2001 Toyota Tacoma Prerunner - Long Travel
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by SanClemTaco, Mar 6, 2020.
  1. Mar 6, 2020 at 2:19 PM
    SanClemTaco
    SanClemTaco [OP] Well-Known Member
    Sean
    San Clemente
    01 Prerunner on 37's
    Solo Motorsports XLT Kit, Giant 64
    For Sale:
    Truck purchased new by my father and in my possession for the past ten years
    Details and description below.
    $20,500 OBO
    Front Suspension:
    Solo Motorsports 2wd XLT Race Kit - Bumped and Strapped at 16.5 inches travel
    • 4.5” over stock per side
    • Boxed Upper Control Arms
    • Boxed Lower Control Arms
    • Fabricated 3” Lift Spindle
    • Dana 44 Hubs and Snouts
    • 12 mm Wheel Studs
    • Braided Stainless Steel Brake Lines
    • Heim Billet Aluminum Tie Rods
    Solo Motorsports Shock Hoops
    King 10” Coilovers - Internal Bypass (IBP), Remote Reservoir with Compression Adjuster
    King 2.0 x 2” Bump Stops - Bump Off LCA
    Rear Suspension:
    Giant Motorsports 64” Leaf Spring Kit - Bumped and Strapped at 17.5 inches travel
    • Relocated Front Spring Hanger
    • Relocated Shackle Hanger
    • 8” Tension Shackle
    • 64” SUA Leaf Spring
    • ⅝” U-Bolts
    King 16” Smooth Body Shocks - Piggyback Reservoir with Compression Adjuster
    King 2.0 x 4” Bump Stops
    Custom Fabricated Bed Cage
    Boxed and Gusseted rear frame rails
    Rear Axle:
    First Generation Tundra Axle - 66” WMS to WMS
    • Non-ABS Housing
    • 8.4 Third Member - 4.88 Gear Ratio
    • Eaton Tru-Trac Locker
    • Third Member Built by East Coast Gear Supply
    Wheels and Tires:
    Method 305 NV (MR30578560500)
    • 17” x 8.5”
    • 6 x 5.5” Bolt Pattern
    • 0 Offset, 4.75” Backspace
    BF Goodrich T/A KO2
    • 37” x 12.5” x 17
    Includes Full Size Spare - Never Used
    Engine:
    5VZ-FE - 3.4 L
    • K&N Intake (57-9015-1) - Carb EO: D-269-28
    • Doug Thorley Headers (THY-507-C) - Carb EO: D-540-6
    • Stock Catalytic Converters
    • Custom Cat Back Exhaust - Exit through Bedside
    Magnuson SuperCharger (01-62-34-003-BL) - Carb EO: D-488-42
    • 2.2” URD SuperGrip Pulley
    • URD Tensioner Pulley
    • URD 7th Injector Kit
    Transmission:
    A340E - 4 Speed Automatic
    • Auxilliary Transmission Cooler
    Brakes:
    Tundra Front Brakes - 13WL
    • Power Strop PWR-S2712 Calipers
    • EBC Greenstuff Brake Pads
    • EBC 3GD Series Rotors
    Sequoia Rear Brakes
    • Power Stop PWR-S3276 Calipers
    SOS Performance Rear Disk Brake Conversion Kit
    • Functioning Parking Brake
    SOS Performance Master Cylinder Conversion
    • Sequoia Master Cylinder - 15/16” Bore
    Wilwood Manual Proportioning Valve
    Bodywork:
    McNeil 6” Bulge Fiberglass Fenders
    Fiberwerx 8” Flat Top Bedsides
    Cab Clearanced for 37s at Full Bump, Lock to Lock
    Fiberglass clearanced for 37s at Full Bump
    Lighting:
    Single Piece Headlights
    • Turn Signal Relocated into Headlights
    Rigid D-Series SAE Fog Light (504813)
    • Legal for use on the highway
    GGLighting 30” G4D Light Bar
    Stock Tail Lights
    Audio:
    Kenwood KDC-MP345U Head Unit
    Infinity Reference 6830cs - Front Speakers
    Infinity Kappa 682.9cf Speakers - Rear Speakers
    Rockford Fosgate PS-8 - Powered Subwoofer
    Other:
    Battery Relocated Under Spare Tire
    • Space for Second Battery
    • Blue Seas Dual Battery Cutoff Switch
    Pro Eagle 3 Ton Off Road Jack
    • Stainless Steel Jack Mount
    • 8” Adjustable Extension
    • Jack Cover
    • Located Under Spare Tire
    Working Cruise Control
    Note: Dash Light does not work
    Custom, Bolt On, Front Bumper
    UltraGauge EM Plus - v1.4
    ~227,000 Miles - majority are freeway miles. Vehicle was a daily driver before being modified
    I may have missed some things. For questions please reach out.
