2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Feb 28, 2015 at 7:29 PM
    #361
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You getting sliders?
  2. Feb 28, 2015 at 7:34 PM
    #362
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Eventually, not the highest on the list yet.
  3. Feb 28, 2015 at 7:45 PM
    #363
    BYJOSHCOOK
    Josh
    Check Out My Builds
    What's next then?
  4. Feb 28, 2015 at 7:51 PM
    #364
    Delta00
    Troy
    Chandler AZ
    Check Build
    Probably in this order
    1. Get LED bar and pods
    2. Wire up LED bar and pods
    3. Rims
    4. Tires
    5. Sliders
    6. Regear
    7. Probably a lot of other stuff that im forgetting.
    I want to make my own sliders (and rear bumper :spy: ) and im currently taking welding classes so its going to be awhile before I attempt something like that.
    :D
  5. Feb 28, 2015 at 8:36 PM
    #365
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I think you can skip #2 ;) you don't need to wire anything haha
  6. Feb 28, 2015 at 8:38 PM
    #366
    Delta00
    Troy
    Chandler AZ
    Check Build
    Its just for looks no need for wire ;)
    I have 3 switches, that 6 switch holder, and possibly a new radio that i want to install at the same time so gotta gather everything first.
  7. Feb 28, 2015 at 8:45 PM
    #367
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I got mine today and I only have 1 switch :anonymous:
  8. Feb 28, 2015 at 8:57 PM
    #368
    Delta00
    Troy
    Chandler AZ
    Check Build
    Blanks for the rest! Or get 5 other switches and wire them so they just light up which I might do...
  9. Feb 28, 2015 at 9:02 PM
    #369
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I was gonna do that, just not sure what switches/accessory I'm gonna get haha
  10. Feb 28, 2015 at 9:08 PM
    #370
    Delta00
    Troy
    Chandler AZ
    Check Build
    Yeah that was my dilemma. I think ill just go with blanks for now...
  11. Feb 28, 2015 at 9:38 PM
    #371
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Definitely recommend wiring everything at once. Much easier in the long run.
  12. Feb 28, 2015 at 9:43 PM
    #372
    Delta00
    Troy
    Chandler AZ
    Check Build
    Haha you're the reason I was thinking about doing that. Basically copying your switch setup, it looks so clean :anonymous:
  13. Feb 28, 2015 at 9:46 PM
    #373
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Which wires for the switches can you wire like that?
  14. Feb 28, 2015 at 9:46 PM
    #374
    PcBuilder14
    Brent
    Nor Cal
    Thanks! I think they look very nice when fully set up.
    Just sucks not having all of them do things, causing you to want to hurry up and spend money on more lights... :eek:
    I personally recommend that if you plan on doing dual batteries or run a lot of switches like that, try to hold off until you can get everything at once. I know it's a challenge, but it'll make things much easier and be fun to get all the wiring stuff done in one run instead.
    I was able to wire everything behind the switches to my auxiliary relay box. Only one of the switches actually controls lights right now, but they're all wired to relays which means all I have to do when I get new lights is hook the positive wire to the correct relay and then just ground it.
  15. Feb 28, 2015 at 9:48 PM
    #375
    Delta00
    Troy
    Chandler AZ
    Check Build
    Very true, I want to get everything in one go. Waiting does suck...
  16. Feb 28, 2015 at 9:49 PM
    #376
    PcBuilder14
    Brent
    Nor Cal
    Haha kind of why I'd like to start over again...
  17. Feb 28, 2015 at 9:50 PM
    #377
    Delta00
    Troy
    Chandler AZ
    Check Build
    Do you mean what size wire?
  18. Feb 28, 2015 at 9:51 PM
    #378
    Delta00
    Troy
    Chandler AZ
    Check Build
    1st gen black double cab??? :p
  19. Feb 28, 2015 at 9:52 PM
    #379
    PcBuilder14
    Brent
    Nor Cal
  20. Feb 28, 2015 at 9:55 PM
    #380
    Delta00
    Troy
    Chandler AZ
    Check Build
    Yeah, i'd rather not cut it close. 14 gauge looks good and I have a lot of it that needs to be used up.
    Double cabs really shoot up the price... $$$
