2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Nov 4, 2015 at 9:24 PM
    #1021
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    What Up Troy had some beers with the man on taco tuesday, really miss working with and hanging out with the guy, shit mang we used to talk about our trucks all day sometimes . . .
  2. Nov 7, 2015 at 2:20 PM
    #1022
    Tacosupreme09
    Tacosupreme09 Well-Known Member
    Charlotte, NC
    White Lightning
    Dude that's sweet!! Same spot haha, did you move from Arizona or make a trip down here?[/QUOTE]
    At the time I was moving from California to Indiana and I had everything I own in the truck with me, so it was a little heavy to wheel haha. I had been there as a kid and I always wanted to take my truck, Gorgeous place for sure!
  3. Nov 8, 2015 at 9:40 AM
    #1023
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Do you know if these lines will work with the 13wl tundra brake upgrade?
    One in the pic is a rear line
    And where did you buy the calibers and rotors? Did you get OEM ones?
  4. Nov 8, 2015 at 9:53 AM
    #1024
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Ha yeah! When he got home I would always get to hear what was next for your truck. But I hear you might be staring a build page soon?
    Ha, sure was fun wheeling there!
    The brake lines I used were for banjo bolts. Those brake lines look they are to be used with hard lines. Looks like they would work but they would require some extra parts.
    See banjo:
    Hard line:
  5. Nov 8, 2015 at 9:56 AM
    #1025
    gray223
    SE Missouri
    2014 Tundra Limited
    Thanks! So I would just need some hard lines to make it work? And are your calipers and rotors oem?
  6. Nov 8, 2015 at 10:01 AM
    #1026
    Delta00
    Troy
    Chandler AZ
    Check Build
    Im pretty sure that's all you would need. I hadn't researched the hard line one all that much because I never planned on using them.
    I know a lot of people got this kit
    http://www.lceperformance.com/Front-Big-Brake-Upgrade-Kit-Tacoma-1995-2004-6-Lug-p/1055203.htm
    I got the red power stop rotors and calipers. No complaints and I read other reviews saying they had no problems.
  7. Nov 8, 2015 at 10:04 AM
    #1027
    gray223
    SE Missouri
    2014 Tundra Limited
  8. Nov 8, 2015 at 10:12 AM
    #1028
    Delta00
    Troy
    Chandler AZ
    Check Build
    Man, the more I look at it I think that the hard line brake lines are meant for the 4runners. Tacoma's use the banjo bolts. If you look at the spindle on the two pictures I posted where the brake line gets close its different. I'm sure you can make it work I just don't want to say "yeah it will work" when I don't know for certain.
    Where did you get those brake lines?
  9. Nov 8, 2015 at 10:57 AM
    #1029
    gray223
    SE Missouri
    2014 Tundra Limited
  10. Nov 8, 2015 at 10:59 AM
    #1030
    gray223
    SE Missouri
    2014 Tundra Limited
    That lce kit looks like it uses hard lines
  11. Nov 8, 2015 at 11:18 AM
    #1031
    Delta00
    Troy
    Chandler AZ
    Check Build
  12. Nov 8, 2015 at 12:00 PM
    #1032
    gray223
    SE Missouri
    2014 Tundra Limited
    Wonder if lce would just sell me the brackets and the hard lines
  13. Nov 8, 2015 at 12:00 PM
    #1033
    Delta00
    Troy
    Chandler AZ
    Check Build
    Wouldn't hurt to call them.
  14. Nov 8, 2015 at 12:06 PM
    #1034
    gray223
    SE Missouri
    2014 Tundra Limited
    Actually it says that brake line kit is for the 13we calipers? Does that make a difference?
  15. Nov 8, 2015 at 12:07 PM
    #1035
    Delta00
    Troy
    Chandler AZ
    Check Build
    I think the only difference betwwen 13we and wl is the size of the caliper 199mm and 231mm
  16. Nov 8, 2015 at 12:08 PM
    #1036
    Delta00
    Troy
    Chandler AZ
    Check Build
    And @alphabravo is using the 13wl with this kit i believe.
  17. Nov 8, 2015 at 12:13 PM
    #1037
    gray223
    SE Missouri
    2014 Tundra Limited
  18. Nov 8, 2015 at 12:17 PM
    #1038
    Delta00
    Troy
    Chandler AZ
    Check Build
    I think when they use the hard line the brake line is a bit shorter so if you were to go that route you might be overstretching those lines.
    Is there anyway you can return those lines/sell them? Im very happy with my wheelers offroad ones. They also come in black if you dont like red.
  19. Nov 8, 2015 at 3:13 PM
    #1039
    gray223
    SE Missouri
    2014 Tundra Limited
    Well we bought the front and rear as a kit and I'm currently using the rear one, so probably not but maybe.
  20. Nov 8, 2015 at 5:26 PM
    #1040
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Delta00[OP] likes this.
