2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Mar 9, 2015 at 10:30 PM
    #521
    PatriotOfAmerica
    PatriotOfAmerica Well-Known Member
    Reed
    Good Ole' Kentucky
    03 Jade Mica DC TRD 4x4
    33'' kanati mud hogz arb front bumper are camper shell 42'' cree light bar color match fender flares
    yeah i eventually want to replace my double row with a sr-25 combo single row
  2. Mar 9, 2015 at 10:38 PM
    #522
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Not necessarily. I have seen plenty of them to tell the good from the bad. Theres definitely better and worse, clearly Rigid's are at the top end, theres a lot of decent Chinese bars as well. Not up to Rigid but not crap either. Though there are some crap chinese bars out there!
  3. Mar 10, 2015 at 6:45 PM
    #523
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Pretty stoked to see the bar... Did you order yet??
  4. Mar 10, 2015 at 6:46 PM
    #524
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    im ready to see some bar action!
  5. Mar 10, 2015 at 6:48 PM
    #525
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Still waiting on a PM back, told him what I wanted and he said he would get a price.
    But most likely will order depending on price haha :D
  6. Mar 10, 2015 at 6:48 PM
    #526
    Delta00
    Troy
    Chandler AZ
    Check Build
    Me also!
  7. Mar 10, 2015 at 6:52 PM
    #527
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
  8. Mar 11, 2015 at 8:37 AM
    #528
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Reading your build now, really cool!
    Question, did you install the ext. brake line at the same time as the rear lift? I'm not sure if I should worry about the brake line before the lift or can I do it after. Also, how easy were the brakes to bleed, did you bleed all four or just the rears? Thanks
  9. Mar 11, 2015 at 9:30 AM
    #529
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks!
    I put my extended brake line on after the lift. However I absolutely recommend doing it before. The extra three inches allows for the axle to droop a bit more and allows you you to line up the spring perch with the center pin a lot easier.
    Brakes were super easy to bleed! Just hook up some plastic clear tubing over the brake line bleeding nipple and keep pumping and bleeding until you see absolutely no bubbles. I only bleed did the rear brakes after the install. Also, make sure you have some extra brake fluid and add as you go, you don't want to suck in more air!
  10. Mar 11, 2015 at 3:54 PM
    #530
    quetzal
    Mario
    Long Beach, CA
    Thanks for the response and recommendations. I think I'll change the line before I install the lift. :cool:
  11. Mar 11, 2015 at 3:55 PM
    #531
    quetzal
    Mario
    Long Beach, CA
    By the way, that's your truck on TWs header isn't it? Very cool!!!
  12. Mar 11, 2015 at 3:56 PM
    #532
    Delta00
    Troy
    Chandler AZ
    Check Build
    I wish i would have done it before!
    What line are you going with?
  13. Mar 11, 2015 at 3:57 PM
    #533
    Delta00
    Troy
    Chandler AZ
    Check Build
    It is!
  14. Mar 11, 2015 at 4:02 PM
    #534
    quetzal
    Mario
    Long Beach, CA
    I picked up whatever Wheelers' sells. When bleeding, you start w/the rear passenger since it's the furthest from the master cylinder, correct?
  15. Mar 11, 2015 at 4:03 PM
    #535
    Delta00
    Troy
    Chandler AZ
    Check Build
    Nice! Very good product.
    And yes, passenger rear is the first one you want to bleed.
  16. Mar 11, 2015 at 4:06 PM
    #536
    quetzal
    Mario
    Long Beach, CA
    Thanks. Again, love your build!!!
  17. Mar 11, 2015 at 4:36 PM
    #537
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks!
    All it needs is a sun roof ;)
  18. Mar 12, 2015 at 8:26 AM
    #538
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Congrats on making TacomaWorld Banner!
  19. Mar 12, 2015 at 8:35 AM
    #539
    johnboyTRD
    South SF bay
    Hey that's pretty cool, nice one! Purdy truck :thumbsup:
  20. Mar 12, 2015 at 9:05 AM
    #540
    quetzal
    Mario
    Long Beach, CA
    :D
