2002 Tacoma 4x4 Awful Gas Mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by iw719, Oct 27, 2019.
  1. Oct 28, 2019 at 7:39 AM
    Glamisman
    Glamisman Well-Known Member
    My 96 4X4 will only get 15mpg in town driving and thats if I drove gently. 31 10.50 15's, automatic, 175k miles, Flatland bumper and winch (heavy, heavy).
  2. Oct 28, 2019 at 8:33 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    change your spark plugs, clean your MAF sensor, clean the throttle body, change your air filter, replace your PCV valve, use a couple doses of B12 chemtool (make it strong, like only fill up 1/2 tank at most), then a dose of Techron concentrate.
    Your MPGs shouldn't be that bad. I'm getting like 18 MPG on the highway and my truck is heavy.
    det107 likes this.
  3. Oct 28, 2019 at 9:44 AM
    eon_blue
    Azusa, CA
    I remember when I first got my truck, from filling up at the gas station to where the needle would finally start to go down, would take about 70 miles.
    Now, the needle starts going down after fill up once I hit about 25 miles lol :(
    det107 and GQ7227 like this.
  4. Oct 28, 2019 at 12:13 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Yea I know the feeling. Good thing it’s not my daily. With my beater I get around 380 miles before I have to fill up (11-12 gallons) compare to 200 miles (15 gallons) on my Tacoma. My Softopper also creates drag and decrease 1-2mpg so I try to have it down when I don’t need it.
    GQ7227 and det107 like this.
  5. Oct 28, 2019 at 1:07 PM
    bcrooms
    bcrooms Well-Known Member
    Brandon
    Georgia
    1999 Toyota Tacoma XCab 2.7L SR5 4WD
    My 1999 2.7L 4x4 was doing bad on MPG until I had the Catalytic converter replaced with a Magnaflow universal cat and replaced the fuel filter. Gets much better now.
  6. Oct 28, 2019 at 1:23 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    OP,
    What motor and trans do you have?
    The Magnaflow catalytic converter is awesome. It improved the low end on my 2.7 (3RZ) motor. I have an auto trans and my truck weighs in just under 4,300 pounds and I’m getting 15-17 mpg’s.
  7. Oct 28, 2019 at 1:42 PM
    eon_blue
    Azusa, CA
    Magnaflow is the only good aftermarket option for catalytic converters, particularly if you need them to meet CA smog specs. I had to replace mine a few years ago and got the CARB certified Magnaflows and they've held up great so far. Far, far cheaper than OEM cats. Although OEM cats are the best quality ones you can get hands down.
  8. Oct 28, 2019 at 1:44 PM
    eon_blue
    Azusa, CA
    Don't go replacing your cats though unless you need to...usually you'll know by the dreaded P0420 code, or when your truck's performance tanks due to one or both getting plugged up
    Ritchie likes this.
  9. Oct 28, 2019 at 4:23 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Like others have said...start simple. I would start with spark plugs and PCV valve...shouldn't cost more than $20-25 for it all unless you don't have the tools. But you should get the tools if you don't already have them.
  10. Oct 29, 2019 at 1:37 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    Oh P0420, I know thee well.
  11. Oct 29, 2019 at 1:38 PM
    eon_blue
    Azusa, CA
    Shhh...say it too many times and it will come back to haunt us
    Fortunately I just passed my biennial smog test last Saturday so either way I'm good for another 2 years lol
    Ritchie likes this.
  12. Nov 5, 2019 at 9:28 PM
    iw719
    iw719 [OP] Member
    Ian
    2002 Black Tacoma Xtra Cab 4x4
    The CEL isnt on, and I went and got the ecu flashed. No codes. Im going to replace the O2 sensor tomorrow to see if it fixes anything.
  13. Nov 5, 2019 at 9:31 PM
    iw719
    iw719 [OP] Member
    Ian
    I actually just checked how far it is to work. Its 19 miles one way. 38 miles and a quarter tank of fuel isnt great. Guess i thought the drive was longer, turns out my gas mileage is even worse
  14. Nov 5, 2019 at 9:34 PM
    iw719
    iw719 [OP] Member
    Ian
    Its the 3.4L V6 with a 5 speed. The 4x4 taco gearboxes are awful. At cruising speed on the highway im sitting at 3000 rpm, but even driving slowly im not doing much better gas wise. Im hoping to get a new exhaust soon, hopefully it fixes some things.
  15. Nov 6, 2019 at 2:07 AM
    #35
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    The one which will impact MPG is your AFR (Air Fuel Ratio Sensor), not the o2 sensor. The AFR is upstream and expensive. When replacing AFR or o2, stick with Denso. None of those cheap aftermarket sensors.
    Like most mentioned, start simple. Give it a good tune-up and see where you are. I wouldn't replace the sensors unless you are throwing codes. Save the AFR for later.
    As for what you can expect, realistically - I'd be content with 14-16 MPG. Our trucks (especially 3.4 DC) are not known for fuel efficiency.
