2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Dec 19, 2016 at 6:45 PM
    #2561
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Got my led map and dome lights in! They look great. Very white light and illuminates everything.
    @Digiratus
    jubei, synergy10, rngr and 3 others like this.
  2. Dec 19, 2016 at 6:50 PM
    #2562
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    Nice. Where did you get those?
  3. Dec 19, 2016 at 6:51 PM
    #2563
    Delta00
    Troy
    Chandler AZ
    Check Build
    Got them from @csjumper2003
    stumbles[QUOTED] likes this.
  4. Dec 19, 2016 at 7:05 PM
    #2564
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Lookin good man.
    Delta00[QUOTED][OP] likes this.
  5. Dec 19, 2016 at 8:10 PM
    #2565
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I don't have map lights. Base model problems? :notsure:
    Looks good man.
  6. Dec 19, 2016 at 8:13 PM
    #2566
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks!
    Interesting, I would think that yours would have it. Ive heard you can swap them over though i think.
    rngr[QUOTED] likes this.
  7. Dec 19, 2016 at 8:38 PM
    #2567
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow, looks good man. With all three on, Its bright. You almost need sunglasses. :rolleyes: I like the color.
    Hows is it with just the dome light. Does the normal shutdown delay still work the same? <door left open, light stays on for a few minutes before shutting down, even with the door still open>
    This is how I use it when adventuring. Nice to be able to see the contents of the fridge in the backseat without a flashlight.
  8. Dec 19, 2016 at 9:10 PM
    #2568
    Delta00
    Troy
    Chandler AZ
    Check Build
    Here is with just the dome light. However I left the driver side door open for quite some time and it never turned off. But I don't know if that's differences in years, I don't recall mine ever turning off. The LEDs are acting just like the bulbs so far from what I remember. Also, it looks brighter in person.
    Digiratus[QUOTED] and stumbles like this.
  9. Dec 19, 2016 at 10:09 PM
    #2569
    Digiratus
    Roaming the PNW
    The RedHead
    That looks plenty bright. Quite a bit brighter than stock for sure.
    Delta00[OP] likes this.
  10. Dec 19, 2016 at 10:48 PM
    #2570
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Why didn't you just come look at mine in October haha
  11. Dec 20, 2016 at 2:57 PM
    #2571
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Been wanting to do this since I got my truck...still haven't gotten around to it
  12. Dec 20, 2016 at 3:03 PM
    #2572
    Delta00
    Troy
    Chandler AZ
    Check Build
    It's nice, very bright! My dome light burned out and I really missed it, had to replace with led ASAP.
  13. Dec 20, 2016 at 3:04 PM
    #2573
    MatthewMay1
    Matthew
    Lone Star Republic
    My lights pulse when you have them on at idle....rather irritating
  14. Dec 21, 2016 at 11:58 AM
    #2574
    Digiratus
    Roaming the PNW
    The RedHead
    If i'd known you had them, I would have.
  15. Dec 29, 2016 at 9:25 PM
    #2575
    Delta00
    Troy
    Chandler AZ
    Check Build
    Got my TWSS gift! Soft shackles and quick fists! The soft shackles look awesome!
    cbechtold, rngr, Boogyman and 2 others like this.
  16. Dec 30, 2016 at 11:05 AM
    #2576
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    :wave:
  17. Jan 7, 2017 at 4:39 PM
    #2577
    Delta00
    Troy
    Chandler AZ
    Check Build
    First time truck has seen snow, happy with how it drove! Got much more snow later in the day. Need to spray everything down, it's is crazy dirty after everything melted.
  18. Jan 15, 2017 at 11:31 PM
    #2578
    Overland_Tennessee
    Overland_Tennessee I don't even own a Tacoma
    TENNESSEE
    05 4Runner
    Dobinsons Remote Reservoir & things
    After hours of searching for caliper color options, I ran across this. I am so glad you have the same wheel and color as me. You've made my mind up!
  19. Jan 16, 2017 at 8:50 AM
    #2579
    Delta00
    Troy
    Chandler AZ
    Check Build
    Awesome, throw some pics up when you get it completed!
  20. Jan 18, 2017 at 10:15 AM
    #2580
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Did you paint your paint your chrome grill, or buy a color matched one?
