2002 tacoma race build
Discussion in '1st Gen. Builds (1995-2004)' started by linked2002, Aug 17, 2011.
  1. Jun 15, 2013 at 9:41 AM
    #361
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Nice to see some progress man. When this thing moves I'm coming to see it!
  2. Jun 15, 2013 at 12:15 PM
    #362
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Hard to tell but is there any lift built into those?
  3. Jun 15, 2013 at 4:00 PM
    #363
    linked2002
    linked2002 [OP] Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    Nope. For proper KPI I was t able to place any lift into the spindle.
  4. Jun 15, 2013 at 7:39 PM
    #364
    TC yota
    Tyler
    Escondido
    Ha
    Starting with a bare snout block you could put the kpi where ever it needs to be
  5. Jun 15, 2013 at 10:46 PM
    #365
    linked2002
    san diego
    Indeed. But you can only move the KPI line in so far before the bolt hits the back of the snout block. When your running KPI off of the wms of the rotor with this backing plate, if you put the bolt head against the back of the block ( as far in as physically possible without ruining structural integrity of snout block) 12* still yields you an inch and a quarter positive scrub radius at the wms. More KPI is out of the question and more positive scrub will be detrimental. I'm all ears to ideas.
  6. Jun 16, 2013 at 10:13 AM
    #366
    TC yota
    Tyler
    Escondido
    Ha
    Sounds like you got it figured out! At least its not a 4x chassis where you need the extra ground clearance haha
  7. Jun 16, 2013 at 3:36 PM
    #367
    linked2002
    san diego
    thats what im saying! hahah. right now i have the bottom bolt and nut so snug to the backing plate, that you cant even get to the nut with a wrench. it sits inside the vertical support and is sammiched between the 2 plates. only takes one ratchet from the bottom to install/remove spindles! so effing nice!
    on a side note, tyler, send me a text to kick me in the dick tomorrow afternoon to get down to fiberwerks for you. ive been meaning to and realize i need to as i pull up my damn driveway.
  8. Jun 16, 2013 at 5:34 PM
    #368
    TC yota
    Tyler
    Escondido
    Ha
    Haha will do man thanks!
  9. Jun 16, 2013 at 6:04 PM
    #369
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
  10. Jun 18, 2013 at 11:26 AM
    #370
    Werkro01
    Werkro01 Senior Clown
    Rob
    CT
    Butters
    Long Bed Leer cap, Wheather tech floor liners, Black badges, Demello Offroad front plate bumper, rear wrap around tube bumper and sliders. Scorpion lined bed, rocker panels and fender flares.
    Golly gee! This sure is a swell build! That gosh darn 3-link sure does look sturdy. I sure do like what I'm seeing so far.
  11. Jun 18, 2013 at 11:29 AM
    #371
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    That's a 4 link.
  12. Jun 18, 2013 at 11:56 AM
    #372
    Werkro01
    Rob
    CT
    Butters
  13. Jun 18, 2013 at 12:12 PM
    #373
    linked2002
    san diego
    Werkro is correct. I have a triangulated three link with a single vertical 1-1/4" vertical heim.
  14. Jun 18, 2013 at 12:18 PM
    #374
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I stand corrected! Thanks.
  15. Jun 18, 2013 at 12:23 PM
    #375
    Werkro01
    Rob
    CT
    Butters
    Linked, you forgot to mention that it's awesome! Just wondering if there would be any advantages to that wishbone style 3-link that the Jeep is running? I'd think it would spread out the forces differently than your straight pieces. Any ideas? Either way I think that triangulated 3-link is pretty tops.
  16. Jun 18, 2013 at 1:33 PM
    #376
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    It should be the exact same. The upper links mainly control the pinion angle through the stroke. The only things that would make the jeep differ from OP's is link lengths and angles. And I'm pretty sure that a wishbone 3-link with the same angles and lengths as a 4-link are going to act exactly the same. I'm not a 100% sure on that one though.
    To the OP, this is an awesome build.
  17. Jun 18, 2013 at 7:43 PM
    #377
    linked2002
    san diego
    Southerntaco hit the nail on the head. There is no variation I'm my design vs that jeeps other than the fact it looks that the jeeps lowers are parallel with the frame rails as opposed to triangulated as well that is where I would say I have the advantage. When you place your lower links exactly parallel with the rails you see much more extreme forces at the ends. With a slight angle built inboard, it forms a triangle which is also more structurally sound than parallel bars. Either way I'm sure it serves its purpose and many many many people run parallel links, just not this guy.
    And thank you all for the compliments. Been a long time coming but light is at the end of the tunnel now.
  18. Jun 23, 2013 at 11:24 AM
    #378
    linked2002
    san diego
    Both sides tacked together, both sides cycled, both sides dialed. It's time to make this shit happen.
  19. Jun 27, 2013 at 9:54 PM
    #379
    linked2002
    san diego
    Yup. So now I need rotors and calipers ( have a caliper but would prefer another set) from a solid axle front end. The mis calculated wording of the ad that I picked the spindle flanges up from sort of just screwed me. Only real reason I went with this company as opposed to machining them myself was because the ad said all of the parts I had sitting in my garage would work. Well, not including cost of the flanges, I'm out 500 in parts because none of the stuff I had fit as advertised. Not a happy individual to say the least. Sending the slotted rotors I have back hopefully and hope to recoup funds.
    If anyone has the parts I've requested, it would be much appreciated. And since I've had a conflict on this site before regarding a parts request, here are the exact years:
    Pre 89 (1988 and prior folks) solid axle front end mini trucks. I am looking for stock calipers and stock rotors.
    Thanks for any help.
  20. Jun 28, 2013 at 7:57 AM
    #380
    Werkro01
    Rob
    CT
    Butters
    So your going solid axle front end... I feel like you're gonna have to do some fabbing. Not the whole thing but some. Have you checked out any of the salvage yards around? That would be where I would go looking for something like that.
    Wish I could help. Good luck finding those parts.
