2002 Tacoma Clutch Pedal Spring Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by kp12584, May 20, 2014.
  1. Jun 1, 2014 at 7:08 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Start to finish time was about 45mins - getting that damn oem spring out was a pita but IT did come out w/a flathead screw driver. Problem went away.
    Thanks TW community.
  2. Jun 1, 2014 at 8:15 AM
    kp12584
    kp12584 [OP] Member
    Lift kit, after market security system
    Here ya go:
    http://lieblweb.com/clutchbushing.html
  3. Jun 1, 2014 at 9:35 PM
    Combatman
    Combatman Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    Well actually I found out the spring is a heck of a lot easier to get out if you use one hand to depress the clutch while using the other to pry out the spring with a flat head.
    I think Depressing the clutch put put pressure on the center of the spring and caused it to relieve pressure on the mount holes. I was able to pop it out first try
