2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Jul 25, 2017 at 10:33 AM
    #2721
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    It's an R150f. I believe they're all the same.
  2. Jul 25, 2017 at 10:36 AM
    #2722
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't think my truck on 31s could hit 100mph in 4th. To pass anyone I had to drop to 3rd.
    Your situation sounds completely untypical.
    I couldn't even use 5th gear when I had 35s and 4.10s for the short time I did.
    Ultimately though the #1 reason for picking gears that should be taken into consideration is how you plan on using the truck.
    PROseur likes this.
  3. Jul 25, 2017 at 10:09 PM
    #2723
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Regearing is still by far the best mod I have done. So worth it. Troy, for how your truck is currently configured, I think you will be very happy with 4.56s.
  4. Jul 26, 2017 at 11:40 AM
    #2724
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Thank you, with everything I've read so far that's what I thought also. I'll probably be regearing by the end of August. I drove another manual with 4.56 and it did feel better. @JTB727
  5. Jul 26, 2017 at 11:46 AM
    #2725
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    Those of you questioning, connor has a weird way of keeping his momentum up off-road....but for me personally, i still get into situations occasionally that I feel 4.88s with the manual would be nice...
    I HATED my truck with 4.10s and 33's with armor. It was a dog. Going up to payson i would be in 3rd gear and climbing the hills at 50mph.... I love my gearing change. Best thing i ever did to the truck. Especially because i went from open open to locked front and rear.
  6. Jul 26, 2017 at 12:12 PM
    #2726
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I still get into situations where I feel 5.29s would be nice...
    I love my 4.88s, but wheeling at elevation it still is hardly enough. I end up riding the clutch to get up obstacles. Luckily I have lots of practice doing so from all the awful time wheeling with 4.10s. Excellent on the roads though, except the interstate which I hardly ever drive.
    jubei, JTB727[QUOTED] and Delta00[OP] like this.
  7. Jul 26, 2017 at 12:19 PM
    #2727
    Blackdawg
    Monte
    Wyoming/St. Louis
    I love 5.29s with the manual and 35s. Brett and i did a "drag" race in 4lo and its almost exactly the same as 4.88s with 33s and a manual. It is amazing offroad. Low gearing is the shit. And i never ever have to down shift to pull big hills anymore. Hell i can accelerate in 5th up hill now and that was before i added boost.
    JTB727, Delta00[OP] and jubei like this.
  8. Jul 26, 2017 at 12:20 PM
    #2728
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I'm on 35s and 5.29s and the gearing is absolutely perfect. I know that's not where Troy is going with his build, but the point is that regearing (and in my case, overgearing) was the best "bang for the buck" mod that I've done to my truck. It's very peppy around town off the line, it runs around 3300-3500 at 75-80mph, and it's absolutely killer in 4LO. I have a crawl box that will get installed someday, but for 90% of my wheeling, it's not remotely necessary with my gears. When I get a SC, the truck will absolutely scream.
    The caveat is that I don't care about mileage beyond being a metric for the health of the engine and miles until empty. I have a DD, so it's not a focus for me. So having the 3.4 at those higher RPMs on the freeway doesn't bother me, and in fact means that I can pull up the passes in 4th gear, no problem. And that's with the RTT and gear.
    TL;DR: Regearing is the shit if you have the coin to pull it off. (Especially if it gets you locked front and rear).
    Delta00[OP] and BYJOSHCOOK like this.
  9. Jul 26, 2017 at 12:21 PM
    #2729
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Damnit! Going back and forth between 4.56s and 4.88s now :annoyed:
    Delta00[OP] likes this.
  10. Jul 26, 2017 at 12:21 PM
    #2730
    jubei
    NoCo
    Stuff. Also things.
    4.88 and 33s in a manual is slightly overgeared about as much as the 5.29/35/manual combo, right?
  11. Jul 26, 2017 at 12:22 PM
    #2731
    jubei
    NoCo
    Stuff. Also things.
    :gossip:
    4.88...
    BYJOSHCOOK[QUOTED] likes this.
  12. Jul 26, 2017 at 12:24 PM
    #2732
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.88s for an offroad rig. 4.56 for a DD/weekend warrior.
    Yep. Almost exactly.
  13. Jul 26, 2017 at 12:28 PM
    #2733
    BYJOSHCOOK
    Josh
    Check Out My Builds
    well for now it's a DD/weekend warrior, but it won't stay that way which has me leaning towards 4.88s now in that I don't wanna regear twice unless it's for 35's (which at this time is not in the plans)
  14. Jul 26, 2017 at 12:36 PM
    #2734
    Blackdawg
    Monte
    Wyoming/St. Louis
    go 4.88s. I think with the roof rack alone you'd be glad you did.
  15. Jul 26, 2017 at 12:42 PM
    #2735
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I think it'll help a ton off-road too. Have yet to put any dirt miles on the new tires hopefully soon now that school is done
  16. Jul 26, 2017 at 2:35 PM
    #2736
    JTB727
    Justin
    AZ
    I got my entire set up for 500 bucks with 456s. If i paid full price I would have gone 4.88.
  17. Jul 26, 2017 at 2:44 PM
    #2737
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Lucky bastard!
  18. Jul 26, 2017 at 2:52 PM
    #2738
    cynicalrider
    cynicalrider #NFG
    Jersey
    +1 to both of these. I went 5.29 to avoid a crawl box and I most definitely nearly accomplished my goal. Even on the harder trails I basically point the truck where I want it to go and it goes.
    jubei[QUOTED] likes this.
  19. Jul 26, 2017 at 2:54 PM
    #2739
    JTB727
    Justin
    AZ
    With lockers!
  20. Jul 26, 2017 at 7:17 PM
    #2740
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    When you have baby tires, gearing is not an issue :p
