2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Feb 1, 2016 at 1:19 PM
    #1141
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Oh, that's a lot more white than I was imagining. Thanks!
    Delta00[QUOTED][OP] likes this.
  2. Feb 4, 2016 at 7:56 AM
    #1142
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    What all did you buy for the Tundy upgrade? Thinking about using my refund for that and UCA. Then I'll buy some new LBJ and knock it all out one weekend
  3. Feb 4, 2016 at 10:29 AM
    #1143
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Got this kit:
    http://www.amazon.com/gp/product/B00EOBMFAY?psc=1&redirect=true&ref_=oh_aui_search_detailpage
    These brake lines: And this sticker:
    http://www.speedysgarage.net/sportrunner/tundra_brakes/projectsportrunner_tundra_brakes.htm
    And a lot of brake fluid haha
    BYJOSHCOOK[QUOTED] likes this.
  4. Feb 4, 2016 at 10:34 AM
    #1144
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  5. Feb 4, 2016 at 10:46 AM
    #1145
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Awesome! Wanted to make sure I didn't need anything else. No modification to the banjo bolt?
    Thanks
  6. Feb 4, 2016 at 10:55 AM
    #1146
    Delta00
    Troy
    Chandler AZ
    Check Build
    Wheelers kit comes with new banjo bolts so no need to modify them.
  7. Feb 4, 2016 at 11:34 AM
    #1147
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Awesome! I'll use my tax return on them then!
  8. Feb 4, 2016 at 12:12 PM
    #1148
    Delta00
    Troy
    Chandler AZ
    Check Build
    Just don't overtighten them like I did. I broke the bolt off in the caliper which sucked trying to get it out. If its not sealing something is wrong with the caliper itself like I found out the hard way...
  9. Feb 4, 2016 at 1:48 PM
    #1149
    MatthewMay1
    Matthew
    Lone Star Republic
    Still need to do this....but other things keep getting in the way. AND I think I have another warped rotor or drum. Very annoying :frusty:
  10. Feb 4, 2016 at 2:26 PM
    #1150
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I was gonna do it during December break but I needed to do some other things
  11. Feb 5, 2016 at 9:28 PM
    #1151
    SeekingZero
    SeekingZero Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    Damn you've been busy! The truck looks awesome! That brake upgrade is on my list, especially with my trailer adding to my brake wear.
  12. Feb 6, 2016 at 10:30 AM
    #1152
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks! The brake upgrade was absolutely a huge improvement and brings back a lot of the lost braking power with all the extra weight added.
  13. Feb 10, 2016 at 5:55 AM
    #1153
    cynicalrider
    cynicalrider #NFG
    Jersey
    Can't believe I'm not subbed. Your truck is the only reason I am considering doing a BHLM when I retrofit eventually.
  14. Feb 10, 2016 at 9:28 AM
    #1154
    Delta00
    Troy
    Chandler AZ
    Check Build
    Awesome! BHLM definitely gives it a different look! I'm happy with how it turned out in the end.
  15. Feb 10, 2016 at 9:52 AM
    #1155
    MatthewMay1
    Matthew
    Lone Star Republic
    did you buy blacked out corner housings, or did you paint them?
  16. Feb 10, 2016 at 9:59 AM
    #1156
    Delta00
    Troy
    Chandler AZ
    Check Build
    Bought them, I don't think you can open the corners. Well I'm sure you can but doing it might be really hard
  17. Feb 10, 2016 at 9:59 AM
    #1157
    MatthewMay1
    Matthew
    Lone Star Republic
    ok, I didn't know if you could open them either
  18. Feb 10, 2016 at 10:08 AM
    #1158
    cynicalrider
    cynicalrider #NFG
    Jersey
  19. Feb 10, 2016 at 10:12 AM
    #1159
    MatthewMay1
    Matthew
    Lone Star Republic
  20. Feb 10, 2016 at 10:20 AM
    #1160
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah the plan was going to use those only as turn signals, not on all the time. But agree, def a little ricey.
