2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Sep 29, 2015 at 7:10 AM
    #981
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That's what Im gonna do with mine so you can still see the emblem
  2. Sep 29, 2015 at 9:50 AM
    #982
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I was only considering putting on that film to protect from impacts of road debris as well as the weather elements like mud, road salts, etc. I didn't know about uv inhibitors. Hadn't considered that. I also liked the size/dimensions.
  3. Sep 29, 2015 at 10:17 AM
    #983
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Ahh okay. Well if its for that I would say that what you linked would work well!
    Without measuring though, I think the headlight is more that 6" tall and I see that the roll is 6" x 48"... But that's just a guess.
    EDIT: Went out and measured it, looks like 6" is just about right. Just a bit short on the tallest point.
  4. Sep 29, 2015 at 10:28 AM
    #984
    Delta00
    Troy
    Chandler AZ
    Check Build
    Hha don't wanna cover up that $40 emblem!
    Adventurer_Alex likes this.
  5. Oct 1, 2015 at 1:31 PM
    #985
    Delta00
    Troy
    Chandler AZ
    Check Build
    Now with pods
    HectoRome, quetzal and stumbles like this.
  6. Oct 1, 2015 at 1:40 PM
    #986
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    Lights look good.
  7. Oct 1, 2015 at 1:40 PM
    #987
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks! Gotta wait until tonight to see how bright they are!
  8. Oct 1, 2015 at 1:42 PM
    #988
    stumbles
    stumbles 1 eye
    bryan
    mesa
    Now you can get on the trails at anytime of the day.
    Delta00[OP] likes this.
  9. Oct 1, 2015 at 8:47 PM
    #989
    Digiratus
    Roaming the PNW
    The RedHead
    Those look good, which pods are they?
  10. Oct 1, 2015 at 8:53 PM
    #990
    Delta00
    Troy
    Chandler AZ
    Check Build
    Just some cheep Amazon ones, they claim an ip68 rating but we will see.
    I dont want to spend $200-300 on rigid lights when I know im going to rarely use them. So far i like them and the fit my needs well.
  11. Oct 1, 2015 at 9:07 PM
    #991
    Digiratus
    Roaming the PNW
    The RedHead
    I have piaa 510s (round) in mine right now. They are one of the fog light models. I used to need them for fill with the stock halogen headlights as they cast a low and wide beam but I don't need them any more with the projectors. Can't even tell they are on now. :D Besides both lenses cracked when I submerged them on the last trip. So its only a matter of time before the bulbs fail.
    I've been considering small LED cubes to replace the piaas. I would use them as daytime driving lights for 2-lane roads and FS roads just for visibility for oncoming traffic.
    I was thinking about a set of these: http://www.amazon.com/Rugged-Ridge-15209-03-Square-Driving/dp/B00GRHSVTW
  12. Oct 1, 2015 at 9:14 PM
    #992
    Delta00
    Troy
    Chandler AZ
    Check Build
    These are the exact one I got, for the price I am very pleased!
    http://www.amazon.com/Eyourlife-Spo...443758959&sr=8-2-spell&keywords=eyorlife+pods
    Here they are on at night.
    I forgot to get an output shot but i need to angle them up a bit and go somewhere darker. Btw, I think I asked you this but who made your headlights? I think the chrome on chrome looks pretty good!
    Also, im still working on my welding. Currently on 7018 arc welding and im almost done with that. Then I get to practice mig. Your bumper is still my favorite out there and i definitly want to try and make it some day! :D
  13. Oct 1, 2015 at 9:37 PM
    #993
    Digiratus
    Roaming the PNW
    The RedHead
    :jellydance: of the welding skill. Keep at it, practice makes perfect.
    Those pods seem pretty bright and it seems like a good price too. I hope they hold up to the rigors of the front bumper. I saw those but didn't consider them because they used epistar chips. May have to reconsider. :notsure:
    Ambguous did the retrofits for me. So far I'm happy. The chrome look turned out pretty good. Looks good anyway. There is some light scatter and a hotspot that bugs me a little bit. Its not horrible but I see it. I think it is coming from the chrome reflector. The projectors put out a shit ton of light as you kno. I think some of it reflects back from the inside of the plastic housing cover onto the chrome bowl and even the shroud. I suspect that is the source of my light scatter.
  14. Oct 2, 2015 at 5:32 PM
    #994
    Delta00
    Troy
    Chandler AZ
    Check Build
    I see how they hold up and report back. Im still waiting on my BUSS box so i can permanently wire them and then ill get some output shots and post em up!
    Scenekyd likes this.
  15. Oct 2, 2015 at 5:36 PM
    #995
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Looking good Troy! Now you need an RTT :)
  16. Oct 2, 2015 at 6:18 PM
    #996
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I agree! He's got all the armor, except skids and sliders. After those snag one!
    Then grab a Prinsu rack
  17. Oct 2, 2015 at 7:19 PM
    #997
    stumbles
    stumbles 1 eye
    bryan
    mesa
    I think he has sliders. Just hasn't put them on. Unless he sold them.
  18. Oct 2, 2015 at 7:24 PM
    #998
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks! Its definitely on the long list of mods!!
    I plan to weld my sliders on next year. Still working on my welding skills.
    Also the school I'm taking classes at has a CNC plasma so I plan to use that to make my skids since I already have the diagrams to make my own.
    Still have em! Plan to put them on eventually haha
  19. Oct 3, 2015 at 5:39 AM
    #999
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    Looking Good Troy ! !
  20. Oct 15, 2015 at 12:37 PM
    #1000
    Delta00
    Troy
    Chandler AZ
    Check Build
    Got the rest of my switches in!
