2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Sep 4, 2016 at 10:58 PM
    #2161
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Imitation is the highest form of flattery...
    cbechtold, Blackdawg and Delta00[OP] like this.
  2. Sep 4, 2016 at 11:02 PM
    #2162
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Gotcha.
    We'll have fun with that haha can't bring myself to make my own..yet. Was a lot of work.
  3. Sep 4, 2016 at 11:02 PM
    #2163
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd be happy to assist you by taking that rear bumper off your hands...
  4. Sep 4, 2016 at 11:03 PM
    #2164
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't think he will have problems moving that bumper. Cover the costs of a homemade one easy
    Delta00[OP] likes this.
  5. Sep 4, 2016 at 11:05 PM
    #2165
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    @BYJOSHCOOK has fist dibs haha
    I know its going to be a lot of work, it takes me about three weeks to do any of the projects ive done (bed rack, skid plate) i see the bumper taking a lot more time...
    BYJOSHCOOK likes this.
  6. Sep 4, 2016 at 11:05 PM
    #2166
    Speedytech7
    Yeah, I'm not too picky about my truck's looks. I'd just hack the current bumper into something I like and call it a day. But yeah I bet he'd have extra after selling and building a new one with swingout.
  7. Sep 4, 2016 at 11:25 PM
    #2167
    Blackdawg
    Monte
    Wyoming/St. Louis
    Long long time indeed.
    Delta00[QUOTED][OP] likes this.
  8. Sep 5, 2016 at 6:33 AM
    #2168
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Hey now ;)
  9. Sep 5, 2016 at 6:35 AM
    #2169
    Speedytech7
    Can't blame a guy for trying. :oops:
  10. Sep 5, 2016 at 6:36 AM
    #2170
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Oh I know. I heard Troy a while back say something about making his own. I was like dibs on your current one. Haha
  11. Sep 5, 2016 at 8:43 AM
    #2171
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    In the long term, I'd like to have the compressor under the hood in the usual spot and have a tank under the bed. Then I want hook ups on both the front and rear bumper
  12. Sep 5, 2016 at 8:55 AM
    #2172
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I had my compressor under the hood of my 2nd gen. If you see muddy conditions at all, you will not be able to keep it from getting dirty. Maybe you're cool with that, maybe not. I didn't like it so I put it in the cab of the 1st gen. Something to consider at least.
  13. Sep 5, 2016 at 9:13 AM
    #2173
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'm going to copy yours when the time comes for OBA
    Delta00[OP] and rngr[QUOTED] like this.
  14. Sep 5, 2016 at 9:30 AM
    #2174
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Go right ahead. I'm happy with it.
  15. Sep 5, 2016 at 9:51 AM
    #2175
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Honestly the best way I've seen it set up on a first Gen. Since we don't have a lot of room anywhere
    rngr[QUOTED] likes this.
  16. Sep 5, 2016 at 9:54 AM
    #2176
    MatthewMay1
    Matthew
    Lone Star Republic
    I don't want to hear it inside. Where is yours mounted?
  17. Sep 5, 2016 at 10:03 AM
    #2177
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Under the back seat.
    https://www.tacomaworld.com/threads/re-demption-rngrs-re-debatable-re-debacle.443620/page-7
    Hear it? That won't be a problem. You'll be outside the cab when airing up tires. Even if you are running air lockers it's just the initial bump to pressurize the line then it shuts off. Plus, I can assure you, you can hear it just as good under he hood as where I have it mounted.
    Not trying to to sway you, this is just what I've noticed with mine.
  18. Sep 5, 2016 at 10:06 AM
    #2178
    Delta00
    Troy
    Chandler AZ
    Check Build
    That's does look really good..
  19. Sep 5, 2016 at 10:08 AM
    #2179
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Thank you.
  20. Sep 5, 2016 at 3:00 PM
    #2180
    MatthewMay1
    Matthew
    Lone Star Republic
    See I'm a double cab and don't have that sneaky cubby