    Partial Trade May be Considered:
    Presmog preferred
  2. Mar 6, 2020 at 4:29 PM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    San Antonio, Texas
    Supercharged 2012 TRD Sport DC
    Love the build man glws
  3. Mar 7, 2020 at 10:28 AM
    latchlock8111
    latchlock8111 Well-Known Member
    ... not sure if I have enough scratch for this one. Let me double check under my mattress ..
    ToyotaDriver likes this.
  4. Mar 7, 2020 at 12:10 PM
    BurgerTaco
    BurgerTaco Burger Slinger
    Redlands, CA
    04 Xtra Cab PreRunner
  5. Apr 12, 2020 at 6:24 AM
    manesfesto
    manesfesto Well-Known Member
    Jacob
    Texas
    2001 LT Double Cab
    Clean build, but $27k!!! I hope you get close to that because it means I can sell mine close to that.
    ninjaexplosion likes this.
  6. Apr 12, 2020 at 8:23 AM
    SanClemTaco
    Sean
    San Clemente
    if your interested make an offer. this isn't some beat high-schoolers truck and its priced accordingly.
    price out just the suspension work and the parts bill exceeds the asking price. that doesnt include the cost to source a truck or any of the other parts, labor, tools, or consumables that went into the build.
    everything done can be seen in the build thread so any work can be judged accordingly by any serious buyer.
  7. Apr 12, 2020 at 8:30 AM
    manesfesto
    Jacob
    Texas
    2001 LT Double Cab
    I get it. Everyone gets so defensive these days. I have a similarly built truck but it has four doors and is caged front to rear. Like I said, I hope you get what you’re asking. Glws
  8. Apr 12, 2020 at 11:55 AM
    Nickgbmx
    Nickgbmx Well-Known Member
    Nick
    2010 Tacoma Trd
    I hope this truck sells for every bit of the asking price. You couldn’t build it for anywhere near that, it’s all new and quality work. Good luck with the sale someone will get a rad truck!
  9. Apr 14, 2020 at 6:31 PM
    latchlock8111
    Say seller, I really like the storage cabinet in the background in the one photo trimmed out with vintage NHL hockey sticks. Very cool. Growing up I played with a Northland ... Sherwood and Koho came late to my game. Again, very nice, was that made by you ???
  10. Apr 14, 2020 at 8:01 PM
    SanClemTaco
    Sean
    San Clemente
    I did not build it, Craigslist find.
  11. May 5, 2020 at 7:25 AM
    SanClemTaco
    Sean
    San Clemente
    price reduced
  12. May 7, 2020 at 9:48 AM
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Escondido, CA
    Supercharged '14 Tacoma TX Baja 4x4
    We need video of this truck in action!
  13. May 7, 2020 at 11:12 PM
    joe25rs
    joe25rs Well-Known Member
    Joe
    Mrr’land
    2004 Black TRD
    This is one bad bitch! I bet this thing is a blast. Good luck with the sale!
  14. May 22, 2020 at 3:31 PM
    onequarteratatime
    onequarteratatime Well-Known Member
    Marietta, GA
    2019 Quicksand DCSB Tacoma TRD Off-Road
    GFC, Black Rhino Armory 17's, 285/70/17 Ridge Grapplers, ARB Awning, Decked System, Goal Zero 200W Solar setup, Expedition Essentials Dash mount system, OME EL096 rear leaf springs, Fox 2.0 Remote Rear Shocks
    Awesome machine and well worth the asking price! Amazing amount of work here! GLWS!
  15. Jun 1, 2020 at 7:42 PM
    SanClemTaco
    Sean
    San Clemente
    bump, price reduced
  16. Jun 30, 2020 at 8:22 PM
    SanClemTaco
    Sean
    San Clemente
  17. Jul 4, 2020 at 2:03 PM
    2004Taco
    2004Taco Well-Known Member
    Luis
    Lakewood, CA
    04 Double Cab PreRunner SR5 Trd
    Keep it! That truck is so nice!
  18. Aug 31, 2020 at 4:41 AM
    Frank319
    Frank319 Well-Known Member
    Monterey County California
    Nah, the build sucks.. it doesn't have bluethooth lol jk man, good luck with the sale
  19. Oct 2, 2020 at 7:15 PM
    SanClemTaco
    Sean
    San Clemente
    bump, price drop
    Dalandser likes this.
  20. Oct 5, 2020 at 11:47 AM
    Dalandser
    Anthony
    Downey, LB
    Empty Wallet Mod
    Wow. Buy aftermarket parts and install shop fee, free truck included.
