2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Mar 22, 2015 at 8:35 PM
    #581
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
  2. Mar 22, 2015 at 8:42 PM
    #582
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I didn't think the inlet/outlet made a difference?
  3. Mar 22, 2015 at 8:49 PM
    #583
    Delta00
    Troy
    Chandler AZ
    Check Build
  4. Mar 23, 2015 at 12:41 AM
    #584
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I did the chambered magnaflow 18 offset offset and I like mine.
    Edit
    I did the catback with 2.25 piping. Then a turn down immediately after the muffler.
  5. Mar 23, 2015 at 12:49 AM
    #585
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    That won't work with stock tubing unless you get a few fittings. You need a straight through one like the aero. When are you available to come hear it. Tomorrow? Monday meet?
  6. Mar 23, 2015 at 11:50 AM
    #586
    Delta00
    Troy
    Chandler AZ
    Check Build
    Cant make meets as I have school during that time.
    Did you install the LCA with Hector? If not, i could swing by then and BS most likely.
  7. Mar 25, 2015 at 3:16 PM
    #587
    Delta00
    Troy
    Chandler AZ
    Check Build
    Ordered the rest of my OTRATTW switches so i can prewire everything!
    Should see some mods rolling in eventually... :D
  8. Mar 25, 2015 at 3:17 PM
    #588
    JuansTaco
    Juan
    gilbert az
    Which panel did you get? The paranoid one? I built mine that fits below my single Din
  9. Mar 25, 2015 at 3:21 PM
    #589
    Delta00
    Troy
    Chandler AZ
    Check Build
    Yeah, already have it. Got it in the TW SS event :)
  10. Mar 25, 2015 at 3:23 PM
    #590
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Bout damn time :rolleyes:
  11. Mar 25, 2015 at 3:23 PM
    #591
    Delta00
    Troy
    Chandler AZ
    Check Build
    Ive only had it for about 4 months.... haha
  12. Mar 25, 2015 at 3:27 PM
    #592
    Delta00
    Troy
    Chandler AZ
    Check Build
    Also painted it.
  13. Mar 25, 2015 at 3:29 PM
    #593
    JuansTaco
    Juan
    gilbert az
  14. Mar 25, 2015 at 3:32 PM
    #594
    Delta00
    Troy
    Chandler AZ
    Check Build
    Hmm that sounds pretty good, ill still need to hear the aero to make my final decision :D
  15. Mar 25, 2015 at 3:33 PM
    #595
    JuansTaco
    Juan
    gilbert az
    definelty! im free today if that works.
    hector hasnt hit me up to install them lowers in my garage.
  16. Mar 25, 2015 at 3:35 PM
    #596
    Delta00
    Troy
    Chandler AZ
    Check Build
    Cant today, volunteer down in mesa until 10 pm :(
    Sunday im pretty free usually!
  17. Mar 25, 2015 at 3:36 PM
    #597
    JuansTaco
    Juan
    gilbert az
    we shal see then haha soon
  18. Mar 25, 2015 at 3:38 PM
    #598
    Delta00
    Troy
    Chandler AZ
    Check Build
    Yeah, shoot me a message on whatever date the lowers are going to be done and ill see if i can do that. Other then that ill try to make it to a meet or setup a day haha
  19. Mar 25, 2015 at 3:50 PM
    #599
    synergy10
    synergy10 @synergy10.sd
    San Diego
    So much progress on your rig. I'm lagging big time.
  20. Mar 25, 2015 at 8:18 PM
    #600
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks man! still need to get tires and rims.... Haha
