2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Mar 29, 2016 at 8:25 AM
    #1321
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Ya think I might go for it. What I am wondering is if I would feel any kind a slight power increase. I know most say they do not but my question is since I live up in the mountains(6500-7000ft) if if would be more beneficial up here to get more air in the intake since the air is thin up here and I might actually feel a difference compared to most other users in lower elevations
  2. Mar 29, 2016 at 8:27 AM
    #1322
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    You might, but I'd be skeptical. If you have access to a dyno, test it and report back on the high altitude effects of the mod
    FirstGen Jer[QUOTED] likes this.
  3. Mar 29, 2016 at 8:28 AM
    #1323
    FirstGen Jer
    Jeromey
    Ya that would be awesome...unfortunately though no dyno access.
  4. Mar 29, 2016 at 8:29 AM
    #1324
    MatthewMay1
    Matthew
    Lone Star Republic
    Hit up a drag strip! Do 3 runs without the plate, 3 with. Average them and see. Then you also get to have some fun. Haha
  5. Mar 29, 2016 at 8:33 AM
    #1325
    FirstGen Jer
    Jeromey
    Haha:thumbsup:, If only there was a drag strip where I live. nearest one is about 1.5hrs away and that's down the mountain at about 1500ft.
  6. Mar 29, 2016 at 8:46 AM
    #1326
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Digiratus describes the "use" of the deck plate mod the funniest. Where you at Mike!
  7. Mar 29, 2016 at 9:03 AM
    #1327
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I assume this is what you are referring to. :luvya:
    (from the daily thread)
  8. Mar 29, 2016 at 9:18 AM
    #1328
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Aw I still have the damn CAI the OP put on, I guess I'm not a true member :pout:
    Digiratus[QUOTED] likes this.
  9. Mar 29, 2016 at 9:21 AM
    #1329
    Speedytech7
    It's okay, I have a 4cyl so the power gain to effort ratio (0hp::0fucks) wasn't good enough for me to bother. Which CAI you have, is it one of the shielded ones?
  10. Mar 29, 2016 at 9:25 AM
    #1330
    Speedytech7
    Sliding back on topic, @Delta00 why u no burn sliders on?
    I want to know what your planning for a rear bumper, I'm in the early drawing stages of making one as well.
  11. Mar 29, 2016 at 9:28 AM
    #1331
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Volant intake, what do you mean by shielded ones?
  12. Mar 29, 2016 at 9:31 AM
    #1332
    Speedytech7
    Like this...
    Or some are in a box like this...
  13. Mar 29, 2016 at 9:43 AM
    #1333
    MatthewMay1
    Matthew
    Lone Star Republic
    I hope it is shielded....Kinda dumb not to if you ever go off road
  14. Mar 29, 2016 at 9:57 AM
    #1334
    Speedytech7
    That's why I've left my intake alone, becomes hard to find decent filters too. Afe is the only company I know of that makes a quality pod filter, the rest are oily or let in everything but boulders. Putting CAI intake pipe on a stock air box would be the most I'd change because it allows you to remove the intake baffles and silencer heimholz resonators. That'll get you the sound and quality filtration.
  15. Mar 29, 2016 at 10:11 AM
    #1335
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Welder is still being shipped to me then they should go on. I'm planning on replicating the one @Digiratus has with some things different. I think its the best looking plate bumper out there.
  16. Mar 29, 2016 at 10:20 AM
    #1336
    Speedytech7
    Ahh, gotcha. Yeah its a good looking bumper, all the little details for the foldout table and little lock to hold the gate open are great too. It's a sight to behold in person.
    I'm looking to do similar, but I want to tuck it up even higher and rather than cover the bedsides to the tire well I'd just chop em at the bottom of the tail light and have the plate wrap around higher up and keep it as out of the way as possible. Basically I'd want no part of it more than ~2" below the frame.
  17. Mar 29, 2016 at 10:27 AM
    #1337
    Delta00
    Troy
    Chandler AZ
    Check Build
    Nice, yeah I will be putting my own spin on it but I haven't put much time into thinking about it. I'll only e able to work on it during the summer because that's when I'll only have free time to take on a large project.
  18. Mar 29, 2016 at 10:28 AM
    #1338
    Digiratus
    Roaming the PNW
    The RedHead
    It is awesome but I have Monte to thank for that. @Blackdawg
  19. Mar 29, 2016 at 10:32 AM
    #1339
    Delta00
    Troy
    Chandler AZ
    Check Build
    Haha, I'm thankful that Monte was nice enough to do a detailed write up of the process!
    Blackdawg likes this.
  20. Mar 29, 2016 at 10:33 AM
    #1340
    Speedytech7
    When does summer begin for you? I've got access to a good welder, but I'm hoping to acquire a plasma cutter rather than do the whole thing with grinders and death wheels. But if I have to I will, I'm about two months away from being able to start on one.
