2001 Toyota Scheduled Maintenance Guide
Discussion in '1st Gen. Tacomas (1995-2004)' started by scocar, Aug 27, 2011.
  1. Aug 21, 2012 at 1:14 PM
    scocar
    scocar [OP] Patron of the Farts
    You remember correctly.
  2. Sep 11, 2012 at 8:41 AM
    wkbrdtx
    wkbrdtx Member
    Houston
    1999 Tacoma 4WD Limited
    Supercharger, spray-in bed liner, bed cover
    I followed the schedule and when i got to the propeller shaft re-torqueing I discovered that they were so tight I could not loosen them to re-torque - so i just left them alone.
  3. Mar 19, 2013 at 10:57 AM
    White Monster
    White Monster Well-Known Member
    Central Florida
    2001 PreRunner
    US Navy Veteran
    Use Mobile 1 Extended Performance (EP) and double your oil change interval and go to 15,000 !!!
    I have tested my Inline 2.7L four-cylinder 3RZ-FE at both 14,200 and 18,500 with excellent results (meaning no abnormal engine wear or contaminates) and some TBN still remaining. My engine has 125,000 on it now, mostly easy, clean driving without loads or towing.
    :thumbsup:
    Averages: Both the universal and unit averages are running averages and change with the number of samples we analyze.
    Elements: Elements are quantified in the oil at parts per million levels (PPM). This list shows the most common sources of the elements in gasoline or diesel engine oil. Following each element is a description of where it comes from. They are grouped by category.
    Wear Metals
    Aluminum: Pistons, bearings, cases (heads & blocks).
    Chromium: Rings, a trace element in steel.
    Iron: Cylinders, rotating shafts, the valve train, and any steel part sharing the oil.
    Copper: Brass or bronze parts, copper bushings, bearings, oil coolers, also an additive in some gasoline engine oils.
    Lead: Bearings.
    Tin: Bearings, bronze parts, piston coatings.
    Nickel: Trace element in steel, platings on some cylinder types.
    Trace Elements
    Manganese: Trace element, additive in some foreign gasoline.
    Silver: Trace element, some types of bearings.
    Titanium: Trace wear metal.
    Contaminants
    Potassium: Antifreeze, additive in some oil types.
    Sodium: Antifreeze (ethylene glycol), additive in some gasoline engine oils.
    Silicon: Airborne dirt escaping air filtration, sealers, gaskets, sand-casted parts, and spray lubricants, antifreeze -inhibitor.
    Oil Additives
    Molybdenum: Anti-wear additive, some types of rings.
    Boron: Detergent/dispersant additive, antifreeze inhibitors.
    Calcium: Detergent/dispersant additive.
    Magnesium: Detergent/dispersant additive.
    Phosphorus: Anti-wear additive.
    Zinc: Anti-wear additive.
    Barium: Detergent/dispersant additive used in some synthetics.
    Physical properties
    Viscosity/Flashpoint: If fuel is present in the oil, the Viscosity and Flashpoint will often be lower than stated in the "Values Should Be" line. A high viscosity may show oil oxidation or high levels of soot. It can also show an oil additive in use.
    Fuel %: Indicates the amount of volatile fuel dilution found in the oil.
    Antifreeze %: Indicates the amount of antifreeze found in the oil. A question mark means we found possible traces of coolant, but not enough to definitively say it's there.
    Water %: Indicates the amount of water found in the oil.
    Insolubles %: Insolubles are solid materials present in the oil. They are typically free carbon from the oxidation of the oil itself, along with blow-by past the rings.
  4. Jan 1, 2014 at 9:45 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    hello. great post! does registering for that site give you history for any service done at the dealerships? Im the second owner of my 99 tacoma and the previous owner said he did all the service at the dealer. thanks
  5. Feb 10, 2014 at 8:36 AM
    scocar
    Not necessarily. I think they only go back to a certain point, or may depend on how dealers recorded data.
    For example, I have a 2001 with only one previous owner. He had hard copies of the major maint. records from the dealer, including T-belt change @90k. However, this is not shown in the online record.
  6. Jan 1, 2015 at 3:02 PM
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    When is the water pump and timing chain due on an 04 2.7? Im at 160,000
    I couldnt find anything telling me when.
  7. Jan 1, 2015 at 6:22 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Water pump when it starts leaking. Timing chain replace when it breaks. I wouldn't worry about either one.
  8. Jan 2, 2015 at 7:29 AM
    BrianLV
    Las Vegas
    04 Prerunner SR5
    I see, I'm not in your Prerunner cool kids club.
  9. Jan 3, 2015 at 8:59 AM
    ToyoTaco02
    Scott
    Decatur,IL
    I don't know what was meant by that statement. There is nothing maintenance wise that tells you when to replace either. I wouldn't worry about the water pump until it starts leaking or if you want just go ahead and replace it. With the timing chain these things can go 400,000 miles without needing replaced its a chain not a belt.
  10. Nov 28, 2016 at 1:06 PM
    roguewaave
    roguewaave Well-Known Member
    Texas/Maine
    stock
    stock
    Links are dead, damn lawyers
  11. Mar 12, 2018 at 8:31 AM
    Calion
    Calion Well-Known Member
    2002 Black Tacoma SR5 4x4
    Came used with brush guard, winch and bed cover.
    scocar[QUOTED][OP] likes this.
  12. Mar 12, 2018 at 10:38 AM
    scocar
  13. Jul 29, 2020 at 8:01 PM
    47Drvr87
    47Drvr87 Well-Known Member
    Charlie
    1999 Tacoma TRD
    Thanks for posting this OP!
  14. May 27, 2023 at 1:23 PM
    Tsean
    Tsean Well-Known Member
    Tsean
    mine is 2002 double cab 3.4L what do you suggest to fix my frame or get a new one how much will it cost me if i need to?
