2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Sep 5, 2016 at 3:07 PM
    #2181
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Nothing under the rear seats at all?
  2. Sep 5, 2016 at 3:08 PM
    #2182
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Not that I'm aware of. The backs fold down and the bottoms are bolted down to the floor
  3. Sep 5, 2016 at 3:09 PM
    #2183
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Well dang. I tried. Ha ha.
  4. Sep 5, 2016 at 3:12 PM
    #2184
    MatthewMay1
    Matthew
    Lone Star Republic
    Yeah I'm not sure where I could put it inside the cab. Probably going in the engine bay. I can always just clean it when it gets dirty...
  5. Sep 5, 2016 at 3:13 PM
    #2185
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    If you're looking an air compressor, Viair will be better bet. The little ARBs will burnout if you try doing anything else that isn't locking the ARB Air Lockers.
  6. Sep 5, 2016 at 3:14 PM
    #2186
    MatthewMay1
    Matthew
    Lone Star Republic
    Was leaning to a Viair 440 or whatever it's called. My thing is that I want to have a 3-5 gallon air tank also
  7. Sep 5, 2016 at 3:16 PM
    #2187
    cbechtold
    Cory
    Pleasanton, CA
    Either way, I'd go with either a Viair or a 15lb tank, assuming you're just airing up tires.
  8. Sep 5, 2016 at 3:16 PM
    #2188
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Yea, that'll work.
    This^^ they make a 100% duty cycle compressor that I would go with if I had it to do over.
  9. Sep 5, 2016 at 3:17 PM
    #2189
    MatthewMay1
    Matthew
    Lone Star Republic
    I want to fit the largest air tank I can under the bed without limiting ground clearance. BUT, that's in the long term. I won't do that until after I relocate the rear shocks.
  10. Sep 5, 2016 at 3:18 PM
    #2190
    cbechtold
    Cory
    Pleasanton, CA
    If you're putting a tank under the bed, then make sure to build a skid plate for it.
  11. Sep 5, 2016 at 3:19 PM
    #2191
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    *cough*co2*cough*
    BYJOSHCOOK and cbechtold like this.
  12. Sep 5, 2016 at 3:22 PM
    #2192
    MatthewMay1
    Matthew
    Lone Star Republic
    Oh for sure. That wouldn't be an issue at all.
    I know I know... I don't want to have to carry around a bottle and then have to have it refilled too
  13. Sep 5, 2016 at 3:24 PM
    #2193
    Blackdawg
    Monte
    Wyoming/St. Louis
    Meh. Refill it what? Once every two years? How often do you air down? And you have 33s. 20lbs lasts a long time with 33s.
    Bottle is no different then the tank. Not that bulky and easy mounting solutions.
  14. Sep 5, 2016 at 3:26 PM
    #2194
    MatthewMay1
    Matthew
    Lone Star Republic
    Hmm, I didn't know it lasts that long... Thing with just an air tank is that I'd have it hidden and you wouldn't be able to see the system at all. No big ugly tank anywhere taking up space in my midget bed
  15. Sep 5, 2016 at 3:40 PM
    #2195
    Blackdawg
    Monte
    Wyoming/St. Louis
    Put it on the rear bumper or don't leave it in the truck at all times.
    When I had 33s I filled up a lot and many friends with it before it ran out.
    It lasts a long time and if you aren't wheeling regularly then I won't be a problem.
    Long as you stay with 33s though compressor is fine. I just like :stirthepot: but if you ever go to 35s. Screw that. Co2 for sure
  16. Sep 5, 2016 at 3:42 PM
    #2196
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Agreed. For filling tires CO2 all the way.
  17. Sep 5, 2016 at 3:43 PM
    #2197
    MatthewMay1
    Matthew
    Lone Star Republic
    35"s aren't in the foreseeable future while it's a daily driver. What's your opinion on having a 5 gallon air tank under the bed? I think it might be neat, but not sure how quickly it'll get depleted. My main use will be airing up tires, and mayyyybe using an impact gun for emergencies
  18. Sep 5, 2016 at 3:46 PM
    #2198
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not worth it for tires at all. Air tools sure. But unless you use them often. Tank is worthless. The compressor won't catch up to fill the tank once it's depleted after filling a tire
  19. Sep 5, 2016 at 3:47 PM
    #2199
    MatthewMay1
    Matthew
    Lone Star Republic
    See that was my concern
  20. Sep 5, 2016 at 3:48 PM
    #2200
    Blackdawg
    Monte
    Wyoming/St. Louis
    Id skip it. Get the dual arb if you can afford it. Or the puma one is 100% duty and puts out some major cfm.
