and completely stock with 201k. Which also means, no I havent ever changed the stock belt. I bought my truck new and take good care of it. My secret to good belt life is that I also keep the engine compartment clean from dirt, grime, oil or other type of FOD build up. Keeping the engine compartment clean prevents your belt from having premature or excessive wear. I'll take pictures of the engine copartment and replacement parts and post them online at the end of my project to support my theory on long life engines. I have the belt aready exposed and am looking for a good write up for a '01 replacent. any suggestions will be greatly appreciated.
  7. May 30, 2010 at 10:50 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
  8. May 30, 2010 at 1:18 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    im runnin about 180 on the stock belt. no problems yet. and i have not been anywhere close to gentle on my truck.
