2001 Vacuum Switch Valve or Solenoid
Discussion in '1st Gen. Tacomas (1995-2004)' started by travis500, Apr 25, 2023.
  1. Apr 26, 2023 at 10:02 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    pretty much it was years ago.
    no trouble codes so i just left it alone now for years.
  2. Jul 28, 2023 at 12:05 PM
    Ramphonic
    Ramphonic Well-Known Member
    Cape Cod
    2k1 SR5 4x4 V6
    Adjustable Bilstein, AAL Lift, Eagle Rims with BFG ATs, Trd Exhaust, Clear Corners, Red Clear Tails
    Did anyone ever find out if the two were interchangeable??
    Toyota says this was discontinued. 25860-75220
  3. Jul 28, 2023 at 12:14 PM
    travis500
    travis500 [OP] Well-Known Member
    Travis
    Denver
    2001 M/T 3.4 Xtracab 230k
    @Ramphonic
    Meant to update and spaced...
    Ive been using the new part for couple months now and a few thousand miles. No CEL so far.
  4. Jul 28, 2023 at 1:06 PM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
  5. Sep 2, 2023 at 3:46 PM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
  6. Sep 2, 2023 at 4:35 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  7. Dec 8, 2023 at 3:34 PM
    travis500
    Travis
    Denver
    @Ramphonic Are you still getting codes? Which codes?
  8. Mar 3, 2024 at 5:57 PM
    Zondar
    Zondar New Member
    Jeff
    01 Tacoma
    I have the same one pictured in travis500's Post #1. Part number 269-75230, 101362-2200, 220 shows up on Amazon as "fits your vehicle". I see someone tried it and it didn't work? I thought I saw a post that had an Ohm reading for the original. I get a 1.1 ohm reading, same as touching probes together, so I'm thinking I need a new one. I've never noticed a ticking noise from mine though. Got CEL and had them read the code at Auto Zone, forget the code but it was "Excessive Exhaust Gas Recirculation". I replaced the EGR valve as I figured that was most likely to be the issue, but no difference. (Lol, and learned here that was the least likely to fail)
    1996-01 TOYOTA CAMRY OEM VACUUM SWITCH VALVE VSV # 90910-12201 or 90080-91203 | eBay Will this work? I'd prefer to use something as close to OEM as possible. Seems other Camry stuff was used too.
    Of if your the anal type.....
    For Toyota Tacoma AISIN Vacuum Switching Valve 2.4L 2.7L L4 1995-2004 1n | eBay Does it attach to the original rubber damper?
    Hoses look good but are dry so will get new ones. Truck runs & starts great as always. Exhaust is getting louder. Could cause the CEL? Thinking I'll go with Stainless Steel system from 4x4 Parts as it's not much more. Figure I'll get a new O2 sensor when I do that. Also wondering if it's possible to check for vacuum/switching while it's running as I don't have a vacuum tool.
    Truck is in great shape as it's spent 80% of it's life in a garage and not much in the mud. The frame replaced before I bought it in 2003(has the bar code sticker). Probably in New Jersey where it's originally from.
  9. Mar 4, 2024 at 7:48 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    What code do you have? I had a P0446 for a while that was fixed by replacing my rear O2 sensor. I replaced it for a P0420 code but it appeared to be resolved after that. Never heard anyone else having the same experience.
  10. Mar 6, 2024 at 10:03 AM
    Zondar
    Zondar New Member
    Jeff
    01 Tacoma
    I didn't write it down. I'll get the code next time I visit a parts store.
  11. Aug 25, 2025 at 7:08 PM
    Machine_Ruse
    Machine_Ruse Member
    '02 TRD DBL Cab
    Just so I understand this...you had a P0446 (EVAP code) that you never intentionally did anything about, but it went away after you also started getting a P0420 and changed your rear O2 sensor?
    I've been trying to resolve this EVAP code on my '02 TRD (and the eff'ing Smog certificate is due in a few months!). I already tried the vacuum switching valve, but that didn't help. I'll probably try replacing the purge valve (since' it's 23 years old anyways), but to be honest, that valve is bench testing just fine. The rollover valve, which would be a PITA to deal with is the last culprit to try. Changing an O2 sensor would be a lot easier, lol.
  12. Aug 26, 2025 at 10:46 AM
    ztwatson
    Milwaukee, WI
    Yup that’s correct. Changed the rear O2 sensor while trying to chase a P0420 code and it ended up resolving the P0446 code.
    Machine_Ruse[QUOTED] likes this.
