2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Jun 5, 2016 at 6:41 PM
    #1761
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    My new bumper isn't tube and it's still perfect. :anonymous:
  2. Jun 5, 2016 at 6:42 PM
    #1762
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Ha, well I don't know if I'll be ordering within the next 2 months.
    Yeah, still need to put it in though. Working a lot to pay for all the nice suspension stuffs so not much time to do it haha.
  3. Jun 5, 2016 at 6:43 PM
    #1763
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Hybird? Still not as heavy.
  4. Jun 5, 2016 at 6:44 PM
    #1764
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Yes, but like 80% plate and a winch. Pretty heavy.
  5. Jun 5, 2016 at 6:55 PM
    #1765
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    This
  6. Jun 5, 2016 at 7:04 PM
    #1766
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    My opinion is 700's are too much. For low speed crawling especially, it's gonna be significantly harder to reach full bump with 700's. The counter argument to that is often that the front "Feels bouncy" over speed bumps, however that is all in the valving of the shock. You should use the lightest spring you can get that will set your ride height where you want without too much preload. Too much preload and your coils maybe limiting your up travel.
    stumbles likes this.
  7. Jun 5, 2016 at 7:08 PM
    #1767
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    This is solid info.
  8. Jun 5, 2016 at 9:40 PM
    #1768
    Delta00
    Troy
    Chandler AZ
    Check Build
    Thanks for all the great info!!
    Now only if there was an ads group buy....
  9. Jun 5, 2016 at 9:42 PM
    #1769
    cbechtold
    Cory
    Pleasanton, CA
    *cough* Start one... :anonymous: *cough*
  10. Jun 5, 2016 at 9:45 PM
    #1770
    stumbles
    stumbles 1 eye
    bryan
    mesa
    What he said. I would jump on that.
  11. Jun 5, 2016 at 9:48 PM
    #1771
    Delta00
    Troy
    Chandler AZ
    Check Build
    Hmmm... Let me finish my current one and I'll see what is possible!
    BYJOSHCOOK and stumbles[QUOTED] like this.
  12. Jun 5, 2016 at 9:48 PM
    #1772
    cbechtold
    Cory
    Pleasanton, CA
  13. Jun 5, 2016 at 9:50 PM
    #1773
    Delta00
    Troy
    Chandler AZ
    Check Build
    Much respect to @ramonortiz55 for setting up group buys, they are more difficult than I thought an the one I did was pretty simple.
  14. Jun 5, 2016 at 10:48 PM
    #1774
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Knowing what I kno now, I think I will go ADS next go around. I actually like my kings a lot but I think the ADSs might be better.
    I would do 700s on them tho. It is what I have on the Kings. I've worn out 650s with all of the weight.
    I would too.
  15. Jun 6, 2016 at 7:37 AM
    #1775
    MatthewMay1
    Matthew
    Lone Star Republic
    Oooooh I'm going to be very sad if there's an ADS group buy before I have that much extra cash...
  16. Jun 6, 2016 at 8:02 AM
    #1776
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    In for the GB
  17. Jun 6, 2016 at 8:05 AM
    #1777
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    ADS was one of the brands i had in mind for a group buy as part of my extravaganza, none of the vendors want to :(
  18. Jun 6, 2016 at 9:53 AM
    #1778
    Delta00
    Troy
    Chandler AZ
    Check Build
    Nooooooo
  19. Jun 6, 2016 at 11:03 AM
    #1779
    Digiratus
    Roaming the PNW
    The RedHead
    Screw the vendors... Maybe ADS will work with us directly?
  20. Jun 6, 2016 at 11:13 AM
    #1780
    Delta00
    Troy
    Chandler AZ
    Check Build
    I sent them a message last night, have yet to hear a response.
    BYJOSHCOOK and Digiratus[QUOTED] like this.
