2002 Tacoma 4WD Build
Discussion in '1st Gen. Builds (1995-2004)' started by Delta00, Jun 3, 2014.
  1. Jul 12, 2016 at 7:27 PM
    #1961
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    What's the next project?
    Delta00[QUOTED][OP] likes this.
  2. Jul 12, 2016 at 7:39 PM
    #1962
    Delta00
    Delta00 [OP] ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    About 23.5" in the front with around 1.5" of rake. I think the springs may settle a bit also.
    What's yours?
    I eventually want to make a bed rack for a rtt in the future!
  3. Jul 12, 2016 at 7:55 PM
    #1963
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    What all was involved in getting the gussets to work?
  4. Jul 12, 2016 at 8:02 PM
    #1964
    Delta00
    Troy
    Chandler AZ
    Check Build
    What do you mean? Like how to make them fit better?
    I just had to bend them in some areas, mostly the bottom part of it were it is closest to the hub. It had a pretty big gap that would have been hard to weld. No matter what there will be gaps, but none to crazy.
  5. Jul 13, 2016 at 4:38 AM
    #1965
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah that and the prep work you did. I assume grinding the paint to the bare metal and cleaning it?
  6. Jul 13, 2016 at 7:06 AM
    #1966
    Delta00
    Troy
    Chandler AZ
    Check Build
    Yep, I got one of those wire and wheel attachments for the angle grinder and that worked great, just took the paint away and not the metal.
  7. Jul 13, 2016 at 7:41 AM
    #1967
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Gotcha, what held you up that took so long then?
  8. Jul 13, 2016 at 9:36 AM
    #1968
    Delta00
    Troy
    Chandler AZ
    Check Build
    Well, just getting the spindles off in the first place. Then getting everything to fit exactly how I wanted. Then waiting between welds so it doesn't get to hot. I'm sure it could be done quickly, I think I just took a long time.
  9. Jul 13, 2016 at 9:57 AM
    #1969
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Gotcha! Did you have a press or just rent the thing from Vatozone?
  10. Jul 13, 2016 at 10:46 AM
    #1970
    Delta00
    Troy
    Chandler AZ
    Check Build
    Press for what? To get the adapter for the UCA in? I bought a 20 ton press to get those in.
    Also press that in before your weld the spindles.
  11. Jul 13, 2016 at 11:42 AM
    #1971
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Correct! (sorry at work and typing fast without properly thinking). Pretty sure that's all that would hang me up would be prep for the spindles and the adapter.
  12. Jul 13, 2016 at 4:11 PM
    #1972
    Delta00
    Troy
    Chandler AZ
    Check Build
    Yeah, those adapters are hard to get in. Broke a vice in the process :(
  13. Jul 13, 2016 at 4:33 PM
    #1973
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's what I've heard. Hope my friends press works ha
  14. Jul 13, 2016 at 5:28 PM
    #1974
    Delta00
    Troy
    Chandler AZ
    Check Build
    It was just an excuse to buy more tools haha
  15. Jul 13, 2016 at 5:43 PM
    #1975
    BYJOSHCOOK
    Josh
    Check Out My Builds
    If I had the place to store them ha
  16. Jul 13, 2016 at 6:22 PM
    #1976
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Just don't park the truck in the garage. Problem solved :p
    Delta00[OP] likes this.
  17. Jul 13, 2016 at 7:01 PM
    #1977
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I don't have a garage or else I'd have tools :anonymous: damn apartments....
  18. Jul 13, 2016 at 7:03 PM
    #1978
    cbechtold
    Cory
    Pleasanton, CA
    Welp... Time to move then :p
  19. Jul 13, 2016 at 7:10 PM
    #1979
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Wish I could, renting houses out here at college age is a nightmare. Either have to pay a huge deposit or live in apartments....
  20. Jul 13, 2016 at 7:12 PM
    #1980
    cbechtold
    Cory
    Pleasanton, CA
    Or just live in your RTT :p and rent a 1000 sq ft garage :p
