2002 Tacoma Brake/Turn light issue.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Torqd, May 13, 2010.
  1. May 13, 2010 at 9:22 PM
    Torqd
    Torqd [OP] Member
    Central IL
    01 Ext cab TRD 4x4 Auto V6
    This is the replacement truck for my 97 frame rot truck. Need to get a game plan for mods!
    I have a 2002 Tacoma 4x4 TRD that turns on the left turn signal... front and rear... solid on state... when I hit the brakes. And when I use the turn signal and then hit the brakes it locks up the flasher until I let off the brakes and then resumes flashing.
    The only other electrical type problem started a few months back in winter... the Dome light is not being activated by the drivers door most of the time. Sometimes when it does turn on it just fades to off fairly quickly.
    Any body have either of these two problems before... I have had sticky door dome light switches before on other trucks but I am not sure if these are related or just everything is beating me down at once:)
    Sorry to vent just a little lost here.
    Thanks in advance!
  2. May 14, 2010 at 5:27 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I also have a turn signal problem :( I thought it was the flasher...replaced it with a new one...same problem :mad: must be a loose wire or bad ground somewhere...I hate electrial probs...
  3. May 14, 2010 at 3:32 PM
    Torqd
    Torqd [OP] Member
    Central IL
    Mine ended up being the aftermarket trailer light conversion kit. It must of had a short... I unhooked it and plugged my lights into the factory harness and all is well... Good luck!
  4. May 15, 2010 at 8:52 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Thx...I got a bunch of little issues I have to fix on my truck today and this one is definetely on the list :cool:
  5. May 15, 2010 at 8:53 AM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Also putting on my new Tails and Corners...I'll post pics later...They looks Schookem!!! :D
