2002 2.7 Tacoma Check Engine Light w/ Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wood's Double Cab, Mar 1, 2010.
  1. Mar 1, 2010 at 8:21 AM
    Wood's Double Cab
    Wood's Double Cab [OP] Can't Have Nothin'
    Pamplico, South Carolina
    '02 Tacoma DC PreRunner SR5 TRD Off-Road
    Alarm, Nerf Bars, Vent Visors, Bug Deflector
    hey y'all,
    my check engine light is on and thanks to my dad's handy-dandy actron scanner, i received a P1135 code but have no description for that particular code. ran real-time on it and showed that O2 sensor 2 read 0 voltage. can i deduct that the #2 O2 sensor is bad from this or am i going to have to go to the recall dealer and spend $ for 3 minutes worth of having the right scanner to figure it out?
    thanks in advance,
    wood
  2. Mar 1, 2010 at 9:51 AM
    PacNWgen1
    PacNWgen1 NewHere
    Adam
    Oregon
    96' Tacoma Reg Cab 2.7l 4x4 5-speed 150,000+
    DynoMax ST, Deck Plate, Full Syn, Soon Header and Slotted Rotors
    I am no expert but here is what the code says.
    P1135
    Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1)
    I think it is the closest one to the engine before the CAT. Hope this helps.
  3. Mar 1, 2010 at 11:53 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    P1135 means a fault with the A/F sensor (aka O2 sensor, bank 1 sensor 1) heater circuit. Possible causes:
    - Open or short in the A/F sensor heater circuit
    - A/F sensor heater fault
    - ECM
