2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Apr 28, 2015 at 9:48 PM
    #721
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I'll probably find someone on craigslist to do it. Those guys that advertise 35 years of experience without the big shop prices. I mean if it's a cheap paint job for $150, it can't be worst than a rattlecan job that I do myself and might be as good as maaco cheap paint :notsure:
  2. Apr 28, 2015 at 9:51 PM
    #722
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Yeah, just make sure they match paint codes so you know you will get a good match.
    Did that brushed aluminum vinyl match at all?
  3. Apr 28, 2015 at 9:58 PM
    #723
    WildLand
    Josh
    NM
    16T4RSR54WD
    Yeah I will definitely make sure paint codes match before anything. Don't want another camper incident.
    And not at all. Like you warned, it's too... aluminumy surprising enough :rolleyes:
  4. Apr 28, 2015 at 10:07 PM
    #724
    Delta00
    Troy
    Chandler AZ
    Check Build
    No metallic sharpie colored hoods!! haha
    Ohwell, i guess paint will be a better long lasting option over vinyl.
  5. Apr 28, 2015 at 10:11 PM
    #725
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    You could do the vinyl yourself.. doing just the hood couldn't be that hard.
  6. Apr 28, 2015 at 10:15 PM
    #726
    Delta00
    Troy
    Chandler AZ
    Check Build
    Ha not for me, but I agree i believe the hood would be the easiest part to wrap.
  7. Apr 29, 2015 at 5:26 AM
    #727
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    The paint won't be an exact match even with the code, remember the sun has been slowly fading the paint ever since it was made :mad:
  8. Apr 29, 2015 at 10:07 AM
    #728
    WildLand
    Josh
    NM
    16T4RSR54WD
    Yeah the hood is the easiest part to wrap I would say which is why I am thinking if I am going to spend money on a hood, might as well just go all out haha but probably will just do paint.. I didn't even think of the sun :mad:
  9. Apr 29, 2015 at 10:47 AM
    #729
    Delta00
    Troy
    Chandler AZ
    Check Build
    Eh, the sun cant be that bad. There will definitely be a difference but I don't think it will be very noticeable.
    A paint shop matched a 1990 Toyota pickup fender for me and it looks the same, you would have to try hard to find a difference.
  10. Apr 29, 2015 at 10:48 AM
    #730
    WildLand
    Josh
    NM
    16T4RSR54WD
    Yeah that is true. My paint is in pretty great condition.
    Ughhh called 2 places on craigslist.. $250 and $300.. Hmm... What to do, what to do
  11. Apr 29, 2015 at 10:56 AM
    #731
    Delta00
    Troy
    Chandler AZ
    Check Build
    You could try it yourself 5 times before you add up Tue that price according to how much that one guy paid. I say try it yourself.
  12. Apr 29, 2015 at 11:27 AM
    #732
    WildLand
    Josh
    NM
    16T4RSR54WD
    Yeah I'll go that route. And with summer coming around I'll have time. Time to call around about mixing some rattle cans for me!
  13. Apr 29, 2015 at 11:31 AM
    #733
    Delta00
    Troy
    Chandler AZ
    Check Build
    Nice! And you will get some good experience with painting after that.
  14. Apr 29, 2015 at 1:11 PM
    #734
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I meant it isn't going to 100.00% perfect, but you won't tell the difference unless you're OCD. But I'd say try it yourself, if you don't like it spend the coin
  15. Apr 29, 2015 at 1:18 PM
    #735
    BAMATACO12
    BAMATACO12 Well-Known Member
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    2.5' Fabtech Suspension lift. 285/75/16 Cooper STT's New headlights Surefire mount with Quick Fist Shrockworks bumper-3 wks out on delivery Light Force 240 Blitz arriving today
    Delta, did I read somewhere in your build thread that you installed a Magnaflow 18"?
  16. Apr 29, 2015 at 1:22 PM
    #736
    Delta00
    Troy
    Chandler AZ
    Check Build
    Agreed
    I was originally. But I ended up with an aero 2525xl. Sounds great to me, loud when you're stepping in the gas and soft when your crusing.
  17. Apr 29, 2015 at 1:53 PM
    #737
    BAMATACO12
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    Cool, thanks!
  18. Apr 29, 2015 at 1:54 PM
    #738
    Delta00
    Troy
    Chandler AZ
    Check Build
    No problem man! Which magnaflow are you going with?
  19. Apr 30, 2015 at 9:28 AM
    #739
    BAMATACO12
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    Either the 14" or the 18". There seems to be somewhat of a difference of opinion on the two. The model numbers are #11255 or 11225. Just trying to make sure I order the right one you know? Haha can only install once. Here is a sound clip of Box Rocket's magnaflow. It is the exact sound I'm looking for. He has an 18". https://youtu.be/jYwav8H8gIE
  20. Apr 30, 2015 at 11:26 AM
    #740
    Delta00
    Troy
    Chandler AZ
    Check Build
    I've heard good things about the 18" magnaflow! I say go for it.
